Old 11-12-2003, 11:41 AM   #7711
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Steering Hub Bearings and Carpet fuzz problem
Originally posted by TakDrift
Anybody have problems with carpet fuzz getting into the steering hub bearings? Any tips on avoiding or eliminating the carpet fuzz from getting into the bearings? Thanks.
Get some Acer sealed bearings, that should keep the fuzz out pretty well... Or just spray them out with motor spray often, and dont use oil...
Old 11-12-2003, 11:57 AM   #7712
TakDrift's Avatar
Randman, is the Acer bearings metal shielded or teflon shielded? Thanks.
TakDrift is offline   Reply With Quote
Old 11-12-2003, 11:59 AM   #7713
They have a special shield that I have no idea how to spell, it's almost like a perfect molded plastic shield, really good tolerances...
Old 11-12-2003, 12:07 PM   #7714
TakDrift's Avatar
Thanks, Randman. I have to buy some of those. I cleaned my front hub bearings recently and they were clogged with carpet fuzz. I finally just took out the metal shield and cleaned it out. I should've done it before last weekends big two day race here in WA. I could've gained a few tenths. Thanks again for the tips.
Old 11-12-2003, 02:06 PM   #7715
Default Re: Re: Steering Hub Bearings and Carpet fuzz problem
are you mad.
the bearing needs some oil and i use the actull oil they use.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 11-13-2003, 12:29 AM   #7716
TakDrift's Avatar
Default Re: Re: Re: Steering Hub Bearings and Carpet fuzz problem
Originally posted by trf racer
are you mad.
trf racer, randman is right on the money. The bearings spins better without the friction the oil is causing. The oil has to be super light to not cause a lot of friction but will still cause friction no matter how light.
Old 11-13-2003, 06:29 AM   #7717
Super Steve's Avatar
Send a message via AIM to Super Steve
also, oil will attract even more carpet fuzz
Super Steve is offline   Reply With Quote
Old 11-13-2003, 09:09 AM   #7718
highwayman's Avatar
KEVIN K:
if i use the 2r in front... aside from removing material from the front bumper, (where you put the droop screw) do i also have to take out material from elsewhere in the bumper?
i notice that the hinge pins might hit the area where you screw in the bumper and the chassis...
thanks
jason
highwayman is offline   Reply With Quote
Old 11-13-2003, 10:01 AM   #7719
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Highway....No I did not have to remove any more material from the bumper...when I cut the droop screws off I just cut the bumper straight where it goes out for the droop screws...do you follow what Im saying? I sill use the screw holes to hold the bumper in place on the chassis....there is no clearance problems there. Hope this helps.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-13-2003, 10:15 AM   #7720
wannabee's Avatar
I just did this mod on my car and it is very simple, just cut the tab off that houses the set screw for droop...
KevinK,
Have you ran the metal outdrives? If so what did it do for you?
Thanks,
Kevin
wannabee is offline   Reply With Quote
Old 11-13-2003, 10:16 AM   #7721
highwayman's Avatar
KEVIN K:
thanks... helps a lot.
Old 11-13-2003, 10:18 AM   #7722
highwayman's Avatar
cool. thanks...
when you did this mod... how was it?
Old 11-13-2003, 04:34 PM   #7723
Kevin K's Avatar
wannabe....I have run them in the front with rubber tires but have yet to really try them with Foam tires....maybe this weekend or next. Once I do I will let you know how it works out. With rubber tires it gave more on power steering so I would think it would do the same but Im not sure that I need that with foams, but its worth a try.
Old 11-13-2003, 06:02 PM   #7724
wannabee's Avatar
Yea I might try it this weekend...Thanks for the reply...
Kevin
Old 11-13-2003, 10:53 PM   #7725
There is usually a trade-off, did you loose any off-power steering??
BTW: I am running rubbers now.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
