Old 11-07-2003, 10:57 PM   #7681
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by JitsuGuy
Has anyone bought another set of hubs to rule out whether they're the problem or not?
Thanks,
J
I have a new set of blocks in all degree's.....the problem is still there. The only other thing that I can think of is that the problem is in the chassis somewhere. The chassis isn't tweaked but maybe it's molding wrong somewhere on the right side in the rear.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-08-2003, 12:51 AM   #7682
Default real quick.
Hey does anyone know where i can get the complete screw kit in blue for my G+?
tricklosi is offline   Reply With Quote
Old 11-08-2003, 02:19 AM   #7683
BG
BG's Avatar
I believe the problem lies in the roll centre blocks or mounts. If they are not in line properly when fastened it will change the angle of toe in. The hub carriers and the rear arm tolerence doesnt change.
Have a look at that and see if that fixes it.
Cheers Bill
BG is offline   Reply With Quote
Old 11-08-2003, 08:21 AM   #7684
Rob Mincey's Avatar
Default Re: real quick.
Trinity sells blue aluminum screws, but I don't know that they offer them in a "kit" form.
Rob
Rob Mincey is offline   Reply With Quote
Old 11-08-2003, 09:27 AM   #7685
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Stormer hobbies sells the Trinity AL screw kit.
Jon Kerr is offline   Reply With Quote
Old 11-08-2003, 09:31 AM   #7686
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Check on eBay as well, they arent Trinity screws, but they propably cost less..
Old 11-08-2003, 09:32 AM   #7687
Jon Kerr's Avatar
Randy, you have the Yok built yet?
Old 11-08-2003, 09:36 AM   #7688
Nope, all of the aluminum stuff is off bieng anodized red
Old 11-08-2003, 10:21 AM   #7689
Jon Kerr's Avatar
Nice
Old 11-08-2003, 10:43 AM   #7690
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The blue screw kit is available from Trinity. It is part number TK5075.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-08-2003, 10:50 AM   #7691
Nice
Yeah, I had the aluminum polished, then anodized red, so it'll go nicely with all of my "chrome" titanium
Old 11-08-2003, 09:33 PM   #7692
Jon Kerr's Avatar
Send me some pics when you get it done.
Old 11-09-2003, 02:30 PM   #7693
PTP Racing's Avatar
i just got a xxx-s g+ and i need some setup advice for carpet
i havent been racing onroad any for a while so i dont remember much
what tires are recommended we run foams and i was told plaid fronts and magenta rears trc tires but i would rather run something other than trc tires if i can speedmind tires are perferable because they are cheaper and easier to get
and what can i do to stop the shocks from leaking it seems the front shocks are nearly empty after a little more than a weeks time or is it because i need to rebuild them weekly
Paycheck to Paycheck Racing
Jason Miller
PTP Racing is offline   Reply With Quote
Old 11-09-2003, 02:35 PM   #7694
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
PTP - You are going to want to rebuild your front shocks if they constantly leak. Take the shock completely apart, and take the cartridge apart. Inside there are two O-rings, and the plastic spacer. Replace the two O-rings, and make sure the inside of the cartridge is cleaned out with motor spray.
When you install the new O-rings, if you have it, put some AE Green Slime on them. If you don't, a drop of shock oil will work too, just so that the o-rings aren't dry when you push the shock shaft back through them.
Also make sure the threads on your cartridge are in good shape, and that you tighten it well when you rebuild the shocks. They need to be more than just finger-tight.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 11-09-2003, 03:36 PM   #7695
PTP Racing's Avatar
the shocks are brand new and ive had to rebulid them once already
i put a drop of oil on the shafts when i was building them like it said to do in the instructions
should i tighten the cartridges with a wrench or something
i will replace the cartridges if thats what i need to do but they are really new so i dont think they are the problem
Jason Miller
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
