Old 08-10-2003, 09:32 PM   #6811
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Thanks Mark. I've got a real nice setup on the car now but I want to do some testing to what else it's capable of. That's one thing I ran into when I was running a TC3. I found an OK setup and just left it. Never deviated. I want to know what different setups will do to the handling so if I need a minor adjustment I can go back to my past notes.
Jon Kerr is offline   Reply With Quote
Old 08-11-2003, 01:24 AM   #6812
highwayman's Avatar
Originally posted by MDawson
The additional top-row holes on the front shock tower add more tuning option rather drilling out the stock units which has been used on recent setups found at TeamLosi.com.
... what does that the additional top - row holes do?
highwayman is offline   Reply With Quote
Old 08-11-2003, 11:57 PM   #6813
TWiZTiD's Avatar
can some one give me a starting set up for this track www.tftr.org.au just want to start the setup againg i got every thing to run any setup so please give me a idea the track is middish bite but is big
TWiZTiD is offline   Reply With Quote
Old 08-12-2003, 12:02 AM   #6814
SpeedTech's Avatar
Hi Guys,
The SSG Losi Shock tower arrived a day early and they are available online right now in two different combos I saw MDawson's car over the weekend and the car almost look like a different car. Along with the silver CNC machined parts we have available, the car looks very trick
Here's a picture of the SSG shock tower, enjoy!
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 08-12-2003, 12:36 AM   #6815
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Finally something for the XXXS for "bling" supremacy over the Yok.
Dan is offline   Reply With Quote
Old 08-12-2003, 01:44 AM   #6816
McLaren's Avatar
Hi Guys, anyone interested to buy the following (almost new) assembled car kit? It includes ...
Losi XXX-S Graphite Plus:
- Race-proven ultra-efficient XXX-S drivetrain
- Graphite chassis, components, and suspension arms
- Threaded shock bodies with titanium-nitrided shafts
- Machined titanium turnbuckles throughout
- MIP CVD Driveshafts front & rear
Extras:
- Matt Francis Red Foam Front Bumper
- Matt Francis Red Aluminum Battery Heatsink
- Matt Francis Red Aluminum Motor Mount
- Matt Francis Red Aluminum Motor Mount Clamp
- Matt Francis Red Aluminum Motor Heatsink
- Matt Francis Red Aluminum Servo Mounts
- Matt Francis Red Aluminum Steering Brace
- Matt Francis Front Suspension Arm Front Mounts
- Matt Francis Front Suspension Arm Rear Mounts
- Matt Francis Rear Suspension Arm Rear Mounts
- Matt Francis Rear Suspension Arm Front Mounts
- Matt Francis Red Gear Adapter
- Matt Francis Red Aluminum Bell Cranks
- Matt Francis Red Shock Collars
- BOCA CERAMIC Bearings Throughout
- One-way front diff
- One box full of parts inc. rear/front arms, titanium drive shafts, red nuts, etc. etc.
Simply give me an offer and I will consider
McLaren is offline   Reply With Quote
Old 08-12-2003, 10:17 AM   #6817
TeamPRP's Avatar
Default setup sheet for PRP Megatune towers
Sorry, accidentially hit the submit button twice, d'oh!?!
TeamPRP is offline   Reply With Quote
Old 08-12-2003, 10:18 AM   #6818
TeamPRP's Avatar
Hey guys,
We finally have a setup sheet for all those that use our Megatune towers. Also, our updated shock towers should be coming out this month. The new tower design and the setup sheet can be found at at the TEAM PRP web site. The setup sheet can be found in the downloads section.
Thanks!
Ben
Old 08-12-2003, 01:37 PM   #6819
pro3racer's Avatar
Default factory
how do u assemble the factory setup for the ackerman steering. I'm putting greg hodapp's setup, and for his ackermann, he has forward,flipped, how do u do that(i drilled the hole, but i can't seem to get the ball cup on with the bar so far back.
pro3racer is offline   Reply With Quote
Old 08-12-2003, 07:46 PM   #6820
They filp the ackerman by using the forward hole for the ackerman posts in the graphite plus.(it you only have a xxx-s or a graphite conversion your out of luck.) That way the longer part of the arms are facing back and the short part is forward. the ackerman will be in in the same positon to mount balls and links, this just change the pivot point for the ackerman.
Ophidian is offline   Reply With Quote
Old 08-12-2003, 07:53 PM   #6821
2QCK2C's Avatar
Hi Ophidian,
Actually on the graphite conversion if does have the
forward holes for the second location for the ackerman.
As it does on the G-Plus. As I have both the difference
between the 2 is the slotting and milling work in the
chassis. But you are right on the reg non graphite
you can't do anything about the ackerman position at all.
2QCK2C is offline   Reply With Quote
Old 08-12-2003, 08:00 PM   #6822
2QCK2C, thanks for the info. I went from the xxx-s to graphite plus and never bought the graphite conversion. I didn't know they add the exrta holes for the flipped ackerman in the conversion.
Old 08-12-2003, 08:20 PM   #6823
SpeedTech's Avatar
Yes, "bling bling"
I forgot to mention that the SSG Components are a limited production run as SSG material are quite difficult to source.
Steve Wang
Old 08-12-2003, 08:30 PM   #6824
Jon Kerr's Avatar
Not a problem. Mine are already on their way
Old 08-12-2003, 08:34 PM   #6825
pro3racer's Avatar
Default ackermann
i'm still confused, okay, i think i have a regular xxx-s, manually made into a G+, i bought the car from a "almost" factory driver, very fast, best equipment. On my car, stock, there are three holes on the the bar that holdes the two steering systems together. Two holes are to hold the parts together, and one is to have a ball stud, connecting to the servo, is that it, i've done the factory mod and drilled a center hole, but the stud doesn't fit with a cup on it, can i flip it, or buy a new part. I want the better adjustments, and a good factory mod.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
