Old 07-20-2003, 08:53 PM   #6676
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by Smartazz07
XXXKat- No in the summer we race asphault in Ripon(at dan's auto body). Then in the winter all of us ripon drivers go to the stockton fairgrounds for carpet racing. I cant get my car hooked up though. The back end Is always sliding and adding a couple seconds on each lap. I heard that for the mains at ripon I should use Front:24's and Rear:20's. SHould I try Blue's all around? Or something else? Like the stock spring set up. XXXkat at what track do you usually race?
take off 27's always are the go to tire at ripon. Hopefully I can make it up there sometime soon to help you out.
Brandon
P.S. I only have som sorex 36's with firm inserts and take off cs-27's which seem to be too hard for the main beacause my tires didnt even heat up until the last lap.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-20-2003, 09:29 PM   #6677
Send a message via AIM to Smartazz07
James, You work at the hobby shop right? I'm not gonna be there next week but I will in three weeks since we have an off week. If you dont remember me I usually ride my bike to the hobby shop and you gave me the sorex 36's.Thank's they helped me alot.
Brandon
Smartazz07 is offline   Reply With Quote
Old 07-20-2003, 09:53 PM   #6678
I am running D.prpl/prpl, arms all the way forward (no extra triming yet), I am also running 40 weight in all 4 shocks with 57/55 pistons. I like the extra cornerspeed the 55's give iwhen used in the back....
I believe I will go 60 weight all around and probably go back to my old plaid/prpl tire set-up....... BTW: I al running 4.5/5mm rideheight.
Adding the extra droop or uptravel as I measure it actually allows the car to transfer extra weight to the front tires......
This week I will ask to borrow the shop tempgun and check the tire temps at the beginning, halfway thru, and at the end of my practice runs to try ad get a better handle on what is actually happening.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 07-20-2003, 10:05 PM   #6679
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
IMPACTPLAYR,
may i ask what springs you are running?
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 07-20-2003, 10:17 PM   #6680
Blue on all 4
Old 07-20-2003, 10:33 PM   #6681
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
IMPACT: i would try spacing the front arms in the middle to get the off power steering you want. i could also try less droop in front (higher on the droop gauge) but would try out the arm spacing first and see how that goes.
also, considering that your car behaves differently through the course of a run, i would tend to think that it may be a tire issue (overheating perhaps?). coz mechanical grip or the grip achieved with suspension/cahssis set-up should not change over a 5 min run unless these are drastically altered or mis-aligned by somthing like a hard crash.
just my .02 cents.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 07-20-2003, 10:53 PM   #6682
Thanks Robo, I will take that into concideration... however I am going to find out what is causing te rear tires to generate more grip as the race goes on.... either the rears are heating up more due to more mechanical grip or possibly the fronts are overheating...but the foams show no signs of overheating.....
Front droop effects on-power steering , rear droop effects off-power.......
Old 07-20-2003, 11:43 PM   #6683
How does it affect it. I'm just starting to expirament with most of this stuff.
Old 07-20-2003, 11:56 PM   #6684
Droop affects weight transfer. in turn affects traction at each end of the car, front droop controlling traction coming out of a corner on power. and rear droop controlling traction coming into a corner off power. also affects the rate at which your car manuevers (sp?) and transfers weight from side to side on cornering.
James Nguyen is offline   Reply With Quote
Old 07-20-2003, 11:56 PM   #6685
ROBORAT's Avatar
i find that adjusting droop settings, like most other suspension components is always a compromise ... meaning you gain one thing at the expense of somthing else. from what ive experienced, less front droop (higher on the droop gauge) makes the car react faster and gives off power steering and doing the opposite or adding more droop (lower on the gauge) makes car react slower but increases on-power steering. so depending on which way you go, more or less droop should give you different steering characteristics.
as for the rear, i find less droop makes the back end rotate faster in corners while more droop gives more bite.
Old 07-21-2003, 04:18 PM   #6686
IMPACT,
ever think about maybe going stiffer on spring??? I mean how low is the traction at your track that you run that soft for foam?
USVTA Member #211
Old 07-21-2003, 04:46 PM   #6687
Traction is great, I have used this same set-up for several months at 3 different tracks and it has worked very well until the temps started being regularly higher....
Also my fronts wear quicker than the rears?? by about 2 mm per 2 racedays..... and then with the tracks running 2 right hand sweepers..... I can't ever get even tire wear from the darn thing.....
Old 07-21-2003, 04:48 PM   #6688
BTW: unlike several other competetors cars I hear almost no tire scrub noise!!! Some sound like a tire truer in the turns!!!!
Old 07-22-2003, 01:20 PM   #6689
mainracer's Avatar
Send a message via AIM to mainracer
just want to know what it will give to me if I use a smaller spur but whit the same ratio so if I was running 31 total with a 128 spur gear what is supose to do if I use the same ratio but whit a 108 tooth !!!!
thanks
mainracer is offline   Reply With Quote
Old 07-22-2003, 01:48 PM   #6690
If its the same ratio it wont change a thing.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
