Old 10-07-2003, 08:41 AM   #7291
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Default Re: foam carpet
Originally posted by sturla
Does anyone have a good set up to share on twisty foam carpet track? What should I think about when I go from a good asphalt rubber set up to a foam carpet setup?
Start with the Matt Francis set up on the Losi site its a good starting point. If you cant find the Congo springs in the set up start with White front springs and Black rear springs. That should get you very close to a good set up.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is online now   Reply With Quote
Old 10-07-2003, 09:11 AM   #7292
RCBuddha's Avatar
Trader Rating: 33 (100%+)
Out of curiosity, what kind of lubrication do you guys use on your one ways? I was thinking a light grease or oil, any suggestions?
Thanks,
Buddha
RCBuddha is offline   Reply With Quote
Old 10-07-2003, 10:00 AM   #7293
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Evicerator
um, it's easy to eliminate the gear cover... you are drilling holes in your chassis aren't you?
Yeah, but the places where the wires go, there's either an ESC in the way, a pulley, or a diff gear, that's what makes it hard... See ya at the track today.
Old 10-07-2003, 10:00 AM   #7294
Thanks,
Buddha
XRay has some 1 way lube, I've never tried it out, but everyone says it's the best out there.
Old 10-07-2003, 11:48 PM   #7295
Well I ran the XXXS for the first time today, I do like how the belt drive feels as opposed to shaft drive, but I've still gotta see if I can get a better setup on the car. Decided to run pro stock instead of mod today, and had to buy a motor at the track, unfortunately it was kinda underpowered, and held me back a little bit, ended up 3'rd place about 1 second behind 2'nd. I'll try a few new things next week, hopefully I can get it dialed in even more.
Old 10-08-2003, 12:07 AM   #7296
FREAKAH's Avatar
Thanks,
Buddha
Do NOT use regular oil or grease. They are too slippery. They will allow the rollers to slip while under drive.
I use AE stealth diff lube. I still has enough lubricity yet still has enough friction(if that makes sense. )
I think Racers Edge (or some other similar sounding company) has a oneway specific lube too.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 10-08-2003, 12:20 AM   #7297
highwayman's Avatar
Thanks,
Buddha
i use serpent's one bearing oil...
highwayman is offline   Reply With Quote
Old 10-08-2003, 01:30 AM   #7298
Default Which foam tire to use
Hi, Just built my xxx-s and ran it. Coming from Nitro (MTX-3), It handles much better, I think it's because of it's weight. I'm wondering what tires everyone is using for carpet, do you run same size for both front and rear, or larger rear?, and where can I get these tires on-line cheap
Jasonchi is offline   Reply With Quote
Old 10-08-2003, 08:19 AM   #7299
dpaton's Avatar
Send a message via AIM to dpaton
I run premounted 24mm Take-Off 22s front and rear. My LHS sells them for about $30/4.
A little sauce, and they stick real good. They wear pretty quick tho. The nxext harder compound is CS27, which is nearly as grippy.
A lot of guys swear by the Sorex compounds, but it's a bit more since they're abotu $35/4 for just the tires. Add inserts and rims and it makes more financial sense (to me) to go with the Take Offs.
-dave
dpaton is offline   Reply With Quote
Old 10-08-2003, 08:23 AM   #7300
RCBuddha's Avatar
I thought AE Diff lube was a "regular grease"?
Any other suggestions? Thanks,
Buddha
Old 10-08-2003, 09:05 AM   #7301
Jasonchi- For carpet foam tires the standard is Plaid fornt and purple rears. Most people run them the same size front & rear, the most stagger I have heard is 1/2 mm smaller on the fronts.
Chad
ChadK is offline   Reply With Quote
Old 10-08-2003, 09:55 AM   #7302
Thanks for the responds. Yes, my intension was to ask about form tires. From what I hear, they are better than rubber. don't want to start a tire war here . So, most people runs foam tire on carpet and they are 24mm for both front and rear, this sauce you are talking about is WD40 and Simple Green, and can be used for both foam and rubber tire. Am I on the right track so far?
What brand is this "Plaid fornt and purple rears" and where can I get them, and do you recommend other brands as well?
Old 10-08-2003, 10:03 AM   #7303
FREAKAH's Avatar
Buddha
The AE diff lube is a silicone based grease.
Second-Hand Racing
RACE WORLD HAWAII
Old 10-08-2003, 10:09 AM   #7304
-dave
Check out Speedtech's site, they have Sorex tire/wheel/insert bundles for around $35...
Old 10-08-2003, 10:11 AM   #7305
TRC or Jaco should make them (although I dont run any foam tires, so not 100% sure)
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
