Old 08-06-2003, 06:27 AM   #6766
J.Filipow's Avatar
Trader Rating: 15 (100%+)
ernieball- they are not available just yet, i think it will be a few weeks before your LHS will have them in stock.
zachzachz- these gears won't be completely indestructible, you will still need to set your gear mesh carefully, like any other gears.
highwayman- for the sedan, i think initially it will only be the popular 64 pitch, 128 tooth that will be kevlar.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 08-06-2003, 10:39 AM   #6767
http://www.teamlosi.com/newprod/2003...vlar_gears.htm
i dont think the color is that bad. i know they will all be going into all of my cars. the only gears that i have seen that are also really sweet are the hpi ones made of carbon fiber. that would be sweet if they fit the losis.
ernieball is offline   Reply With Quote
Old 08-06-2003, 10:59 AM   #6768
DuffMan's Avatar
Send a message via AIM to DuffMan
From the site above....
LOSA3943 128T/64P Kevlar Spur/Pulley (XXX-S) 5.00
Does this mean there will only be 64p, 128 tooth spur, its the only product code related to XXX-S there.
DuffMan is offline   Reply With Quote
Old 08-06-2003, 05:20 PM   #6769
TWiZTiD's Avatar
having some truble with car setup cant seem to get the rear hooked its fine on open corner and is fast corner speed just exiting tight corners it becomes really lose. I am runing on a larger track with tight sections medium bite the set up I am using is
FRONT
purple spring
45wt oil
shock in hole 3
camber link hole 2
lrc - 2f
oneway
4 deg caster
4mm of drop
REAR
Silver spring
45 wt oil
shock in 1 hole
camber in hole 1 inside on hub carrier
offset 0 hub carrier
lrc - 0r
2mm of drop
body alfa 2
TWiZTiD is offline   Reply With Quote
Old 08-06-2003, 05:24 PM   #6770
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Now all losi has to do is make kevlar gears to fit other cars too...IE TC3...
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 08-06-2003, 05:26 PM   #6771
Trader Rating: 23 (100%+)
preview.....
you'll have to ask [email protected] for more info but here is a look....
TEAMORCA.SHOP
MDawson is online now   Reply With Quote
Old 08-06-2003, 05:36 PM   #6772
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
(drooling) I want, I want. Steve, if you're reading this, when and how much! Tell me you're going to have a bottom channel cover too.
Jon Kerr is offline   Reply With Quote
Old 08-06-2003, 05:38 PM   #6773
Jon Kerr's Avatar
Mark, what'ss the screw coming out of the top of the center channel?
Old 08-06-2003, 05:49 PM   #6774
that is for my 5th body post.
TEAMORCA.SHOP
Old 08-06-2003, 05:56 PM   #6775
Jon Kerr's Avatar
I see. I thought you may have some trick front belt tensioner or something.
Old 08-06-2003, 06:17 PM   #6776
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Twizz....try the outer hole on ther rear hub. I never liked the inside hole it makes the rear end of the car break away real easy. Also try a little more rear droop or take some front away. And try try the standard NON-offset rear hubs in the back too. Dont do all this at once but these would be the three things I would look at next time your at the track.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 08-06-2003, 07:25 PM   #6777
STLNLST's Avatar
Trader Rating: 21 (100%+)
FRONT
purple spring
45wt oil
shock in hole 3
camber link hole 2
lrc - 2f
oneway
4 deg caster
4mm of drop
REAR
Silver spring
45 wt oil
shock in 1 hole
lrc - 0r
2mm of drop
body alfa 2
what pistons are you running front and rear? Iwould try coming out a hole on the rear shock location. I personally prefer the outer hole on the rear hub (seems to be a little more planted to me) but more and more people are trying the inner hole so I need to learn to deal with it as well. Also what hole in the rear arm are you using?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-06-2003, 09:19 PM   #6778
Kevin, wouldnt he need more front droop instead of less, for more forward bite on corner exit?
btw does anyone know what hinge pins come stock on the graphite plus? titanium? i just replaced mine with some titanium nitride shock shafts and they felt similar in weight, however i didnt weigh them.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 08-06-2003, 09:50 PM   #6779
Kevin K's Avatar
More front droop will give you more on power steering on corner exit which is not what he needs from what I can tell by what he said....so he would need less front droop compaired to his rear droop or just add some rear droop. But thats just one thing he can try I would look more at the rear hubs....go to the standard hubs if the car is over rotating at slower tight corners.....and make the rear link longer move to the outside hole on the hub.
Old 08-06-2003, 10:51 PM   #6780
TWiZTiD's Avatar
ok i have play alot with drop even tryed to have no front drop screws at all the pistons are #56 alround i have also tryed runing 1/2 rear blocks as well
Its really weird cause the cars front end grip is stop on turns in nice and hard and under steers out a little some one side it could be that the front needs more grip cause the rear looks to have to much ??
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
