Old 11-05-2003, 08:14 PM   #7651
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Los1Fan, cool, I'll go take a gander at it right now cause I do have the low-roll center setup.
Thanks!
Jits
JitsuGuy is offline   Reply With Quote
Old 11-05-2003, 08:21 PM   #7652
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Super steve....the last few sets of the graphite conversion that I have seen did have all the NEW UPDATED parts in them....as long as the package you get is new and not a few months old it should be no problem getting all the new stuff in one bag.
Jitsuguy.....I have sorta the same problem on my car to get 2 degs of total rear toe in the rear I need to run a right 1/2deg hub normal on the right so it equals 2 deg per side. So on the left I have a 0 deg block and on the right I have a 1/2 deg block just so they have the same amount total. If I did not use that block on the right I would have 2deg on the left and 1 1/2 on the right using 0deg blocks. Its strange but a couple of the cars that I have seen here seem to have the same problem.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 11-05-2003, 08:29 PM   #7653
JitsuGuy's Avatar
Well, that sucks... So, is it a problem with the hub carrier? I would think so cause I tried the hub on both sides and it does the same thing just switched... So, should I just get another set of hub carriers? That would suck, but oh well, you gotta do what you gotta do I guess. But I have checked and it definitely isn't an optical illusion.
Thanks,
Jits
Old 11-05-2003, 08:29 PM   #7654
odd but intresting..i can't say i've seen this problem before for i'm the only racer in my club that has been racing with the xxx-s for so long...most of the guys i know that races xxx-s is still begining so i dun think they care about or notice the difference yet...anyways...Kevin K : are you using the low roll center blocks are the other racers using the low roll center block as well...if so..i'm guessing these little buggers are not well made..
Los1Fan is offline   Reply With Quote
Old 11-05-2003, 08:31 PM   #7655
RBLove's Avatar
Trader Rating: 71 (100%+)
Kevin K,
I remember seeing some of Hodge's set up's that had that as well (rear toe issue)...... You guys are doing the right thing by checking. Not sure if this is an on going issue or what, but at least you have the fix................................
RBLove is offline   Reply With Quote
Old 11-05-2003, 08:32 PM   #7656
Thanks,
Jits
hhmm...maybe i should check my car to make sure...i'm pretty sure my car is even 'cause i havent touched it since i re-set and clean my chassis before i started racing nitro....
i have a question..its not really an electric car question but it's still xxx-s chassis...does anyone know if losi is comming out with a nitro version of xxx-s...
Old 11-05-2003, 08:35 PM   #7657
JitsuGuy's Avatar
Well, I'm not so sure I have a fix. I'm looking for a fix still... I did check my low roll center blocks and tried to adjust them, but the problem is definitely still there. I'm wanting to run the 1 degree switched setup (1 degree hub carriers on opposite sides). I'm thinking I'll need to get another set of carriers cause I didn't notice this problem with the low roll setup and the 1/2 degree setup. Things that make you go "hmmmmmmmmmmmmm"
Jits
Old 11-05-2003, 08:50 PM   #7658
Kevin K's Avatar
Losi fan....yeah I have tried all mounts and rear blocks and it seems to be a problem on the right side. But not all cars are like that its strange.
Old 11-05-2003, 08:53 PM   #7659
JitsuGuy's Avatar
Well, on the bright side, the next time I lose I can blame it on the car.
J
Old 11-05-2003, 08:55 PM   #7660
J
lol on that....kevin k...chassis mount holes perhaps??...
Old 11-05-2003, 09:02 PM   #7661
Kevin K's Avatar
Jitsu....if you need a good excuse don't for get to blame Newton and all his psychics.
maybe the chassis holes??? that could be.
Old 11-05-2003, 09:08 PM   #7662
theres really a lot of possibilities here guys...tweaked chassis...chassis holes not properly aligned...blocks tweaked...arms tweaked...hub carriers tweaked...or maybe your setup blocks (i.e. hudy setup blocks, integy setup blocks) are tweaked ...or your eyes playing trick on you ....or maybe your arm arent travelling evenly with the other side thus changing the toes....
Old 11-05-2003, 09:13 PM   #7663
JitsuGuy's Avatar
Well, either way, I can tell you it sucks... A lot of money on this car, and I can't get one tire to face the right direction... Must be a glitch in the matrix.
Jits
Old 11-06-2003, 05:26 AM   #7664
Super Steve's Avatar
Send a message via AIM to Super Steve
hahaha good one...
everyone is refering to matrix these days
Super Steve is offline   Reply With Quote
Old 11-06-2003, 06:29 AM   #7665
STLNLST's Avatar
Trader Rating: 19 (100%+)
the rear toe issue is strange but like others have posted.....not all cars have this problem. Mine does and I adjust my toe with different blocks on the right side.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
