Old 09-26-2003, 11:30 PM   #7141
losi jon's Avatar
STLNFRST-HAHA!!now THAT'S funny! still racing offroad bro but now that the track i am racing at is putting in a big sedan track its on like donkey kong!! gonna try to pry you and Mark Dawson back here to race again!!
also i bought a new REAL vehicle,i am looking at coming up to your neck of the woods now that i have a dependable vehicle....and do some racing...if that what you want to call it
losi jon is offline   Reply With Quote
Old 09-27-2003, 12:36 AM   #7142
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by mb racer
hey I used a roto zip bit in my dremel worked very good no melting and very nice cuts as well ... my 2cents....
I heard about those, do you know where I can find one?
Old 09-27-2003, 12:37 AM   #7143
Originally posted by teamAE
randy here the springs for all the losi's
http://www.teamlosi.com/techtips/spring_chart.htm
And for the roto zop my sucked I bought it because it was there and looked preatry good but it could not cut crap my 2 cents but I also added 2 more cells for some real power lol.
Cool, thats a lot of help! Thank you!
Old 09-27-2003, 10:05 AM   #7144
pro3racer's Avatar
Default rideheight
i was just about to start packing my car up for this weekend with it's new setup, when i noticed that my front ride height is about 3/4 inch up!!!!, i 'm using the trackside todd hodge setup, i never understood how you lower a car down, so could someone please tell me, my car looks like a drag car, going backwards.
pro3racer is offline   Reply With Quote
Old 09-27-2003, 10:08 AM   #7145
I've never seen a sedan with a rideheight of 3/4", I didn't even think the shocks could extend that long. You need to back off of the preload collar to bring it down though.
Old 09-27-2003, 10:31 AM   #7146
pro3racer's Avatar
Default yea
pretty wierd huh, is that it, or is there more i can do to bring it down, it's not preloaded that much to start, okay, maybe it's a 1/2 inch, i rechecked.
Old 09-27-2003, 10:31 AM   #7147
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That and shorten your shocks. Make sure you've got the short shocks in the front and long in the back.
Jon Kerr is offline   Reply With Quote
Old 09-27-2003, 10:43 AM   #7148
pro3racer's Avatar
Default stupid
i just realized i put rear(1.5) springs in the front, now i have to change, i my setup is all screwed up, but i guess thats just one joy of the hobby
Old 09-27-2003, 10:57 AM   #7149
Jon Kerr's Avatar
1.5 or 1.15? You can run 1.15's in the front and still get the correct ride height, it just takes a little adjusting. But I don't know about 1.5". That sounds like a buggy spring.
Old 09-27-2003, 10:59 AM   #7150
pro3racer's Avatar
Default oops
that was what i meant, but anyways, guess what, i didn't work, i have the long shocks in the back, and everthing square, would it have to do with my front pivot(Or) choice?
Old 09-27-2003, 11:07 AM   #7151
highwayman's Avatar
i use to use the 1.15 springs up front, the blue ones, and i could still make the proper ride height. the shock collars just need to be all the way up.
... BTW, im using todd hodge's socal setup now, but before, i use to use the blue or red springs, depending on the track.
... the hinge pin holders in front shouldn't make a difference.
highwayman is offline   Reply With Quote
Old 09-27-2003, 11:14 AM   #7152
pro3racer's Avatar
Default another
great, how didn't i see all these problems, now the hex screw that gos through the bumper(i'm trying to take it off), stripped out. How do you guys get a stripped screw out!
Old 09-27-2003, 11:32 AM   #7153
highwayman's Avatar
Default Re: another
we use a cutting disc on a dremel to place a slot on the screw, in order to be able to use a flat head screw driver to turn the broken screw... just be careful not to hit the chassis...
Old 09-27-2003, 11:33 AM   #7154
Cut a slot on the head of the screw with a cutoff wheel on a Dremel and remove it with a flathead screwdriver.
Old 09-27-2003, 12:13 PM   #7155
dpaton's Avatar
Send a message via AIM to dpaton
Default Re: another
I avoid them in the first place by not ever using the allen wrenches that come with the kit. I used the stock wrench on the tunnel plate on mine, since I couldn't find my good 0.050" one, and stripped out the head on one of the 2-56 screws before I could blink. To remove stripped screws, I usually do like Randman suggested and dremel them into flathead screws. If they're countersunk (flathead) screws, I use a reverse thread extractor a machinist friend of mine made me. I chuch it in my drill press and apply a ton od pressure while slowly turning the spindle backwards by hand. It's hard and slow, but it's the best way I've found to remove the most stubborn small screws. As a matter of fact, I just used it on my car.
Next stop: Hobby shop, for stainless tunnel screws.
-dave
dpaton is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
