Old 07-24-2003, 06:50 AM   #6706
I thought Losi used cheaper plastics on the RTR packages or something along those lines. I was not sure if they skimped on certain areas of the package to keep the cost down. If it is the same as the basic kit, I will be very happy Either way, I suppose it should handle the same
grimlock3000 is offline   Reply With Quote
Old 07-24-2003, 05:57 PM   #6707
Oasis's Avatar
Trader Rating: 36 (100%+)
That was on the xxxnt but not on the xxxs,it's the same as the kit.As far as hop ups I would wait.All you need is tires and a few 3300's and you will be set.
Oasis is offline   Reply With Quote
Old 07-24-2003, 09:35 PM   #6708
i am going to start off with a couple matched packs of gp3300 cells and see how those work out for me. i might pick up a 1500 sport pack as well, for when i want to drive around inside the house...
from what i can tell, the xxx-s sport does not come with the wheel adapters included in the regular kit. what kind of wheels will bolt on to the losi hex adapters on the xxx-s? anything i can order from tower, or do i need to buy losi rims OR hub adapters to use "standard" wheels? is mounting 26mm tires on 24mm wheels an issue?
basically, what are the cheapest well made set of wheels that i can mount x-patterns on the xxx-s? to get the $8 4 pack of losi wheels, i need to place an order through horizon and then get junked $7 on shipping
thanks for the help on everything so far
Old 07-24-2003, 11:47 PM   #6709
You can rder the Losi or Associated wheel hexes for use with the XXX-S...the Associated stuff will give you a 2mm wider car... either way they will cost you less than $4.....
I would asume the 12mm (standard) hexes are included in the RTR package... The wheels also may not come pre-glued in which case you can just remove the tires/inserts and put on your X-patterns..... BTW: the losi 8 packs of wheels should be the new standard hex wheels.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 07-25-2003, 06:26 PM   #6710
TLRacing
Todd Hodge's Avatar
Check it out
http://www.teamlosi.com/newprod/200.../200mm_ALFA.htm
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 07-25-2003, 06:33 PM   #6711
Ah, I did not realize I could use TC3 wheel hexes on the Losi. This all makes sense to me now. I am going to order up some AE wheel hexes, the RPM rims I want, and the X-Patterns. Regardless of what the Sport does or does not come with, I can always use the spares later
Do I want belted tires or regular tires?
Old 07-25-2003, 06:34 PM   #6712
Trader Rating: 23 (100%+)
Originally posted by T. Hodge
Check it out
its friday, get out of the office!!
looks like the rocket has some new colors
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 07-25-2003, 06:43 PM   #6713
Oasis's Avatar
Hey Todd any of you Team drivers going to race the Norrca world race at speedworld in sept. ?
Old 07-25-2003, 11:20 PM   #6714
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'm no team driver but I'll be there....LOL Matt might be around since it's his home track. Are you coming up for this race?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-26-2003, 08:17 AM   #6715
Oasis's Avatar
Yes I'm wanting to,but I need to send my entry form in..like a.s.a.p.. ,I need to race at least one club race also.I'm back running my Losi,I keep selling them and buying xxxs again.. I think in the last 6mo. I've had 10 of them,But as of right now I think I like my xxxs the most,I.m.h.o the xxxs has the least problems,is the easiest to set up,and if you can not get the xxxs to work i dont think your going to get anyother TC's to work..
Old 07-26-2003, 09:00 AM   #6716
STLNLST's Avatar
that's true. The Losi is very easy to work on and is very stable. If you can't get a Losi dialed in you're going to be hurting if you switch to a TC3 or any other car. Losi is still the car to beat at speedworld. The only person that can put down lap times with another car is Llyod. He's the AE factory driver that I came to your home track with. Mo is getting there with his Yok. See you when you come up.
Old 07-26-2003, 10:59 AM   #6717
TLRacing
Todd Hodge's Avatar
xxxkat-I am not sure yet.
Todd Hodge
Old 07-26-2003, 08:30 PM   #6718
Oasis's Avatar
Yea Loyd is a good guy(one of the better Team drivers)I am getting the handle down on it..esp. after Todd's article in R/C CAR,Huge help.I'll let you know when I'm comming up.
Old 07-28-2003, 08:33 AM   #6719
highwayman's Avatar
Arrow RIDE HEIGHT
do you guys normally set the xxx's-G+ ride hieght the same or slightly higher at the back...
highwayman is offline   Reply With Quote
Old 07-28-2003, 09:22 AM   #6720
Thanks to all that helped with my problems.... I ended up with 60 wht oil in the front with 56 pistons, and 70 wht rear with 55 pistons!! The car was hooked!!! definately faster than anything I have ever driven....
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
