Old 12-14-2003, 10:36 PM   #8026
R/C Tech Founder
R/C Tech Charter Subscriber
Battery forward.
That run was with a stock brushless (the new SS4300) so torque at the wheels could have contributed to the problems -- the SS4300 has the same torque as the SS5800 -- but it was still loose, even on-power.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 12-15-2003, 12:58 AM   #8027
Eirik's Avatar
Hello Futureal,
I race on a low bite carpet track all the time and I have found a really good starting set up for tracks like that!
Front End:
Droop: 3mm
Toe: 0deg
Ride Height: 4.5mm
Pivot Support: 2R (Yes, 2R, dremmel down the CVD's)
Camber: 1deg
Caster: 2deg
Roll Center: G+ Low
Shock Position: #3
Shock Piston: 55
Shock Oil: 50wt, Losi
Shock Spring: Purple
Camber Link: #2
Ackerman: Forward and Flipped
Arm Postion: Midle
Spindle Ballstud Washer: 2mm
Front Drive: One Way
Rear End:
Droop: 5.5mm
Toe Inn: 3deg each side
Ride Height: 5mm
Camber: 1deg
Arm Spacing: All the way Back
Camber Link: #6B w/Low Ballstud
Shock Position: #3 Outside
Shock Piston: 55
Pivot Support: 0R, Bottom holes
Roll Center: Low
Standard rear end!
Batteries: Forward
Any aditional weight is placed as much forward as possible!
I have 30gr in my front bumper
Body: Protoform Stratus 1
Tires: Sorex 28R
Insert: Orion/JB Blue (Light Weight, Carpet type) Important!!
For more rear traction/less steering: Rear Camberlink in #1A w/tall ball stud.
For more steering: Ackerman Position in std position and Arm full back.
This setup is extremely easy to drive and very precise!
Could you please try it and get back to me with what you think?
I am sure you will like it!!
Cheers,
Eirik Andreassen
Eirik is offline   Reply With Quote
Old 12-15-2003, 01:06 AM   #8028
highwayman's Avatar
Originally posted by futureal
Battery forward.
Try 2A on the rear camber link, more rear droop and sorex 28's. on your present set-up.
highwayman is offline   Reply With Quote
Old 12-15-2003, 06:50 AM   #8029
STLNLST's Avatar
Trader Rating: 19 (100%+)
futureal- that would be 2 degree per side with the zero degree hubs on. I also feel that the sorex tire's offered me a little more grip than the take off tire's with this set up.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-15-2003, 07:03 AM   #8030
RCGaryK's Avatar
I gave up on my car with a brushless and went back to stock. The problem I had was that I could turn really fast laps, but the car was very inconsistent. The rear end had waaaaaaay too much articulation to it under power. It became a point and shoot kind of thing, you couldn't flow the car. Another thing I did was add a ton of drag brake to the radio, that made a huge difference. I was able to get the car to push really badly on one experiment...I moved the rear shock all the way in on the shock tower, and then it really pushed. I didn't spend a whole lot of time with this setup, but I think if I would have gone down from the purple front springs I could have maybe gotten rid of the push. The things that really helped the car though:
Going to the 1/2 degree rear hubs
going to -100% on the throttle Expo
Putting some drag brake into the car
Moving the rear shocks in on the tower
Now they are running in the unlimited mode, where before we had the limiters on. I think that effected the handling too. As you hit the limiter, there's a sudden weight transfer forward. So that could make a difference too.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-15-2003, 07:48 AM   #8031
Originally posted by THeGame
spaz456 - I'm Brandon Hess.. Are you going to be racing the Januray Jam? Me and Gray are going to make the trip up there..
Hey, ya i will be at the january jam, it kind of sucks that the trackside race is the week before though lol. i think there still may be a decent crowd though. i will look forward to seeing you guys come up.
www.rikter-designs.com
jarrod@rikter-designs.com
Jarrod Langlois is offline   Reply With Quote
Old 12-15-2003, 09:53 AM   #8032
imjonah's Avatar
Default Aluminum Screws
Has anyone had bad luck with those colored anodized aluminum screws. In the process of replacing my steel screws with blue aluminum screws, I have had 2 out of 30 shear off. I was not over tightning either.
Do I just have bad luck or get a bad lot?
Have any of you had simular bad luck with aluminum screws?
imjonah is offline   Reply With Quote
Old 12-15-2003, 09:55 AM   #8033
mcsquish's Avatar
Default Re: xxx-s parts!
Originally posted by babytoy101
why suspension arm of xxx-s are easy to break even you heat not so hard in the track barrier??
When the XXXS first came out I had the same problem. "Bud's" makes a front bumper that is as wide as the body and protects the front end of the car really well. I drilled holes to take the weight out of it and they are fairly cheep. Just my .02
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 12-15-2003, 12:38 PM   #8034
R/C Tech Founder
imjonah: I would avoid aluminum screws for racing, since you tend to take things apart repeatedly and sooner or later they will weaken and strip. Steel or titanium screws have served me best, and still get a bit of that "cool" factor.
Old 12-15-2003, 05:10 PM   #8035
Hey where can you buy on the internet or hobby shop th MHP products t-rex tire sauce?thanks
H8W8IN is offline   Reply With Quote
Old 12-15-2003, 05:39 PM   #8036
RCGaryK's Avatar
HRP distributes MPH Products items, so anyone who deals with them can get his stuff. I know S&N's Trackside hobbies (www.trackside.com) has it, but I don't know if he sells it through the web or not. I'll ask tomorrow when I go racing
HorizonHobby.Com
Old 12-15-2003, 08:30 PM   #8037
JoshR 85's Avatar
HeY!!!
Hey I just got a Graphite+ losi and i'm wondering if anyone would happen to have any good rubber setups for S&N's Trackside??? Thanx in advanced Josh
JoshR 85 is offline   Reply With Quote
Old 12-15-2003, 10:10 PM   #8038
highwayman's Avatar
Get a BRP bumper... will make a big difference.
Old 12-15-2003, 10:21 PM   #8039
highwayman's Avatar
Default Re: Aluminum Screws
... if you're looking for some "cool" factor, try out the stainless steel screws... or better yet, titanium.
aluminum screws will just keep on stripping...
Old 12-15-2003, 11:18 PM   #8040
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
futureal: 1/2 degree rear hubs should help a lot. i actually even use 1 deg rear hubs in low bite tracks and really helps keep the rear end planted. a longer rear camber link (ie. 1A position) should also help. these are some things you may wanna consider trying out. let us know what works out for you.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
