Old 10-23-2003, 04:14 PM   #7471
imjonah's Avatar
Default Oval Racing XXX-S
I know there are cars designed specifically for ovals.
The main difference I saw was that the drive system had the motor directly driving the rear axle, the weight in the car was all very low, and there were several things in the supension that were adjusted for left turns only.
I know that a car designed from the ground up for oval racing would have a big advantage.
I am brand new to the sport and I was thinking that the oval races may be a little easier for me to try, until I get more skilled at driving.
Set up properly would my XXX-S be able to run on a 70 - 80ft oval track with cars designed for ovals or would it be totally out classed.
imjonah is offline   Reply With Quote
Old 10-23-2003, 04:37 PM   #7472
dpaton's Avatar
Send a message via AIM to dpaton
Default Re: Oval Racing XXX-S
Wellll.....
Carpet oval cars generally are mildly modified pan cars, with the associated benefits in terms of power/weight ratio, lowness to the ground, nice wide foam tires, etc.
If you can, I'd try and see if one of the guys with the purpose built oval cars would let you do a few laps with his car, to see how it drives.
Personally, my gut says no, but my gut feelsings have been proved wrong many times, so go for it
-dave
dpaton is offline   Reply With Quote
Old 10-23-2003, 07:37 PM   #7473
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Oval cars are harder to drive than you'd think, to be even slightly competitive, you need to be able to hold a low straight line, which can be hard if you're new to the hobby. Oval cars are also 2wd instead of 4wd, much less drag.
Stick with on-road tracks with your XXX-S
Old 10-23-2003, 08:31 PM   #7474
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
On a proper track, any pan car, road or oval, will out run any touring car in the proper hands. Like Randy said, too much drag on a 4wd car. Pan carws are half the weight, if not less, next to no drag and fast as can be. But they're also hard to drive. Randy's right. keep the touring car on road courses.
Jon Kerr is offline   Reply With Quote
Old 10-23-2003, 10:15 PM   #7475
Trader Rating: 19 (100%+)
Actually 4wd cars are well suited for dirt oval. Just look at the Custom Works Dominator Cars - 4wd. There is a large community of Dirt Oval R/C racers at www.dirtoval.com
The classes of Wedge/Buggy 4wd 19Turn is fairly popular for cars such as the XXXS and TC3.
As for oval with sedans, I believe the class is supported at large events such as SnowBirds. You may want to query folks there.
MDawson is offline   Reply With Quote
Old 10-23-2003, 10:20 PM   #7476
Does Hot Rod Hobbies still have a dirt oval up there?
Old 10-23-2003, 10:20 PM   #7477
I know I am gonna get slammed for this, but IMHO oval is much easier to learn to drive, but is much harder to master than on-road!
That being said, what are the other guys running, are they running gearbox and 4wd cars or are they running pancars?? If they aren't running pancars then the Losi will be right at home with them and possibly even faster.....
The main question is...... do they have a class for the LOSI????
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 10-24-2003, 06:13 AM   #7478
Hi,
Need to ask you guys where I can get this Tech Racing one-way for the XXX-s G+. Busted my losi's, so looking for a replacement. Heard that I need to use AE drive shaft to suit it, is that true?
lozi is offline   Reply With Quote
Old 10-24-2003, 07:09 AM   #7479
dpaton
Where is there to run in by Schamburg? I work in Elk Grove alot and would like to bring my stuff. Any tracks race or practice through the week?
Adams44 is offline   Reply With Quote
Old 10-24-2003, 07:53 AM   #7480
STLNLST's Avatar
I'll be trying out the Integy based 19 turn this weekend. Two times out on 19 turn carpet with rubber tire's and two wins with two different motors. The first was the epic D5 can and the other was an old promatch epic chrome 19 turn. Gearing for both cans were waaaaay different. We'll see what type of gearing the Integy can likes. I'll make sure to post my findings after the races on Saturday.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-24-2003, 08:37 AM   #7481
Jon Kerr's Avatar
Did you like the D5 better than the C2 based motor?
Old 10-24-2003, 10:26 AM   #7482
mcsquish's Avatar
ackerman
OK, I have a question, when moving the front arms .060" farther fwd than the stock fwd and you are supposed move and flip the bellcranks to fix the ackerman. How do you know that the ackerman is wrong? Why I ask is that I tried the arms .060" fwd and the bellcranks fwd. With that change the car was too smooth. It was good at turn in, but had a push middle and exit. If I try .030" fwd how will I know if I should run the bellcranks fwd or back? I hope that made since and any help woul be very helpful!
mcsquish is offline   Reply With Quote
Old 10-24-2003, 11:02 AM   #7483
Send a message via AIM to TeamRoy
HUH? Speak english please.
TeamRoy is offline   Reply With Quote
Old 10-24-2003, 11:06 AM   #7484
Jon Kerr's Avatar
I think what you need to do is see how far forward the ball studs on the cranks move forward when you flip and reposition them. If it's more or less than what you're moving the arms. Your ackerman is going to be off. I hope that makes since.
Old 10-24-2003, 11:32 AM   #7485
Originally posted by lozi
Hi,
You should be able to get it at Rainbow Ten.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
