Old 07-05-2003, 06:32 AM   #6556
ned911's Avatar
Send a message via ICQ to ned911
Its usually the pivot block that start to where causing the slop.
Drilling vs. standard for pistons refers to creating a certain size hole in the piston.
For awhile Losi did not make #57 pistons, so we would buy a 60 (I think - tan piston) and drill the holes with a #57 drill bit. I've also got 556's and 566's which are 56's with 1 or 2 holes drilled with a #55 bit.
Ned
ned911 is offline   Reply With Quote
Old 07-05-2003, 06:37 AM   #6557
highwayman's Avatar
thanks...
so if they're using the #56 piston drilled, it would refer to the number of holes?
highwayman is offline   Reply With Quote
Old 07-05-2003, 06:48 AM   #6558
ned911's Avatar
No, all Losi pistons have 3 holes.
A #56 drilled indicated you created a #56 by drilling out a smaller piston with a #56 drill bit. Not sure why anyone would do this as #56 pistons are quite standard.
Ned
Old 07-05-2003, 07:41 AM   #6559
Registered User
Originally posted by highwayman
what will i replace? changed the arms already...
i noticed that in the setup sheet of some of the pro drivers it says there with regards the shock piston... "standard or drilled" what do they mean if its drilled...
The standard pistons are molded. There may be inconsistencies in the inner diameter of the holes, due to the mold itself. The drilled pistons are drilled out with a sized bit, ie #56.
thatdog is offline   Reply With Quote
Old 07-05-2003, 07:46 AM   #6560
highwayman's Avatar
thanks... so when it says drilled on the setup sheet of the pro's they're just re-sizing the pistons to the exact inner diameter...
Old 07-05-2003, 07:53 AM   #6561
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Actually I have found in every losi piston I checked that there are inconsistancies from 1 to the next, I always just bought #60 pistons and drilled them out. You can also make custom pistons like 56-56-57 for different dampening.
Old 07-06-2003, 05:46 PM   #6562
Korey Harbke's Avatar
Anyone want another xxx-s?
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-06-2003, 06:15 PM   #6563
Send a message via AIM to Smartazz07
How much? what comes with it?
Smartazz07 is offline   Reply With Quote
Old 07-06-2003, 07:11 PM   #6564
Oasis's Avatar
Trader Rating: 36 (100%+)
Smartazz07 I have a G Plus thats really nice,It has everything that you could put on a G Plus(well almost)I have delt with a few people on the RCR board (speedworld)And have good feedback,I live in central Ca.1 to 2 days shipped to no. cal.PM me for more info.And I can get photos.
Oasis is offline   Reply With Quote
Old 07-06-2003, 07:38 PM   #6565
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
as mentioned by highwayman and glide1, the xxxs is by no means obsolete. still has a good representation here at our local track as well (along with TC3s, Tamiya EVO3s, Yok SDs, etc.). and week after week, majority of the cars in the a-main grid are still losi's - be that in stock, mod or spec 19T class.
highwayman: wow, thanks! binobola mo pa ako sa post mo ha! hehehe ... alam mo naman i read this thread. im sure next time you'll be ahead of me. by the way, you guys playing this wednesday? got a hot new set-up for the rockwell track which i worked out last saturday. the car is really hooked now and even more consistent than before. it was really just fine tuning but it made a big difference in terms of handling. cant wait to race it. wish i had this set up in last week's race! i would have defenitly been faster.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 07-06-2003, 08:15 PM   #6566
Pembalap's Avatar
Default Re: spur adapter
Originally posted by ongbenghui
Hi,
Any one try this from jet hobby & precisionrc.com ?
http://www.precisionrc.com/pic/jet/th/th1.jpg
I used the spur adapter, so that I am able to use a regular spur gear. By using this adapter, I am able to tune the gear ratio more closely.
The downside:
Since the profile of the tooth is sligthly differrent to the original pulley, the belt skips a lot under braking.
A.W
Pembalap is offline   Reply With Quote
Old 07-06-2003, 08:59 PM   #6567
Simon K's Avatar
i noticed that the front and rear of my G+ has some play, can this affect handling?
I noticed this too.
Last week I shimmed everything using what was left of my Yokomo shim set. The shims just fit onto the larger inner hinge pins and easily fit the outer ones.
Simon K is offline   Reply With Quote
Old 07-06-2003, 09:59 PM   #6568
Originally posted by Dan
Ah yes, so its not obsolete yet. Just got mines...
So Dan when are you going to come and race with us????
Stlnlst:
Nice talking to you at Speedworld this past weekend.
Sydewynder is offline   Reply With Quote
Old 07-07-2003, 12:04 AM   #6569
Im not looking for one as a serious buyer. I am just seeing how much they would go for now. Sorry.
Brandon
Old 07-07-2003, 01:50 AM   #6570
ROBORAT's Avatar
can anyone help with the thickness measurements of the losi front sway bars? am trying to fill out a set up sheet and this would help. thanks guys!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
