Old 10-30-2003, 01:17 AM   #7561
highwayman's Avatar
Originally posted by TSR6
Advantage: You don't have to pay bucko-bucks for the aluminum low roll center blocks ( Trinity, Speedtech), which are lower than the "losi low" ( basicly mid roll center )
do you have the MF rear alum roll center? is it lower then the losi low roll center?
as mentioned by kevin k, the speedtech ones are a bit higher than the losi ones.
highwayman is offline   Reply With Quote
Old 10-30-2003, 07:13 AM   #7562
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
It was always my understanding that the speedtech & trinity parts were the same, but that the speedtech included a shim.
When the GP+ came out, everyone was calling the losi parts a "mid roll center" aka "Losi Low"
I know for sure that my parts, which i ground down myself from high roll center parts, are lower than the losi Low, and always assumed they were the same as Trinity. I've never held them side to side, but they appear the same when mounted on the car.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-30-2003, 07:25 AM   #7563
J.Filipow's Avatar
Trader Rating: 14 (100%+)
Gray- 'sup!? NWA 4 life, homie! ahhahahha....GIFF forever!
KevinK- Sorry to flood you with another Q, since this thread has really blown up the past 24 hours...2R (as in, the 2 REAR) pivot support in the front, right?
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
Reedy / RC America/XRayUSA / Hudy / Avid / JConcepts / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 10-30-2003, 07:54 AM   #7564
TLRacing
Todd Hodge's Avatar
Andrew-Nice location.....On your couch....that is a good one.
Kevin-Why no Indoor Champs for you this year??
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 10-30-2003, 08:07 AM   #7565
tufferwilde's Avatar
TSR6 -
You are 100% correct that the parts from Speedtech and the MF parts are the same, they are both shaved .150" from the original blocks... The speedtech parts also included the .150" shim to take them back to the original height as well.
Regarding Cleveland - I am going to have to agree with Kevin K - We had to resort to drinking heavily throughout the weekend... then again - I guess it wasn't so bad.
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 10-30-2003, 10:46 AM   #7566
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
The Speed Tech rear roll center mounts that I had were a little taller then the the stock losi low roll center....this is with out that extra spacer....it wasnt much but they were taller. This could have been my set who knows but when I measured them this is what I found.
J fillipow....yes I am using the 2R block in the front.
Todd....No indoor champs this year b/c the last two times I went I did not enjoy the race or myself and sence I have to pay for all this out of my pocket I deceided to go to the Birds instead.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-30-2003, 04:33 PM   #7567
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Beautiful XXX-S for sale eBay item #3153035534
Old 10-30-2003, 05:38 PM   #7568
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Randman is telling the tructh. I just checked the car out on Ebay and it is nice. If I was getting another Losi I would be calling Randman on this one.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 10-30-2003, 07:44 PM   #7569
Trader Rating: 46 (100%+)
For a stock XXX-S with a stock motor, what pinion gear should I be running (tooth/pitch)?
IntegraCL is offline   Reply With Quote
Old 10-30-2003, 07:52 PM   #7570
Tag
Tag's Avatar
Trader Rating: 30 (100%+)
for the stock motor, you want to gear around 6.8-7.2 depending on the track you will be running. 64P 128 spur w/ 33 pinion will yield about 7.1 final, try this first and make adjustment from there..
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 10-30-2003, 07:54 PM   #7571
Thanks! I will give that a try and let you know how it works out.
Old 10-30-2003, 08:23 PM   #7572
hey guys...i just bought my second monster....i had a bad experience with the first one but that was my mistake not knowing how to gear it...now i bought another one 'cause i've seen a lot of racers using it and it's quite fast...anyways...i slap it in my xxx-s and geared it 20 pinion and 90 spur..thats around 8.23 final ratio..and i still can't get the car to run as i want it....track is concrete 25% open 75% tight track....it's a big track....i can't tell how big but its big....anyways.....whats the best final drive for this motor or at least ballpark to start with....i don't wanna burn another motor again...thx a bunch
Los1Fan is offline   Reply With Quote
Old 10-30-2003, 08:39 PM   #7573
I was running on a fairly big track sunday with a monster motor, geared at around 6.5 (36/128)
Old 10-30-2003, 08:43 PM   #7574
if i gear it that low..i'll burn the motor...i didn't finish any heat because i didnt wnt the motor to smoke...still can't figure out whats wrong...i felt the drivetrain and its free as it can be...i changed motors for the main and it ran fine....although somebody clipped me and my car did a cartwheel and broke my shock shaft...maybe i'll try gearing it higher..thnx
Old 10-30-2003, 08:48 PM   #7575
Well 8.2 seems MUCH too low for a large track. When I do run stock, I true the comm every 2 runs, and the car is geared accordingly, if you want more life, go with a 6.9-7.1 final drive.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
