Old 10-09-2001, 12:51 AM   #661
The titanium nitride coating is suppose to make the shafts last longer. It is a hard coating that reduces wear and prevents scratching. They are also suppose to be smoother so the seals last longer.
Sydewynder is offline   Reply With Quote
Old 10-09-2001, 06:12 AM   #662
HarshGuy's Avatar
futureal, the titanium nitride ones are not supposed to bend or break as easily, when I had my street weapon the stock ones used to bend pretty easily (or was that cause it was my 1st car ever ) ...although I've poppped the snot out of my XXX-S and have yet to bend or break a stock shock shaft.
HarshGuy is offline   Reply With Quote
Old 10-09-2001, 06:52 AM   #663
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
also the tit. nit. make the shock smoother....and it reduses friction.....
Matt M. is offline   Reply With Quote
Old 10-09-2001, 08:36 AM   #664
Trader Rating: 35 (100%+)
Started building my xxx-s yesterday, after having the kit for a week (been really busy). Discovered that my MIP/Thorp are not the right size (2mm and 1.5mm), wasn't expecting that. So I'm using the included allen wrenches for now.
The diffs went together easily, and the initial chassis building was smooth (belt, cover spur, belt and bulkheads), however, I've hit a snag... The bushings required for the steering links are AWOL.
I'm not going to bother calling Losi, since it would be better to install bearings anyway.
Geppetto is offline   Reply With Quote
Old 10-09-2001, 08:52 AM   #665
HarshGuy's Avatar
Gepetto, are you sure they're AWOL ...they're on the plastic (yes plastic) tree that the shock ends are on (I believe) I thought they were awol at first to like you I used bearings then when I was done I had 2 5x8 plastic bushings left over, and I verified from Losi that those were in fact the steering bushings.
Old 10-09-2001, 09:51 AM   #666
SpeedTech's Avatar
Hi Guys,
Here's what we have coming as far as those aluminum parts:
Front inner pivot blocks (with optional spacer for roll center adjustments)
Front pivot blocks (2F, 4/0F)
Steering bellcranks
Rear inner pivot blocks (with optional spacer for roll center adjustments)
Rear Pivot blocks (2R, 4/0R)
We also have two parts that will be released this week. They are the front and rear shock tower. These are machined out of 3.0mm woven graphite, and they are direct replacement of the stock pieces. We should have them available with pictures on our website by the end of this week. If you guys have any questions, feel free to email me at:
customerservice@speedtechrc.com
Thanks!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 10-09-2001, 09:52 AM   #667
Trader Rating: 19 (100%+)
Harsh,
Have you guys received one-ways at SpeedWorld yet?
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 10-09-2001, 10:04 AM   #668
Regional Moderator
Darkseid's Avatar
I got a close up look at the milled out graphite chassis this weekend. Pretty impressive piece of equipment.
TLR 22...Tamiya F104...
Old 10-09-2001, 10:17 AM   #669
Pit-racer's Avatar
MD- Do those alum. parts come in any other colors?maybe like purple?
Pit-racer is offline   Reply With Quote
Old 10-09-2001, 10:20 AM   #670
Pit
no they dont. but i am sure that those nice guys in the schumacher board can help you better with your purple people eater. ha ha.
TEAMORCA.SHOP
Old 10-09-2001, 10:35 AM   #671
HarshGuy: Thanks. You are probably right. I was expecting the bushings to be bronze, and to be in the same bag as the other steering parts.
Old 10-09-2001, 10:36 AM   #672
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Mark-
Please do a gear adapter..... the Matt Francis one is way to expensive and the red is crappy looking. I like the natural look.
mike_Webb is offline   Reply With Quote
Old 10-09-2001, 11:08 AM   #673
Administrator
Matt M.'s Avatar
mike, i ordered the trinity peices, and plan on using easyoff oven cleaner to strip the red off....i dont like it...
Old 10-09-2001, 11:19 AM   #674
mike_Webb's Avatar
.... I could do that also but my main point is that all of those products he is marketing are a rip off. $38 for the gear adapter is way to much. A friend has a guy at his track that made one himself and it cost about $20 to make it but the guy doesn't want to make them for everyone so he will not take any orders . I was thinking about having one made where it is not the whole round piece but instead just two or three thin arms that branch out and can have a screw go through them into the Spur Gear. It may be thin but I think it will work and the aluminum will not bend since it is only a spur gear adapter.
Old 10-09-2001, 11:26 AM   #675
Administrator
Matt M.'s Avatar
mike, i agree....they are pricey....
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
