Old 12-11-2003, 09:02 PM   #7996
Hey Kevin can you please post your latest set up for Trackside?
Thanks in advance.
ticitme is offline   Reply With Quote
Old 12-11-2003, 11:29 PM   #7997
Send a message via AIM to ZER01
hey guys, is there a problem with 28mm foams interfering with the shocks in the rear on the g+?
ZER01 is offline   Reply With Quote
Old 12-12-2003, 07:00 AM   #7998
You have to notch the bottom shock eyelet to run the standard Losi hex, or you could use asc. hex and it will clear fine
Old 12-12-2003, 03:10 PM   #7999
THeGame's Avatar
Send a message via AIM to THeGame
Default Back to the Losi..
So how does everone like the XXXs on carpet... ? I did go that far back on the posts but here is a trick to get the drive train alittle bit freeer.. On the Yellow belts Cut off ever other notch on the belt. This will free it up alot...
If someone has already posted this trick sorry for not going back and reading...
-b
THeGame is offline   Reply With Quote
Old 12-12-2003, 07:55 PM   #8000
currently i am using the inside hole on the arm in the rear. and i can run 29 and even 30mm with clearance. but i am guessing you are using the outer hole with these clearance problems?
also about freeing up the drive train. i heard david spashett is cutting every 3rd tooth off from his belt. i asked and i guess he is having no problems with the belt skipping in mod w/foams even. some guys are also using the new black belt and some are also taking teeth off of these belts to free it up further. not sure if it makes a huge difference on the track though....
also i have a question for you guys, has anyone here tryed modifying the rear arms for droop screws into the chassis? i know of some doing this. just wondering if anyone has any feedback? thanks
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 12-12-2003, 08:10 PM   #8001
pro3racer's Avatar
do you mean so the bumper doesn't flex, or so you can try a different pivot, or snading the arm. I don't know what mod yourtalking about. I don't use droop(on carpet). The rear shouldn't be a problem??
pro3racer is offline   Reply With Quote
Old 12-12-2003, 08:14 PM   #8002
Trader Rating: 28 (100%+)
So what your saying is removed every other tooth to free up the drivetrain...did I hear that right?Will this effect acceleration at all?
Anyone have a good carpet/rubber tire setup or at least a starting point?
racenut123 is offline   Reply With Quote
Old 12-12-2003, 08:36 PM   #8003
pro3racer's Avatar
every third tooth. And if the guys didn't have trouble with mod-foam, the hardest on wear class, then any other class should be fine. As long as you keep your belt tight, you should be fine. If you have it loose, you may stop slipping, and reck you other teeth.
Old 12-12-2003, 08:45 PM   #8004
spaz, I'm currently thinking about getting a g+ and was just wondering if 28mm foams were a problem with the outer shock hole in the rear. Thanks for the input.
Old 12-12-2003, 10:25 PM   #8005
THeGame's Avatar
Default FreeDriveTrain..
Guys I'm Sure its ever other tooth. Thats what David told me at Cleveland. And you will notice a deferent's.
Has anyone seen or tried the Losi Mod they were doing to the rear shock tower to give you a new Camber link hole The Man Andrew Gray, a Losi guy came up with it.
I will take a picture of mine and post it..
Old 12-12-2003, 10:27 PM   #8006
THeGame's Avatar
Default proudwinner
There is no problem with 28mm tires in the rear. I have been running the Jaco tires and have had no problems..
Old 12-12-2003, 10:37 PM   #8007
RCGaryK's Avatar
Racenut, try Hodge's on the Losi site from last year's Novak race. It's what I use and it's really really good.
I am working to get graphite bumpers produced. I have to call the guy Monday. He's been working on it for a bit of time now. If they work out, they might get mass produced.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-13-2003, 07:35 PM   #8008
lazyboy's Avatar
Send a message via AIM to lazyboy
Post
how is that gonna differ from them going into the chassis and not the bumber in the rear??? or is it going to be the same?? when you hear back form that guy post a pic of how it turns out, kinda interested on how this will work
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 12-13-2003, 07:45 PM   #8009
thegame- you are probaly right about it being every other tooth. i never talked to david personally about it. now that i think of it i think my buddy did tell me every other tooth.
about the rear camber link mod, i was up in dumas and greys room a few times over the weekend and i checked out the rear tower on mikes car. it looks pretty cool but im not sure how much it is really needed on carpet. it is basically an extra camber link row screwed into the bottom row of holes offset to give an extra inner mount. kind of hard to explain lol.
also another cool thing i saw was the bk hubs which i think others have mentioned...
[email protected]
Old 12-13-2003, 07:48 PM   #8010
pro3racer- sorry didnt clarify, i drilled out a hole in the rear arms just above the edge of the chassis so you can run a long set screw that will hit the chassis. i am only running a small piece of the rear bumper, just enough to seal the rear tunnel, the rest is cut off.
[email protected]
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
