Old 10-10-2003, 06:44 PM   #7336
robk's Avatar
Trader Rating: 22 (100%+)
Let's talk turkey, who's racing on foams these days? Anybody trying anything new? Underdrive? Antidive? Prosquat?
Old 10-10-2003, 07:51 PM   #7337
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I was thinking of trying overdrive with a 1-way. Any thoughts?
Jon Kerr is offline   Reply With Quote
Old 10-10-2003, 08:00 PM   #7338
i tried that...corner turn in is good...exit...pushes a lot...i dunno if it's just me...i replaced the pulley with the standard and it ran fine...actualy ran faster..still pushing out a little....acceleration speed is faster...but puts a lot of stress on the drivetrain....just my thoughts........now i'm going back to diffs with the overdrive...
anyways...i've never seen the spur adapter for the xxx-s but could i use a xxx buggy spur on that thing....i wanted to get one of those kevlar bat it only comes in 64 pitch for xxx-s...any thoughts?....
Los1Fan is offline   Reply With Quote
Old 10-11-2003, 10:24 AM   #7339
Send a message via Yahoo to Doug Gaut
I dont know of anybody that makes a good spur gear adapter. Back when Trinity came out with theirs I bought one and where the gear mounted was true but where the belt rode was oblong. You would have to set the belt tension loose to accomodate the tight spots which allowed the belt to skip. The stock gears work great. I have used 64p for years on indoor and outdoor tracks with no failures. I do use the gear cover though along with some foam strips cut to outline the gear cover to keep the fine dust particles out as well. Its nice to look in the gearcover and see a nice clean yellow belt.
Doug Gaut is offline   Reply With Quote
Old 10-11-2003, 10:27 AM   #7340
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by IMPACTPLAYR
Well it's bulletproof... as for stripproof that remains to be seen!!
Mine held up to a 7 turn motor pretty well, it spins very true, no wobbles or anything.
Old 10-11-2003, 11:46 AM   #7341
Da4head's Avatar
Default Outside shock limiter
I was looking at some setup by guys like Todd Hodge and they have the .100 limiter placed on the outside of the shock between the spring cup and the cartridge. What effect would this have on the handling of the XXXS-G. Would this prevent traction rolling?
Da4head is offline   Reply With Quote
Old 10-11-2003, 04:31 PM   #7342
robk's Avatar
I think the outside limiter is to keep you from driving the dogbone too deep into the outdrive, but I'm not sure. All limiting uptravel does is cause the spring (and wheel) rate to shoot to infinity instantly. Not good for handling, but it can stop damage from occuring.
Old 10-11-2003, 10:18 PM   #7343
Trader Rating: 71 (100%+)
I think the limiter is used to keep the piston lower and "in" the oil. Eliminate the lil air bubbles.......
RBLove is offline   Reply With Quote
Old 10-12-2003, 09:25 AM   #7344
mainracer's Avatar
Send a message via AIM to mainracer
I would like to know if it is better to keep the suspension table whitout any loose tight but to keep it freee or should we put a little loose ?
mainracer is offline   Reply With Quote
Old 10-12-2003, 10:08 AM   #7345
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Da4head: notice on the setup, they are using very light springs & oil....
By using the outside limiting:
A.) it keeps the car chassis from "bottoming" out.
B.) as RBLove stated, less cavitation
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 10-12-2003, 03:26 PM   #7346
does anyone know if theres a shock shaft for the front thats shorter than .36 (is that right??) which is the stock on the G+ kit?? if so can u give me part number...thnxthnx
Old 10-12-2003, 04:16 PM   #7347
Tres's Avatar
http://www.teamlosi.com/pdfs/xxxsG/Bag%20F.pdf
A-5058 .28" Shock Shaft
A-5059 .36" Shock Shaft
Tre's
www.tnt-fx.com
Old 10-12-2003, 05:45 PM   #7348
tnx
Old 10-12-2003, 08:29 PM   #7349
adrian's Avatar
Default Set UP
hey all, im runnibng on a tight indoor carpet track soon.
Any set ups? i like an easy to drive stable car.
adrian is offline   Reply With Quote
Old 10-12-2003, 08:34 PM   #7350
Default Re: Set UP
go to losi's website they have some setups used by their drivers...i think there's one for indoor carpet tight track....we don't have carpet tracks here so i can't use any of those set-up....but check it out..you might get some ideas...l8tr
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
