Losi XXX-S
#7441
Trader Rating: 32 (100%+)
DPaton.....Ball Cups
Dave....you can grind a fair amount off of the top of the ball cup with out fear...some have even ground so much off that you see the ball stud. From the pic all looks well so just try taking some more off the top of the cup or go to a silver ball stud.
#7442
I know this has probaly been posted a few times but I DONT FEEL LIKE LOOKING THREW 250 pages, I need a good carpet setup for a tight indoor carpet track with foams. I dont have a graphite plus but ever part on the car is graphite. I prefer not to use a oneway because everytime I do the rear end always spins out even when Im not braking in a turn. Thanks!!!!!
#7444
have a Question
I'm running a Chameleon pro 2 19t what spur and pin should be used ,, i have a habit of burning motors LOL ..
RPM [email protected]
power [email protected]
eff 73.9@ 15.7k
torque 124.0 Nmm
need advice .. thanks inadvance..
eff 73.9@ 15.7k
torque 124.0 Nmm
#7445
Well, people here are gearing them in the mid 6's final drive ratio. We've only been running the 19T class a few weeks here, so I can't really speak for the "longevity" factor.
Rob
Rob
#7446
ROB !!
Rob
Rob
#7451
Originally posted by Randman
I know that 4499's have a lot of power, and dont seem to kill any of my comms. You might want to make sure the bushings are broken in and oiled as well, those will cause a lot of heat, and start to hurt your power towards the end of the run...
#7455
That must be a sign of how long it's been since I've run 19. I thought they ran bushings... o well.
In that case, gear down a tooth.
