Losi XXX-S
#7607
rollout
one question i've always been wondering. What is rollout, and how do you find your number. what is a averagely good number, or is there.
#7608
Mercury Racer,
commonly the droop is the amount of wheel downtravel between the ride height and the moment the wheel itself leaves the ground when the car lifts. For me this is the effective (or real)
droop.
When we use the droop gauge and we read, example, 2 in the front, this is only a number as reference. The effective droop is affected by ride height and tire diameter.
Anyway, for a given tyre, it' s a very useful way of measuring!
EddiRossi.
droop.
EddiRossi.
#7609
Does the new G+ have different A arms? Also, can someone explain or point to a place that explains off set? Also, what is the 4 degree spindle set?
Thanks!
J
Thanks!
J
#7611
anybody on rollout, "above"
#7613
thanx, does 32 sound good for a tight track.
#7614
Originally posted by EddiRossi
Mercury Racer,
droop.
EddiRossi.
Mercury Racer,
droop.
EddiRossi.
i'm confuse on this...so how exactly do you set your droop, ride height etc. properly or effectively...from what i've read (which i'm still confuse about) is that there's a certain droop for a certain ride height and vice versa...is this correct or did i just mis-understood it?
#7615
Most all racers set their ride height to 5mm... Beyond that it's up to the racer and the setup they're running for droop. For example everyone that I know of at my track running the Losi run a 5mm ride height, but some run 5mm droop in the rear and 3 in the front, while others run 4 in the rear and 2 in the front. Also, when they run different droop, that's the not the only thing that's different. Usually they have a different shock setup etc... and that droop setting works best for that car setup and their driving style.
J
J
#7616
Yep, for a stock motor. and short, tight track
#7617
droop.
EddiRossi.
droop.
EddiRossi.
So how do you measure effective droop? what do you use to measure this?
#7618
highwayman,
suppose that ride height of the car is 5mm.
First I lift front end until wheels begin to leave the ground and with the ride height gauge I read 8mm.: this means real droop at front is 8 - 5 = 3mm. Then I do the same for rear end.
I hope this will clarify my previous post!
EddiRossi.
EddiRossi.
#7619
highwayman,
EddiRossi.
highwayman,
EddiRossi.
Very much so... thanks.
i guess by reducing the effective droop to zero, it had a similar effect as with a sway bar.
#7620
highwayman,
EddiRossi.
highwayman,
EddiRossi.
