Old 10-29-2003, 07:09 AM   #7531
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
there aer two ways to shave you rear roll blocks,
1, you can have them milled
2, get them close with your dremel, then take some sandpaper, put is on a piece of glass(or and flat surface) and sand them down......that is how i did it.....
Matt M. is offline   Reply With Quote
Old 10-29-2003, 07:17 AM   #7532
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
J.Filipow: I'm with ya there also....I'm going try it...
I'm running a slighty modified version of the Paul L. '03 Snowbords set-up.
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-29-2003, 09:36 AM   #7533
highwayman's Avatar
any advantages?
what's the maximum that i can or should shave off?
highwayman is offline   Reply With Quote
Old 10-29-2003, 10:38 AM   #7534
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by highwayman
any advantages?
Advantage: You don't have to pay bucko-bucks for the aluminum low roll center blocks ( Trinity, Speedtech), which are lower than the "losi low" ( basicly mid roll center )
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-29-2003, 12:11 PM   #7535
akrcracer's Avatar
.Can anyone post a tight carpet track set up?. The one I'm using is close Paul L on the losi site. But it doesn't seem to have enough steering for me...
akrcracer is offline   Reply With Quote
Old 10-29-2003, 12:21 PM   #7536
xxxssportracer's Avatar
Send a message via AIM to xxxssportracer Send a message via Yahoo to xxxssportracer
Default tires
what kind of tires are you running, and what weight shock oil are you using in your xxx-s?-Dave
xxxssportracer is offline   Reply With Quote
Old 10-29-2003, 12:24 PM   #7537
akrcracer's Avatar
I'm running TRC purple fronts & Tan rears. And 90wt oil in all shocks
Old 10-29-2003, 01:03 PM   #7538
Tres's Avatar
akrcracer: are you runing stock or mod?
I ran it in stock on a tight track, it had WAY to much steering.
I did run it per the set-up sheet with the light oil & large pistons.
Tre's
www.tnt-fx.com
Old 10-29-2003, 01:08 PM   #7539
akrcracer's Avatar
Spec 19 class. We call it super stock here in AK. I always have plenty of steering... I had good on power steering. It just lacked some off power steering..
Old 10-29-2003, 04:20 PM   #7540
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
any advantages?
The advantage is that it makes the car react faster and rotate a little better in the corners.
The max you can shave off is real close to .080" off of a Losi Low RC block.....if you go lower the rear arm will rub the chassis.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-29-2003, 04:32 PM   #7541
R/C Tech Founder
Kevin: Thanks for the setup posts. You going to Cleveland?
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 10-29-2003, 04:46 PM   #7542
Kevin K's Avatar
Shane.....no biggie. And nope I will not be making it out to Cleveland....that race leaves alot to be desired in my book.
Old 10-29-2003, 05:23 PM   #7543
R/C Tech Founder
I wonder if I will feel the same as you after my first trip...
Old 10-29-2003, 05:39 PM   #7544
are the speedtech and trinity low roll blocks .080 lower than the low losi ones? what the part # for the trinity ones?
lukewilson is offline   Reply With Quote
Old 10-29-2003, 05:43 PM   #7545
Kevin K's Avatar
The first time I went it was ok but it still sucks b/c the area that your in has NOTHING is open over the thanksgiving weekend and everything closes at like 8pm. But you do have Denny's across the street if you want the WORST food ever semi-cooked. And forget trying to order a Pizza or something thats near impossible....if your going bring food with you or make sure you venture outside before it gets dark while some places will still be open. And bring parts the hobby shop seems to have nothing you would need in it.....but you do get to see some of the best racing around. Ohhh and dont forget the 35 and 45 yearold crack whores that frequent the hotel Bar..... But its the BEST RACE EVER
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
