Losi XXX-S
#7396
Re: trinity motor heatsink
Originally posted by eklips
Looking for trinity part number for a motor mount heat sink that was used for the street weapon. This is the one that has a huge blue heat sink attached to the motor mount and can be used w/ the xxxs. Been looking for this mount and cant find the part number.
thanks in advance
thanks in advance
http://dynamiterc.com/Products/Detai...ductID=DYN6820
#7398
Anyone having a harder time setting there losi up on the asphault than lets say a x-ray guy or yokomo guy, seems I have to work alot harder on the asphault than those fella racer, most of the guys here run the x-ray's or tc3's. Just wondering if it true nature is the carpet and to stick to carpet.
#7399
are you using a one-way? that really seemed to keep the speed up in the corner. the setup i used and worked excellent for me was the Greg Hodapp asphalt nats setup on the losi website. that should get you started.
#7400
nope. i run exclusively on asphalt now, and can definitely say, my xxxs handles great.
i run todd hodge's socal set-up with a few variations, like the rear spring. try it out.
#7401
luke, u usin the hodge setup this winter?
#7402
i use the hodge setup for rubber carpet but now i run foamies so im trying out a custom that im told works well.
#7403
thank you all, I will check that out.
#7404
Has anybody tried the rear steel out drives ? any improvement?
#7405
thanks in advance
thanks in advance
#7407
I would think that right side don`t sits right. Cheack the screws again and thighten them carefully
#7408
Originally posted by rcdougie
Anyone have a problem with the Losi one-way bearings? I have a brand new one way and when I installed it the right one doesnt spin freely as well as the left one. Any ideas? Thanks!
just a suggestion, check if you have tightened to halves correctly... i made this mistake and it caused a bind.
if all else fails, maybe you just need to re-lube the one-way bearing, after a while it'll free up.
#7409
could anyone tell me whats the diffrents between piston 56, 60,57 and so on?
#7410
the smaller the number the bigger the hole.
... also the number denotes the drill bit that corresponds to the bore diameter.
