Old 12-19-2003, 12:30 AM   #8056
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Yeah, aluminum screws look good, but are bad news really... Until you have a head of one break off flush *inside the chassis* it's all good. When that happened to me, I just bought the new graphite chassis at that time. Forget trying to drill that puppy out and then making an even bigger hole to have to deal with!
J
JitsuGuy is offline   Reply With Quote
Old 12-19-2003, 07:56 AM   #8057
RCGaryK's Avatar
I only saw a little bit of one round, but it looked pretty good
And that was with ME driving it
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-19-2003, 10:43 AM   #8058
I use Aluminum screws to mount my wings to my bodies... and that is it!!! I'd rather save weight elsewhere..... BTW: I have only ever had 1 stock screw strip out ever ...well since I bought my good drivers!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-19-2003, 01:18 PM   #8059
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
J
Yeah, Been there, done that.. I didnt try to drill it out though.
Jitsu - Are you coming to Milwaukee for the Novak race with the rest of the Ok guys?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-19-2003, 01:57 PM   #8060
lazyboy's Avatar
Send a message via AIM to lazyboy
Post
k thakns Brian ill have to see if josh has it or not. cya sunday
preston
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 12-19-2003, 09:43 PM   #8061
JitsuGuy's Avatar
No, I'm not coming I wish I was though! I'm sure I'll hear ALL about it when they get back! heh.
This may be a dumb question but anyhoo... Can I run the Off-Set hubs in the non-offset position? I don't see why not but I thought I'd ask.
J
Old 12-19-2003, 09:55 PM   #8062
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Jitsu....yes they will fit in the outside holes but the CVD's will be on the verge of falling out of the outdrives....also that would make the rear end VERY wide compaired to the front.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-19-2003, 10:01 PM   #8063
nutfluff's Avatar
Send a message via AIM to nutfluff
So after some long and hard deliberation about which car should be my first touring, I'm gonna go with the XXX-S graphite....
Besides the obvious good elecs, batts and servo (which I already have) what are some of the must have hops I'm gonna need??
I already have a one way and a full set of springs on the list....anything else...trying to read this whole thread hurts!!
nutfluff is offline   Reply With Quote
Old 12-19-2003, 10:20 PM   #8064
RCGaryK's Avatar
All you need out of the box is shock oil, a one-way, and fron swaybars. Other then that, nothing really.
jitsuguy, I have run this setup and it works, just looks weird. I only tried this when I went to the HRC, when I went back to the normal holes.
HorizonHobby.Com
Old 12-20-2003, 12:55 AM   #8065
JitsuGuy's Avatar
Okay, thanks!
J
Old 12-20-2003, 07:48 AM   #8066
1shnot's Avatar
Default FRONT SOLID AXLE....
Hi guys.......
Losi XXX-S Solid Front Axle - Machined 7075-T6 Aircraft Grade Aluminum, Hardcoat RED, includes IRS187 Losi Pin Cushions, hardware, and axle halves. by IRS
has anyone tried this unit b4?
and what are advantages and disavantages are?
sorry if this questions been asked b4
thanx
1shnot is offline   Reply With Quote
Old 12-20-2003, 09:31 AM   #8067
RCGaryK's Avatar
Less off power steering then a one way or a diff, but more on power then a diff, similar to a one way. But you get 4w braking unlike a one way.
HorizonHobby.Com
Old 12-20-2003, 09:33 AM   #8068
Default Re: FRONT SOLID AXLE....
Originally posted by 1shnot
Hi guys.......
thanx
Spool (solid front axle)
Advantages- on-power steering like that of a one-way, yet still retaining 4 wheel braking...
disadvatages- pushes off-power
requires additional tuning to regain some on-power steering
IRS spool
Advantages- solid aluminum, very durable
Disadvantages- HEAVY, can cause other catistrophic failure
Losi spool pads
Advatages- CHEAP$$$$, same effect as the irs unit
Disadvantages- can cause outdrives to fail in extreme situations
Simply put using the Losi spool pads in the factory diffs are a better option. Yes they can fail, but if they don't fail in these extreme crashes then other more expensive parts like your $25 CVD bones can be taken out easier.......
Old 12-20-2003, 09:49 AM   #8069
1shnot's Avatar
thanx for the reply..........
I didn't know about the losi pads( sounds funny )
please tell me how that works, and if you have any part #'s even better...
only reason i'm thinking about getting a spool is i'm sick of breaking one-way unit. well i haven't broken one in a long long time, but still it's very expensive to replace. (even tho i can replace only right or left side)
again thanx alot
Old 12-20-2003, 09:50 AM   #8070
lem2's Avatar
Default Hello!!
I will be an owner of a XXX-S G+ in a few days!! Be patient with my queries, questions and favors. . . .
Basically from numerous, pages of this thread. It will rock box stock. I think the main hop up to do is change to Ti Screws all around. Is this advisable?
Lem
lem2 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
