Old 11-24-2003, 12:14 PM   #7861
pro3racer's Avatar
if i don't use the droop screws i can't get my car low enough!
pro3racer is offline   Reply With Quote
Old 11-24-2003, 12:23 PM   #7862
ND
If you don't use droop screws you just control the amount of droop using the length of the shocks, so you just gotta make sure they're the same left an' right!
I don't know anyone who does use the droop screws as it goes!
ND is offline   Reply With Quote
Old 11-24-2003, 02:34 PM   #7863
RCGaryK's Avatar
Pro3Racer, you should't be using the droop screws to limit ride height. This can actually put excessive preload on the springs. Come up to Trackside and look at Brian Lutz's car tomorrow night. He's got the setup on his car. I still use the screws, but I am working something....
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 11-24-2003, 02:39 PM   #7864
pro3racer's Avatar
one, i live in stevens point, which means i like never can make it down there. I'm gonna spend another 2 hours wrenching on it tonite, WITHOUT THE DROOP SCREWS, I JUST REALLY WISH I COULD GET MY SHOCKS EVEN!!!!
Old 11-24-2003, 02:45 PM   #7865
RCGaryK's Avatar
Make sure you are using the right shock shafts!!!! The front and rear are different lengths, and that car really screw your tweak up. Don't ask how I know....
If you've run your springs for awhile, measure them to make sure they are still the same length.
HorizonHobby.Com
Old 11-24-2003, 02:47 PM   #7866
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
OK, I'll bite, how do you know?
Jon Kerr is offline   Reply With Quote
Old 11-24-2003, 02:48 PM   #7867
ND
Hi
You can also use the Losi shock matching tool to check that old springs are still same length and tension (and you can match shock lengths). I find it a really good tool when building shocks and comparing them, much better than pushing them together!!!
Just my thoughts!
Old 11-24-2003, 02:50 PM   #7868
RCGaryK's Avatar
You know, say "Don't ask" and someone ALWAYS has to ask...sigh..
OK, I built mine wrong the first time, ok, I admit it, I MADE A MISTAKE! sigh...I feel better now
HorizonHobby.Com
Old 11-24-2003, 02:54 PM   #7869
Jon Kerr's Avatar
I had to ask! That the one mistake you've made? I'm glad you feel better now.
Old 11-24-2003, 02:59 PM   #7870
RCGaryK's Avatar
Sigh, no, I've made more mistakes then that, but I don't want to eat up all of Shane's server space
HorizonHobby.Com
Old 11-24-2003, 03:10 PM   #7871
pro3racer's Avatar
hahaha , yeah, urs and my mistakes could make a thread by itself, haha. I'll rebuild them, good thing i just bought a new bottle of oil. Hey, i have pro3 shocks that are threaded, could they work on a xxx-s, yeah purple would e ugly, but whos cares, it means more if your fast.
Old 11-24-2003, 03:15 PM   #7872
RCGaryK's Avatar
Someone posted something about this on another thread. There's nothing wrong with the kit Losi shocks. If you want to upgrade go with the threaded bodies, Ti Nitride shafts, and low friction o-rings.
HorizonHobby.Com
Old 11-24-2003, 03:31 PM   #7873
PTP Racing's Avatar
either im going to run my foams at a larger diameter or slightly unscrew the shock shafts somewhat so i can get ride hieght and droop back since adding the spacer takes all droop out
what are good droop numbers for stiff carpet setup using the losi gauge i would guess now mine reads 5 or 6 front and rear
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 11-24-2003, 03:38 PM   #7874
ND
I cut the piece of plastic on the bumper where the droop screws go, this allows the shock shaft to be used for droop adjustment without the bumper stopping the wishbone.
You should only set ride height using the collars on the spring, putting more pressure on the spring will give ya more ride height, your ride height shouldn't affect droop............
Old 11-24-2003, 03:50 PM   #7875
pro3racer's Avatar
i took my shocks apart, and are all the shock shaft lengths supposed to be the same, at the front mine are 40 mm, to like 43 mm, in that range. I'm gonna cut that bumper apart, you just cut the little area with the droop, and leave that other screw hole aight.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
