Old 11-15-2003, 09:56 PM   #7756
Trader Rating: 21 (100%+)
The G+ comes with a yellow belt. The old standard car use to come with a blue belt. Not sure if they still make the standard car though?
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 11-15-2003, 11:07 PM   #7757
Mercury Racer's Avatar
Ran the 2R in front, it definitely gave more exit steering, unfortuantely, i wasnt able to take advantage of the extra steering, it gave too much rear rotation for me, on powering out.
maybe on a really high bite track this mod would be good.
Mercury Racer is offline   Reply With Quote
Old 11-15-2003, 11:56 PM   #7758
Send a message via Yahoo to Doug Gaut
Mercury Racer, I felt the same thing last weekend when I tried it but I put stiffer rear springs on and it helped a ton with the extra rotation on exit.
Doug Gaut is offline   Reply With Quote
Old 11-16-2003, 12:49 AM   #7759
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Not in the kit form, the standard car is now the RTR.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 11-16-2003, 08:20 PM   #7760
highwayman's Avatar
i tried the 2R in front during our race last saturday, it was pretty good, i could carry more corner speed, but it was too twitchy coming out in my opinion, it was on the edge, so to speak.
DOUG GAUT:
what springs did you use before and after?
highwayman is offline   Reply With Quote
Old 11-16-2003, 08:54 PM   #7761
The 2R in the front should give it more exit steering and also make it change directions quicker. It does but the car on edge, but if you can drive it, it is usually faster. I have only run this is stock though. Have a feeling it will be to much in mod.
Thanks to pops
Old 11-16-2003, 08:58 PM   #7762
highwayman's Avatar
ah ok... maybe that's why, we were running mod...
Old 11-16-2003, 09:06 PM   #7763
Trader Rating: 17 (100%+)
Were you guys running the 2R in the front with the losi low roll center (medium) or the matt francis low roll centers?
429racer is offline   Reply With Quote
Old 11-16-2003, 09:24 PM   #7764
highwayman's Avatar
losi low roll center.
Old 11-17-2003, 01:14 AM   #7765
Highwayman, I was using black springs to begin with but switched to white ones and that stabilized the car. All I have are TRC 26mm tires so I am sure that is the reason it did not work with the black springs.
Old 11-17-2003, 05:53 AM   #7766
pro3racer's Avatar
so the 2r pivots are better in stock. Would this mod still work with the old style front bumper, i have both, but don't want to wreck my new one because it may come back and haunt me.
pro3racer is offline   Reply With Quote
Old 11-17-2003, 10:01 AM   #7767
highwayman's Avatar
pro3racer:
haven't tried it on stock, i ran rubber tires with this modification, and with a mod motor, all i can say is that its a good mod to try, but may not be for everyone.
i dont think their's a difference in the old and new bumper except that the G+ has a more ridgid bumper than the standard kit, so removing material from the bumper (where you put in the droop screw) shouldn't matter, if you dont use the droop screws anyway.
Old 11-17-2003, 04:17 PM   #7768
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
wannabe....I ran the steel diff in the front of the car this weeked and it did add a little exit steering and the car seems to have more on power steering aswell. The turn in stayed the same if not just a touch more. If you got the parts try it out and see, its just one more thing to play with.
The G+ and the standard kit bumpers are the same....you need to get the extra ridged one seperatly.....and even that one is still too soft for the stiffer springs like when using foam tires. but with rubber tires I use the droop scews with out any problem.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-17-2003, 04:44 PM   #7769
wannabee's Avatar
Cool, thanks I ran this weekend and forgot to buy the needed parts, coulda used the extra steering for the tight layout at Ultra!
Thanks a lot for the reply...
Kevin
wannabee is offline   Reply With Quote
Old 11-17-2003, 04:47 PM   #7770
wannabee's Avatar
Originally posted by highwayman
pro3racer:
No diffrence, just the rigid is harder to cut!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
