Old 11-20-2003, 03:14 PM   #7801
DickemDown's Avatar
Originally posted by Super Steve
ok guys, i got the car, but i have no idea of how this car's set up works, specially the A arm mount
the rear says 0R and 4R upside down.
Can anyone shed some light?
Pics (notice my bashed up foams)
the arm mount you have has a dual purpose. with 0R rightside up, you have 0 antisquat. with 4R rightside up, you have 4 deg. of antisquat.
DickemDown is offline   Reply With Quote
Old 11-20-2003, 03:19 PM   #7802
audiaudi's Avatar
Send a message via ICQ to audiaudi Send a message via MSN to audiaudi
Originally posted by Trevor
Hi,
Does anyone know where I can get a stainless steel screw kit for the XXXS?
Trevor
Why not titanium?? I have some, PM me... :cheap:
https://www.facebook.com/aldusdesign
Trying very hard to jump back into RC with CRC Xti-wc.
audiaudi is offline   Reply With Quote
Old 11-20-2003, 04:32 PM   #7803
Super Steve's Avatar
Send a message via AIM to Super Steve
Do you guys run the cheapy stock servo saver?
Super Steve is offline   Reply With Quote
Old 11-20-2003, 04:39 PM   #7804
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
If you run the stock one use two of the gold rings it will center better....I use a Kimbrough one and its fine.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-20-2003, 04:49 PM   #7805
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Default easy noob question
k i have been into rc for 7 years soo im not a noob only to on road lol. i just bought a used xxx-s and i need a body what wheel base is it ? and what are some good setups for carpet(ie. springs tires and oil) want to start racing on road. thanks
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 11-20-2003, 05:06 PM   #7806
most electric tcs including the XXX-S are 190mm.
foam works best for tc carpet racing but some places still have a rubber class. check http://www.teamlosi.com/setups/index.htm for a starting setup, but your setup changes with every track.
lukewilson is offline   Reply With Quote
Old 11-20-2003, 05:50 PM   #7807
imjonah's Avatar
Default First time on track with XXX-S
Well after dinking around with this car for 6 weeks, I finally ran it on a real carpet track; this is also my first time running any RC car on a track. My driving naturally was terrible. I am lucky I only broke one part in the suspension.
I finally took the advice of someone here on the forum and trimmed the throttle so the car went about 1/2 speed with the trigger pulled alll the way. With this setup I was actually able to do a lap or two without hitting the wall. I can see, I got a lot of practice ahead of me.
I had just a few questions.
1. If my primary concern is control and I am running on a small carpet track with foam tires and stock motor
any advice you can give me on the setup of the car. Does setup even matter, if I am doing slow laps trying to learn to drive the car? (assuming no settings are way out of stock spec)
2. What adjustments can I make to my controller(besides the one I already made cutting down the top speed); that will make this car easier to drive.
3. Are graphite parts stronger than stock XXX-S parts? When I bust something should replace it with graphite part? I assume Aluminum is less likely to break but more likely to bend and throw off the stearing geometry.
Thanks in advance
imjonah is offline   Reply With Quote
Old 11-20-2003, 06:13 PM   #7808
Send a message via AIM to BlackFlagRacing
don't worry about set-up too much until you can make quick laps without the assistance of a turn marshall. look on losi's site for set ups and go with one that most closely matches your track conditions. I like the andrew gray setup. just set up the car and don't play around with it too much. once you get better at driving, only then will you'll notice the difference in subtle changes.
I don't suggest dailing out throttle on your controller, but instead learn to use throttle control with your finger. this will be cruicle in the future(carring speed) as you become more competitive.
graphite parts are alot more brittle than standard plastic parts(expecially in the winter). just go with the standard parts, cost is less and and durabillity is much higher.
hope this helps. rob
BlackFlagRacing is offline   Reply With Quote
Old 11-20-2003, 06:31 PM   #7809
actually, wheelbases differ and is adjuastable 190mm and 200mm is the width of the cars. most electric sedans being 190mm and nitros being 200mm
Old 11-20-2003, 10:08 PM   #7810
Umm, that is what Luke said, he just didn't mention about Nitros because this is a thread about the XXX-S on the ELECTRIC FORUM........lol and to be specific the XXX-S is actually 188mm wide like most Electric Touring Cars.... They give you 1mm perside to allow for manufacturing imperfection in Wheels/tires...ect....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 11-20-2003, 10:13 PM   #7811
Actually from my experience the Losi Graphite parts are more durable..... Does anyone else feel the same....
Here's why I think so...... When a standard composite part breaks you can see that the plastic is more porus (air pockets in the plastics) which takes away from it's durability... When you break a Graphite part you don't see as much of this..... I broke tons f standard composite parts and have actually broken very few Graphite pieces...
Old 11-20-2003, 10:36 PM   #7812
highwayman's Avatar
Hi,
Trevor
www.rcscrewz.com
highwayman is offline   Reply With Quote
Old 11-20-2003, 10:43 PM   #7813
highwayman's Avatar
i have to agree, although the plastic ones bend or flex a little (in theory absorbing a little bump), i find that graphite parts are less prone to breakage with light taps.
Old 11-20-2003, 11:13 PM   #7814
I sent you a PM.
Trevor is offline   Reply With Quote
Old 11-21-2003, 03:34 PM   #7815
Hi,
Do all of you use the grub screw to adjust the droop or is there a better way of doing this? The plastic bumper's flex is causing the droop to be inconsistent. Any ways to cure this problem is much appreciated.
lozi is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
