Losi XXX-S
#7281
Youch! I just checked the rear diff on my car, and, um, the middle of the pulley has fallen out. Could be part of the problem methinks.
Time to order some new bits!
Ian
Ian
#7283
rear toe in
I have a question ?
to achieve 2 d of rear toe in on the rear you have to put the 0 deg if I put 1/2 d in the right sens I will have 2½ and if I put 1 on the right side I will achieve 3 ???? and if I put ½ but left on the right and vice versa I will achieve 1½?? and same thing whit 1 d left on right I will have 1 ? and when we say I have 2 d of rear toe in does it mean per weel or both exemple on the setup sheet !
thank
thank
#7284
Trader Rating: 32 (100%+)
You are right in your logic there....and when its on the setup sheet its per wheel not a TOTAL of both sides.
#7285
Ian
Ian
#7287
foam carpet
Does anyone have a good set up to share on twisty foam carpet track? What should I think about when I go from a good asphalt rubber set up to a foam carpet setup?
#7288
Re: foam carpet
#7289
The Evicerator
um, it's easy to eliminate the gear cover... you are drilling holes in your chassis aren't you?
#7290
I was more thinking about roll center, shock position and so on... The springs and the oil is common on all cars when going from asphalt to carpet
