Old 11-24-2003, 02:58 PM   #7876
ND
Are you measuring the shock shaft with the ball cup on the end or without the ball cup?
I just take a Stanley knife and take the top of the screw part of the bumper off so it's flush with the rest of the bumper, if you look at the car from below the hole for the screw is still there and it all looks standard.
Hope this is of help!
ND is offline   Reply With Quote
Old 11-24-2003, 03:09 PM   #7877
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by RC Driver Gary
Sigh, no, I've made more mistakes then that, but I don't want to eat up all of Shane's server space
Tru dat!
Sorry Gary, You know I had to...
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 11-24-2003, 04:05 PM   #7878
RCGaryK's Avatar
Yeah Troy, but I've never been beaten by a TA04 with a Mabuchi in Stock
Proracer If you have the XXX-S GP, the front and rear shock shafts are different lengths.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-24-2003, 04:10 PM   #7879
pro3racer's Avatar
okay, just remembered this, my xxx-s is a old version coversion. So the shock shafts are all the same, and when i took the shocks apart, the rears(or fronts, hehe), had orange pistons/spacer things, and the other had black, whats the difference?, i know that orange is 55, and black is 57?, so what goes in front and back.
pro3racer is offline   Reply With Quote
Old 11-24-2003, 04:44 PM   #7880
I run 56 (Red) in front and 55 (orange) in the rear with 50wt oil. Green front springs, silver rear. And it's a G+, and from time to time I run all the same length shocks depending on what I am experimenting with. But put the 57's up front.
Hope that helps.
NitroJohnnyD is offline   Reply With Quote
Old 11-24-2003, 05:32 PM   #7881
pro3racer's Avatar
would orange in the front, black in the back work, i really don't want to have to run t he store. How do you change the shock lenght, is it just unscrewing the ball cup, and shouldn't it be almost all the way in.
Old 11-24-2003, 05:51 PM   #7882
Trader Rating: 21 (100%+)
Pro3racer-Put the black 57's in the front and the orange 55's in the rear. If you can make it to Road Rage, let me know and I can help you with the car. The shock length will vary depending on your tire size if you don't use the drop screws.
Hopefully Gary will come through on the project and make life easier.
Losi shocks aren't bad once you figure out how to build them. I use to hate them and actually tried HPI shocks when the car first came out. The car never felt like it responded or felt the same as with standard shocks.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 11-24-2003, 05:55 PM   #7883
mainracer's Avatar
Send a message via AIM to mainracer
bigger the hole in rear (54,55,56..)will give you more steering and smaller the hole (56,57,60... ) in front will keep the car flat on the ground !
I think !
mainracer is offline   Reply With Quote
Old 11-24-2003, 05:58 PM   #7884
RCGaryK's Avatar
No Pressure, eh Brian? LOL.
You're going to be at the track tomorrow?
HorizonHobby.Com
Old 11-24-2003, 05:59 PM   #7885
Hixsy's Avatar
Hey guys,
just wondering does anyone here run ceramic bearings in the xxxs? what do you think of them? is the a big effeciency improvement?
thanks
Hixsy is offline   Reply With Quote
Old 11-24-2003, 07:03 PM   #7886
pro3racer's Avatar
brian- i'll be at RR on the sat. race, i only race big races, haha, no just kiddin, i can only make it those distances on weekends. Okay, 57's, orange springs, and probably on brand new purples all around, not trued, because i need them to last, so like 60 mm. Then 55's and black springs in the back, no droop anywhere, i'll get it tweaked, and i like the height around 3.5-4
Old 11-24-2003, 07:28 PM   #7887
hi all,
Seems that all of yea discussing about the shock piston. So whats the difference with all the different shock pistons? Which one is considered to be the best combo piston/shock oil/spring on an asphalt track?
Another thing need to ask you all is the effects of the roll center. What effect would i get with these various combo's. HRC Front & Rear, LRC Front & Rear, HRC Front/LRC Rear & LRC Front/HRC Rear. Just need some general explanation.
lozi is offline   Reply With Quote
Old 11-24-2003, 08:09 PM   #7888
STLNLST's Avatar
Trader Rating: 19 (100%+)
lozi- the all around best piston (IMO) is the 56 (redish) piston. as far as oil I like 40-50wt on asphalt.
I can't really offer you a spring but you can't go wrong with blue fronts and silver rears to start.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-24-2003, 09:14 PM   #7889
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
I'm on an indoor asphalt track and my Losi is hooked up with 40wt oil all around, blue springs in front and red springs in the back. Low-roll centers front and back.
Low-roll center allow the car to roll more in the turn. Also, make sure your front dif is a bit tighter then the back and if the back of your car is still sliding around corners move your back camber links out one position. I also run -1.5 camber all around. 2R block in the front and 0R block in the back. 4mm droop in the back and 2mm in the front. And of course 5mm ride height. My car is STUCK! Give it a try if you're looking for a nice asphalt setup.
J
JitsuGuy is offline   Reply With Quote
Old 11-25-2003, 02:16 PM   #7890
pro3racer's Avatar
hey, i put the shocks back on, and my car sits 10mm up, what did i do wrong, all i did was rebuild them(correctly), and put them on, are there spacers to put on if you don't have droop or something, or am i supposed to put the springs on while the shock is compressed????
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
