Old 12-22-2003, 10:18 PM   #8116
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Default Gearing
I'm going to the 128 tooth spur and was wondering if that means I HAVE to go to say a 27 or so pinion. The highest I have is a 23 pinion right now am going to get a 27 this weekend but wanted to go ahead and put a pinion on my motor... Thing is, the 23 doesn't look like it'll mesh properly to the new spur... Am I doing something wrong?
Thanks!
J
JitsuGuy is offline   Reply With Quote
Old 12-22-2003, 10:45 PM   #8117
Send a message via AIM to ZER01
Jitsu, for what class of racing? Try to maintain the same amount of final drive ratio with your new spur.
Has anyone else tried the new spur? Any differances?
ZER01 is offline   Reply With Quote
Old 12-23-2003, 12:06 AM   #8118
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Are you talking about the kevlar spur gear? If so I have ran it for a while now.....its a spur gear. I mean the only thing that I noticed with it is its harder to strip and it runs a little more straight then the blue ones did.
Jitsu....not saying that your dumb or anything but make sure the pinions are the same pitch.....lol. I have used a 23t with the 128 spur with out any problems....maybe you have a bad gear.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-23-2003, 12:09 AM   #8119
I'm using a 128 64p kevlar spur and using between 37 - 39 tooth pinions. Using Monster stock motors on a reasonably medium to large sized track which has a large straight but not a particularly tight infield. The 128 spur seems fine but the motor can get hot on hot days.
AlanC is offline   Reply With Quote
Old 12-23-2003, 12:47 AM   #8120
KKKWAN's Avatar
For me, using 23T motor, and I have green Spur gear with 29,30,31,33 on pinion gears.
why I use 48 pitch coz I feel 23T motor is quite power in low RPM of the motor.
Maybe later I will change to 64 pitch gear and feel the different.
There have some option parts which can change spur gear easily,
so...I will thinking about this options.
KKKWAN is offline   Reply With Quote
Old 12-23-2003, 08:11 AM   #8121
JitsuGuy's Avatar
I don't think I have the right pitch pinion gear, cause it's the same pinion I was using with my other 88 tooth spur... Does that make sense?
J
Old 12-23-2003, 08:40 AM   #8122
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
OHH, you now have a 64P spur gear with 48P pinions...that would be a problem. I would suggest (depending on how big your track is picking up from 28-34 teeth in 64P.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-23-2003, 08:45 AM   #8123
JitsuGuy's Avatar
Oh okay. heh... See I didn't know that.
Thanks!
J
Old 12-24-2003, 03:34 AM   #8124
highwayman's Avatar
hmm... that's pretty high for the monster stock... i use a 33/128 on a mid size track (final drive 7) maybe a tooth or 2 up if its pretty big, or has a long straight... i guess that's why your motor gets hot... over geared maybe.
highwayman is offline   Reply With Quote
Old 12-24-2003, 03:38 AM   #8125
highwayman's Avatar
J
wrong pitch... just to add to Brian's post, might i suggest 27 to 39, if you run 9Turn and up mod motors, stock and 19T.
Old 12-24-2003, 03:41 AM   #8126
highwayman's Avatar
Originally posted by pro3racer
do aluminum n\knuckles weich thatmuch, and do they do any other good other than not being able to strip out. I've stripped out 2 knuckles, both grphite, and don't want to do it again. Also, what chassis improvement would be best for carpet racing, my car is graphite(old style), and with no aluminum parts. Should i upgrade my electronics, or go to my chassis.
with regards to weight, there shouldn't be a problem with the aluminum ones... i just really like them, so that i don't strip them in a race... stripping is my number 1 reason.
Old 12-24-2003, 11:12 AM   #8127
ENERGY Racing's Avatar
Smile
Hi I have a XXX-S and I would like to find out how to properly set up my Losi shocks.
I have built them many times and they are different each time.
After they sit for a while and they get compresed they sound like there is air in them but after you compress them a few times it goes away.
HOW DO YOU KNOW THEY ARE GOOD??????????
http://energyracing.tripod.com
energyracing@integy.net
XRAY T2007 / Associated B4 / IRS Rug Rat
www.fastcats.ca / www.sidsraceway.com
ENERGY Racing is offline   Reply With Quote
Old 12-24-2003, 06:31 PM   #8128
well i donno if its the same wit offroad but in offroad after i build it if the shaft goes back in after i pull it all the way up i know its perfect
craziracer is offline   Reply With Quote
Old 12-24-2003, 06:32 PM   #8129
same wit onroad***
Old 12-24-2003, 06:45 PM   #8130
No offence, but the Losi shocks are the absolute easiest shocks I have ever built and I have built all brands including HPI, associated , Tamiya, duratrax, ofna, integy, and kyosho shocks!!!!! and for what it's worth the hard coated losi shocks with Ti-nitride shafts are as smooth as the ultra slick Tamiya pieces I have built.... and when built right hardly ever leak!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
