Old 08-19-2003, 04:04 PM   #6901
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Here they are......
LOS9847 Losi, XXX-S Rear HUB CARRIERS, graphite (2) 5.95
LOS9852 Losi, XXX-S Rear .5 degree HUB CARRIERS, graphite (2) 5.95
LOS9853 Losi, XXX-S Rear 1 degree HUB CARRIERS, graphite (2) 5.95
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-19-2003, 07:13 PM   #6902
whats a good website about setting up the xxxs for carpet track?
just curious about the basic setup rules for carpet tracks.
crono man is offline   Reply With Quote
Old 08-20-2003, 06:56 AM   #6903
tufferwilde's Avatar
Crono - Check out the setups on Losi's website... there are several carpet setups on there... at the very least - you will have an idea which direction you need to be headed in!
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 08-20-2003, 07:20 AM   #6904
In general your carpet set-up will begin at the stiffer end of your asphalt set-up. Also usually measures are taken to remove steering as traction is usually abundant.
Of coarse this all depends on what for tires you have to run, if it's rubbers then the set-up will be softer and foams the set-up will be stiffer......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 08-20-2003, 04:29 PM   #6905
thanks for the input guys i did check out the setups on losi website,and i noticed a ressemblance between the carpet setups
Old 08-20-2003, 07:07 PM   #6906
STLNLST's Avatar
Trader Rating: 19 (100%+)
with rubber tire's I was able to run the same set up on carpet that I did on asphalt.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-20-2003, 10:08 PM   #6907
NeO-pRo-3's Avatar
hey guys any of you experience clicking sounds when running your car?
(im using the blue belt)
I use the blue belt also got the yellow but never got the chance to try it out. I hear clicking sounds, i always thought it's because you let the belt loose so it can skip a little. When i make the belt tight it stops making that clicking sound. is that suppose to happen or what? o yeh is yellow belt better than blue?
NeO-pRo-3 is offline   Reply With Quote
Old 08-20-2003, 10:20 PM   #6908
Talking belt
if you have yellow belt run it Its smoother and more efficient than blue ,,, but blue always seemed to work till it snapped......run yellow its better on car....2cents
Mark Barden .
mb racer is offline   Reply With Quote
Old 08-20-2003, 11:25 PM   #6909
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hi guys, just got a used xxxs ..i am a quetion here see if you losi experts can help me out here my xxxs comes with a spur gear orange in color(48P), i am tryin to figure out the T of this spur can someone tell me what T is this ? 88 or ? i will be running a monster stock , and what pinion / spur combination will give me 7.1 range drive ratio ? all help will be highly appreciated!
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 08-20-2003, 11:43 PM   #6910
Your spur is 90T... you would want a 23 tooth pinion....
Old 08-20-2003, 11:54 PM   #6911
Tag
Tag's Avatar
hi thanks for the help..so 90 T w/ 23 pinion will yeild 7.1 ratio ?
Old 08-21-2003, 06:40 AM   #6912
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
(Spur/pinion)*1.83=gear ratio.
(90/23)*1.83=7.16
Jon Kerr is offline   Reply With Quote
Old 08-21-2003, 05:52 PM   #6913
is the BRP bumper worth it?
Old 08-21-2003, 07:30 PM   #6914
Jon Kerr's Avatar
Hey guys, I keep putting off getting a one-way, now all of a sudden I'm hearing that they're very fragile. Any truth to this? Any one have probelms?
Old 08-21-2003, 07:57 PM   #6915
Kevin K's Avatar
If you crash they will break but so will any other part. I dont think the 1-way is any more prone to breakage then any other part on the car. Any part of the 1-way can be replaced so its not like a TC3 where you blow a bearing your out 45 bucks....just buy that side and your back in the game.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
