Old 11-17-2003, 03:59 PM   #7771
CA$H's son's Avatar
Send a message via AIM to CA$H's son
heres a pretty good setup that most losi guys should love
this is for asphalt but to make it work on carpet just use purple springs all the way around
6 degree hubs front
low roll center front and back
off set rear hubs
green front springs
blue rear springs
front shock 2nd hole in
rear shock 2nd hole in
2 degres front camber
1.5 degree rear camber
purple and plaid tires
stratus 2.0
camber link on old towers;
3rd in front 3rd in rear
60 wt oil
This is a great starting point or setup for jsut about any condition
CA$H's son is offline   Reply With Quote
Old 11-17-2003, 07:15 PM   #7772
Super Steve's Avatar
Send a message via AIM to Super Steve
what do you guys mean by 2R?
also, can anyone explain the affects of the roll center mounts?
Super Steve is offline   Reply With Quote
Old 11-17-2003, 08:24 PM   #7773
Trader Rating: 21 (100%+)
2R is the rear pivot block. People are running it in the front to achieve different handling results. It makes the inner hinge pins run straight rather than at a angle.
A low roll center mount is going to let the car roll more. A high mount will make the car drive flatter and should make it more responsive.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 11-18-2003, 06:22 AM   #7774
mainracer's Avatar
Send a message via AIM to mainracer
brian I think roll center is the oposite ! low roll supose to give less roll and high roll will roll more !
mainracer is offline   Reply With Quote
Old 11-18-2003, 06:27 AM   #7775
mainracer's Avatar
Thumbs up
ģI had this question about roll center ! thanks
Old 11-18-2003, 06:30 AM   #7776
dontfeelcold's Avatar
read the team orion setup guide. it tells you every thing you need know about setting up an rc car.
mainracer, you are taking things to literally
dontfeelcold is offline   Reply With Quote
Old 11-18-2003, 09:35 AM   #7777
Mainracer-A low roll mount means that the hinge pin is moved closer to the chassis. This should allow the car to roll more. I just checked my Losi manual it is the same along with the XXX Main set--up guide.
Thanks to pops
Old 11-18-2003, 10:17 AM   #7778
I was thinking of getting a XXX-S G+ for racing both carpet and concrete/asphalt. Is there anything you would say is a "must have" (low roll centers, one way, or other mods or parts) for racing? I'm new to TC racing so any ideas would help.
Thanks.
wcoyote is offline   Reply With Quote
Old 11-18-2003, 01:39 PM   #7779
TakDrift's Avatar
mainracer, roll centers are relative to the center of gravity/ mass concentration of the particular suspension geometry ( front or rear). Having a low roll center the roll center is of a greater distance to the center of gravity. And having a high roll center the roll center is of closer distance to the center of gravity. Now think of a socket wrench. The longer the wrench the easier it is to undo a bolt. The shorter the wrench the harder it is to undo a bolt. Having a low roll center is like having a long wrench. It's easier for the car to "roll". And having a high roll center is like having a short wrench. It's harder for the car to "roll".
Hope this helps you out. And doesn't confuse you more.
TakDrift is offline   Reply With Quote
Old 11-18-2003, 02:42 PM   #7780
pro3racer's Avatar
well wait, since everyone runs low "rc" on carpet, wouldn't you want no roll on carpet, and lots of roll on ashpalt, since there isn't as much grip on ashaplt, in order to get around a turn, you would need roll.
pro3racer is offline   Reply With Quote
Old 11-18-2003, 07:24 PM   #7781
tooooo much traction on carpet therefore you can do traction rolls with alot of roll
makes sense if you think about it
Old 11-18-2003, 07:55 PM   #7782
pro3racer's Avatar
i hate those, i think i hate the right traction, then i make a quick turn, and i roll, they break arms pretty easy too.
i get the consept
Old 11-18-2003, 08:05 PM   #7783
PTP Racing's Avatar
wcoyote i just purchased the xxx-s g+ to race indoor carpet and all you need is foam tires stiff springs pinions and electrics
i built mine changed the shocks a little 55wt front 50 rear purple stiff springs front and rear and its great
already guys are asking me what ive done to get it to handle so well and i cant tell them because honestly i dont know i tell them nothing i just built it and drove it
i plan on buying as few hop-ups as possible because most of the stuff out there just adds weight
oh i guess one thing is the brp front bumper its the only thing ive added and may well be the only must have hopup
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 11-18-2003, 10:12 PM   #7784
The car just plain handles. The suspension is right on the Losi and everything works together on it. It rotates hard and carries awesome corner speed. I have driven most cars out there and I think that it is the best handling car out there with the limited amount of time I had with it.
I set-up my car to roll with foam tires and it doesn't need to be as responsive. It would bite hard and traction roll or be up on 2 wheels in the corners with the higher mounts.
Thanks to pops
Old 11-18-2003, 10:15 PM   #7785
highwayman's Avatar
Thanks.
out of the box, probably, just harder oil and springs, and tires or foams, are all you need to get the G+ dialed in. No real "must-have yet"
highwayman is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
