Losi XXX-S
#7516
Wow, thanks! I'm going to give that setup a try!
J
J
#7517
Originally posted by dpaton
Can you quanitfy "quite hot" and "cools down" for us? It'll help a lot...
If it was a real car, I'd say use some higher temp (harder) tires. It sounds like the heat is making them a little greasy, and as it cools off they come back into their traction range. You could also try playing with traction compound.
My $0.02.
-dave
My $0.02.
-dave
hot around 50 to 60 degrees centigrade... cool is 30 to 36 degrees centigrade.
compound is out of the question. doesnt work, the track is a bit dusty.
#7518
If it were clean, I'd say that the hot end would be perfect for CS27 type tires. The heat will make them nice and sticky. On the 'colld' end, something a compound or two softer (CS22s if you're a Take-Off guy like me) should be OK.
-dave
#7519
Anyone that runs foams on carpet should give Kevin's setup a try. His car looked the best out of all the cars in stock. I have also seen Brian J's car run in mod and would have to say that it is one of the best mod Losi cars I have seen. These guys have been doing their homework and it is really starting to show. Awesome run this weekwend Kevin.
#7521
Trader Rating: 32 (100%+)
J Filipow.....
The battery is forward my bad....I have never run my pack in the rear of the car and cant think of anyone who has.
Rear hub position? Im not sure what you mean. I posted that I had 0 deg offset hubs so that would mean its in the inside "offset" holes on the arm and I used a Ti Ball stud on the outside hole of the hub. If there is more that you are looking for Im not sure I follow what your looking for.
No Shock limiting....I do not use the droop screws everything is set off of shock length. With the Roll center blocks used you will need to cut the droop screw "holders" off of the bumpers for clearance.
Yes I know that the Losi LOW is a mid roll center but I was using Losi parts and its called a Losi Low roll center so I did not want to confuse anyone. Also I should have added that the REAR roll center is a Losi Low cut another .080 off of the bottom to further lower the Roll center.
And Next time you see Brian Busse he should have this setup on his car as well....so if you need anything more give him a shout....hes got info too.
If there is anything more you need ask away
#7522
kevin - are you coming to trackside this sunday?
#7523
Luke....I highly doubt I will be up there for another couple weeks or more.
#7525
Tres.....that looks good thanks.....and thanks again for the face plate.
#7526
Dusty track? Ugh...what kind of tries are you using? I can't imagine slicks work well...
-dave
-dave
slicks work... sorex 40 to be exact with med inserts....
the sorex 40's work best late afternoon till nightime, but during the day, they become quite slippery.
#7527
KEVIN K:
how did you shave the rear roll center?
would you recommend this modification even if we're running on asphalt? what are its benfits?
#7528
XXXS Axles
Hi Guys
I have a question about XXXS Axles. I bought a car from a friend and the threaded part the front CVD's is shorter than the rear threaded part. once you have the hex and wheel on the threaded part is only 1/2 way through the nut. Any idea's on this?
Also I have been having a problem with items I am ordering being packaged wrong? I am on my 3rd itme now that has had packaging issues. Is this a problem or just a run of bad luck on my part?
Here is what I have found.
1. Graphite conversion had front pivot supports only no rear. They put double fronts in the package.
2. front caster blocks 0deg markings were different. One had a large 0 and the other a smaller one. Also the button head screw that goes in from the bottom is wearing a groove in the caster block(with the smaller 0) as it won't sit straight.
3. battery posts & antenna mount kit came with 1 battery post and 2 antenna mounts. Shouldnt this be the other way around?
I'm not trying to whine about these mispackaging problems, just trying to get a handle on it. I am glad that I traded off that TC3 for it.
Cheers
Paul
Cheers
Paul
#7529
Re: XXXS Axles
Originally posted by PaulP
Hi Guys
Hi Guys
The GP+'s axles are a little shorter, and for me are usually flush with the lock nut.
Just as long as the axle hits the nylon part of the locknut, I wouldn't be worried.
If it doesnt, you may want to see if it is shimmed, or if he used AE hexes. If either have been done on the car, it might not let the axle get to the nylon.
