Old 10-14-2003, 03:59 PM   #7366
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Kevin is correct, you need to use the TC3 bones.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-14-2003, 06:40 PM   #7367
pro3racer's Avatar
while looking at pro cars(xxx-s, duh), i saw that many used very wide foam tires, in the front and back, but even wider in the back. Do you have to trim some stuff down to get this wide, and how wide can you go. Does this help enough to go out and buy new tires though.
pro3racer is offline   Reply With Quote
Old 10-14-2003, 06:51 PM   #7368
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Pro3....You can get tires that are wider then 28mm to fit the car but it will take some work. In the rear you can run the shocks on the inside hole on the arm and that helps get some clearance. Also you can cut a little off the shock bottom to get more clearance....when you put wider tires on the car you will see where they rub and if you just take a little off that part of the shock bottom it wont rub. In the front you can drill another hole on the arm a little inside of the stock hole....this is if you want to run wider then 28mm tires. I take the front arms and file or grind away that little "nipple" or nub on the front arm that the shock mounts to. When you grind this flat it will move the shock bottom closer to the arm and reduce the rubbage...is that a word???? Anyway you can and should also glue a gold washer or two to the spindle to limit the max throw so your tires do not hit the front spring. You can also grind a little off the shock bottom where it rubs for more clearance in the front too. If you dont know what Im talking about I will take a pic and post it if needed.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-14-2003, 06:56 PM   #7369
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Do they use a smaller pin size?
Old 10-14-2003, 07:08 PM   #7370
Kevin K's Avatar
I think it has something to do with the size of the ball at the end of the bone. The losi one is bigger or something. Plus I think that 1-way uses TC3 1-way out drive cups so they are made for the TC3 end size.
Old 10-14-2003, 07:24 PM   #7371
pro3racer's Avatar
i think rubbage should be a word, i use it sometimes too. FYI, my word is combojulation, means a lot of, hahaha . I get what your taking about, except for what the shock bottom is, is it the "ball cup", or the keeper. 28mm are supers right, i believe i bought them for my pro 3 once, but they weren't worth trying to make fit. One last ??, are they worth buying a new pair though, is it that big of a difference, and are 24's good for the front.
Old 10-14-2003, 07:42 PM   #7372
Kevin K's Avatar
Im glad you like rubbage
The part Im talking about grinding a little off of is the plastic part that you screw on to the bottom of the shock shaft. And 28mm is a super wide rubber tire but it is almost the norm when you are talking foam tires. I think you are confusing the rubber tires and the foam tires. With rubber tires the 24mm or 26mm tires work just fine. But with Foam tires the wider ones are better like 28mm. If your racing rubber tires you dont have to worry about any of this its just for using wide tires like with Foams....I think you will be hard pressed to find a wide rubber that works near as well as a narrow one.
Old 10-14-2003, 07:52 PM   #7373
pro3racer's Avatar
no i'm not confused, i'm running foam tires. i have jaco 24's in all around right now(foam tires). I want to run wider foams, like a 28.
Old 10-14-2003, 08:01 PM   #7374
Kevin K's Avatar
Ok I just wanted to make sure that you were not talking about rubber tires.
One more thing most of the time with wide foam tires you should run the TC3 hex's...they are alittle wider and give more clearance too.
Old 10-14-2003, 08:05 PM   #7375
pro3racer's Avatar
not to be mean, u answered everything perfect, but whats the effect, just a lot more grip, or more in, off power, what?
Old 10-14-2003, 08:17 PM   #7376
Kevin K's Avatar
The wider tire will make the car less twitchy and have more grip if that makes sense. The narrow tires will make the car feel more like its on edge and not have very much side grip. Plus wider tires give better forward bite. And GM has built an empire on "Wider is Better"
Old 10-14-2003, 09:12 PM   #7377
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Hey Kevin, Do you need to run low profile lock nuts with the AE Hex? I have a set of the AE hexes, but havent played with them. I put them on the car, found the axle didn't get to the nylon on the nut, so i just swaped back to the Losi hex.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 10-14-2003, 09:19 PM   #7378
Kevin K's Avatar
Troy....yeah you can use them or use the BRP locking nylon wheel nuts they never fall off. Or if you have some spare change get TC3 stub axles they have like one more thread on them so the nuts stay on better. The TC3 stub axels are like 8 bucks each but you wont have to worry too much about a wheel falling off. Or you can go ghetto and flip the wheel nuts over and put them on backwards...
Old 10-14-2003, 10:23 PM   #7379
thats what i did on my old T3...the wheels are so deep my socket wrench won't reach the nut when it gets deeper....stupid wheels....
Los1Fan is offline   Reply With Quote
Old 10-14-2003, 10:24 PM   #7380
Originally posted by Randman
aaaah, nice! If I ever have problems with my Losi 1 way, I know what I'm gettin
with the steel outdrives..won't that be heavier so if heavier..the more the rotating mass and the slower the car will accel??
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
