Old 11-03-2003, 12:36 PM   #7621
Mercury Racer's Avatar
EDDIE ROSSI:
thanks... makes sense now... when you change your effectice droop, do you do so for both the front and rear?
JITSU GUY:
The new G+ has a diiferent set of rear A arms (aside from the the material) it has two mounting holes for the rear hubs.
they designed the inner holes to make the losi's rear rotate more for very tight tracks.
Mercury Racer is offline   Reply With Quote
Old 11-03-2003, 01:07 PM   #7622
Mercury Racer,
if I need I change both front and rear or only one side, depends on what change I want in car handling. Most of the times, if the car is already well balanced, I will reduce or increase amount of effective droop same on both ends.
EddiRossi.
EddiRossi is offline   Reply With Quote
Old 11-03-2003, 01:18 PM   #7623
do you adjust the droop for traction?
Old 11-03-2003, 03:36 PM   #7624
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Anyone see the XXX-S on the Listerine Citrus commercial?
Dude was sitting at table working on it when wife comes home with some Listerine.
ChristopherKee is offline   Reply With Quote
Old 11-03-2003, 03:50 PM   #7625
I mainly use it to increase or reduce the weight transfer on front and rear end of the car. Example, immediately before a sharp corner, power off, the weight of the car is transferred to the front end. Increasing rear effective droop, we increase the amount of weight transfer to the front and so the off-power steering.
Exiting the corner, power on, the weight is transferred to the rear end. Increasing front effective droop, we increase weight transfer to the rear and so we reduce on-power oversteer.
But these are only my experiences, maybe I am wrong!
EddiRossi.
Old 11-03-2003, 05:26 PM   #7626
wannabee's Avatar
Is anyone running lightend chassis or milled? Sorry if there is a topic on this already I looked and couldn't find it..
Thanks,
Kevin
wannabee is offline   Reply With Quote
Old 11-03-2003, 10:18 PM   #7627
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Default Adjusting droop
Now that I have the new G+ chassis and low roll center setup, I found that my droop screws are too dang long. Can I just adjust droop with the ball cup attachments on the end of the shock shaft? Such as unscrewing them to decrease droop and screwing them in to increase droop? Or is this not a good way to set droop?
Thanks,
J
Oh yeah and Mercury Racer, thanks for your insight. I was wondering what all this off-set talk was about.. But yeah, that makes sense, by shortening the width some the car should rotate quicker/better on tight tracks.
JitsuGuy is offline   Reply With Quote
Old 11-03-2003, 10:25 PM   #7628
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
jitsuguy- to adjust droop by undoing shock ends, you will need to add limiters inside the shock itself. This is actually the method that the Facotry Losi drivers use, they say it's more consistent.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 11-03-2003, 10:54 PM   #7629
JitsuGuy's Avatar
What kind of limiters?
Thanks!
J
Old 11-03-2003, 10:56 PM   #7630
The black ones that look like your a arm spacers. I do not know how much to use, I don't run that car, but i know that's how they do it.
Old 11-03-2003, 10:57 PM   #7631
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Using limiters and adjusting the length with the shock ends is far more consistant. If you look at the droop screws when they're tightend down, the bumper flexes a ton and will give inconsistant settings as well as change while you're driving.
Jon Kerr is offline   Reply With Quote
Old 11-03-2003, 10:59 PM   #7632
Jon Kerr's Avatar
Use thin metal shims to fine tune the droop setting. Use the thick black ones for large adjustments and use thin shims to fine tune it.
Old 11-04-2003, 08:29 AM   #7633
JitsuGuy's Avatar
Where on the shock do I place the limiters?
Thanks!
J
Old 11-04-2003, 09:26 AM   #7634
Jon Kerr's Avatar
Between the piston and the cartridge.
Old 11-05-2003, 06:29 AM   #7635
Super Steve's Avatar
Send a message via AIM to Super Steve
Hello XXXS guys!
I should be getting the losi sedan from phatkat in less then two weeks!~
Is there any reccomended hop ups that I should first get before the other goodies?
Thanks, let me know!
Super Steve is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
