Old 07-30-2003, 03:14 PM   #6736
DuffMan's Avatar
Send a message via AIM to DuffMan
Default Re: wheel viberation
Originally posted by sturla
hi
I was wondering if some of you have a tip so my wheel wont viberate so much. It seems to me that the plastic hex hub isn`t the best. Any suggestion?
Might be that:
The hub isent seated properly.
The CVD's have threadlock in them.
You dident seat the tires correctly.
These are all things that bhave happend to me, i dunno if its your problem, i think the plastic hubs would absorb more vibes, and are lighter than anything else, dunno for shure though, good luck.
DuffMan is offline   Reply With Quote
Old 07-30-2003, 03:42 PM   #6737
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Sturla.....is the vibration only at max steering throw or is it all the time? If its at max steering throw you have too much throw in the car. Something that alot of guys do is glue a gold washer or two on the backside of the steering knuckle to limit the amount of throw and stop the vibration. If you look at the knuckle there is like a little nub that hits the castor block and on this nub is where you would glue a washer or two to help with the vibration. Other then that I would check to make sure everything is seated properly and none of the CVD's or your wheels are bent.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-30-2003, 03:48 PM   #6738
Kevin K's Avatar
Pkranger63....the only other thing you will need thats a must have is wider hexs from the TC3 if you are going to race Foam tires. Thats about it.
Old 07-30-2003, 04:47 PM   #6739
pkranger63's Avatar
thanks! I saw those on one of the set-up sheets for carpet so I went ahead and ordered a set. I hope to have the car by next week. Thanks again.
Matt
pkranger63 is offline   Reply With Quote
Old 07-30-2003, 09:55 PM   #6740
Default 64 pitch
i am looking into switching to 64 pitch pinions for my xxxs. i want to know what pinion gears i would need to acheive a similar drive ratio. right now, i run anywhere from a 21 to a 24 tooth pinion and a 90 tooth spur(stock i think). what pinion, spur combo for the 64 pitch. any help would be appreciated and thanks in advance.
ernieball is offline   Reply With Quote
Old 07-30-2003, 10:57 PM   #6741
Send a message via AIM to Smartazz07
the stock one is 88 tooth. what color is yours? It depends on what size gear you are gonna use. this will hlp you alot gear ratio program
Smartazz07 is offline   Reply With Quote
Old 07-30-2003, 11:26 PM   #6742
The G+ comes with a 90T spurstock.... I would suggest the 128 spur with 28-35..... to start with
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 07-30-2003, 11:31 PM   #6743
oh i dont have the g+. in the regular kit it is 88. my mistake.
Old 07-31-2003, 01:01 AM   #6744
Lars Johnson's Avatar
Send a message via AIM to Lars Johnson
Originally posted by Evicerator
So what's new with you kids in here... figure out anything interesting with your cars?
stEEEEEVE!!!! I figured out that carpet racin' is really really fun
Lars Johnson is offline   Reply With Quote
Old 07-31-2003, 08:22 AM   #6745
Talking
thanks a lot guys. that gear program helped out. i need pinions 28 -32 with the 118 tooth pinion. thanks for the fast replies
Old 07-31-2003, 09:24 AM   #6746
128 feel alot faster to me...JMO
Old 07-31-2003, 09:36 AM   #6747
Default thanks
I would try your tips... It isn`t long since I installed new cvd`s since the old one was bendt... Isn`t there a option with alu hexes or something? Still feel that is the prop..
sturla is offline   Reply With Quote
Old 07-31-2003, 09:40 AM   #6748
just wondering what color was the 128 tooth spur. i cant find any 64 pitch gears on the losi website. does losi make 64 pitch or do i have to buy a spur gear adapter and regular 64 pitch gears?
Old 07-31-2003, 10:34 AM   #6749
Default spur
the 128 spur gear from losi is blue.. the 118 is yellow, and the 108 is bright/neon yellow
Old 07-31-2003, 01:57 PM   #6750
highwayman's Avatar
Originally posted by pkranger63
Hey guys, I just ordered a xxx-s G+ kit and should have it here in a day or so. I wanted to run somthing diffrent than most folks at the track. I will be running on carpet and used the set-up sheets on the losi site as a guide for what springs, oil ect to purchase. My question is besides the obvious set-up items are there any "must haves" that I should get?
Thanks for the help
Matt
my personal must have, is the clear upper bumper brace from losi and/or the BRP front bumper
highwayman is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
