Old 07-02-2003, 05:36 PM   #6526
tufferwilde's Avatar
TRL -
The steel outdrives are part # LOSA 3073 XX - they come one to a package - should be around $7.50 apiece... You will also need LOSA 3072 XX - the diff tube.
These are the standard outdrives and diff parts for the XXX and XXXT's.
As for the changes that the outdrives make - I will find out tonight and post it.
Kevin K -
Thanks again for the WI information!! I should be back in the area in a couple of weeks
Chris Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 07-02-2003, 06:02 PM   #6527
ned911's Avatar
Send a message via ICQ to ned911
Just and FYI. I just added the Nat's setups for Greg Hodapp and Matt Francis to the database.
On the different setups page...
I currently sort the setups by those viewed the most, does anyone care what order they are presented in?
Would you rather have the newest entries ranked at the top? do you want to see the # of times a setup has been viewed?
Ned
ned911 is offline   Reply With Quote
Old 07-02-2003, 08:27 PM   #6528
Simon K's Avatar
I'm not sure if anyones asked this already...
Was flicking through the Todd Hodge setup article(RC Car, May 2003) last night and noticed a couple of blue screw heads on the side of the Transmission tunnel(If you look at the pic on pg 97, the screws are just to the right of the small "Team Losi" sticker above the servo)
Just wondering if someone could please tell me what they're for.
Simon K is offline   Reply With Quote
Old 07-02-2003, 08:36 PM   #6529
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Simon....On TT Todd said that there was a hole there that he made for running his battery wire through the chassis and he just closed it up....he said something like he wanted to be trick or something.....check his TT thread its in there and not too long ago.
Found it here is what he said in reguard to the screws........"HarrisKat-1.I was trying to be trick and run my wires through the chassis....it didn't work. 2. Those blue screws are there to hold the lexan mount for my lap counter."
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-02-2003, 09:16 PM   #6530
STLNLST's Avatar
Trader Rating: 19 (100%+)
Default Re: steel outdrives
Originally posted by TRL
I was just looking at the set-ups from the nats and it says the guys were using steel outdrives! Is this a losi part or is it aftermarket any one got any ideas?
And why do you think they were using them just all that horsepower??
Thanks!
I run the steel out drive's when I run a spool or diff in the front and as of the last 3 months I've run the steel in the rear. I use it as a protection device simular to the trinity out drive covers. They also add a little rotating mass to the drive train which (IMO) helps corner speed slightly.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 07-02-2003, 09:23 PM   #6531
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
there's already been a post made in hodge's thread in TT inquiring about the steel outdrives and what they do. todge should be online soon to answer the question. will post his reply here as soon as comes up.
... im quite curious myself what they had in mind when using it.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 07-02-2003, 10:08 PM   #6532
Simon K's Avatar
Wink
Kevin,
Thanks for that.
Old 07-02-2003, 10:21 PM   #6533
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
I'll let Hodge give you the real scoop on the steel outdrives, but what I think I was hearing while at the nats was that steel outdrives gave more traction. How? I don't know.
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 07-02-2003, 11:09 PM   #6534
The steel outdrives cause more friction which adds traction.... The same reason you would use CVD's on your XXX buggy instead of Losi universals..... I read about this in an old issue of R/C Car it was an ariticle on driveshafts written by Gil Losi Jr.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 07-03-2003, 12:46 AM   #6535
Matt04's Avatar
is this the XXX-S SPORT RTR car and if so is it competitive casue i am looking at getting a new car
Matt04 is offline   Reply With Quote
Old 07-03-2003, 11:02 PM   #6536
Default spur adapter
Hi,
Any one try this from jet hobby & precisionrc.com ?
http://www.precisionrc.com/pic/jet/th/th1.jpg
ongbenghui is offline   Reply With Quote
Old 07-03-2003, 11:17 PM   #6537
Plus the steel ones are way stronger. I've seen the plastci ons snap in half when running a spool, never seen any snap with a diff though.
teamAE is offline   Reply With Quote
Old 07-04-2003, 01:05 AM   #6538
ROBORAT's Avatar
Arrow Using Steel Outdrives
here's what todge has to say about it .... his reply as quoted from trinity tech talk:
Originally posted by Todd Hodge
Skylab-We found that steel outdrives on the front and rear gave our cars more forward grip and made the cars easier to drive. We have also using Team Losi brown grease on the dogbone pin to keep it from binding too much.
Old 07-04-2003, 01:54 AM   #6539
I just happen to have a barely used xx-4 laying around so I will disect it for the diffs, and build a set for my G+...... and try them this weekend....... race report to come...... I'll start with standard plastic diffs, then work my way thru....hmmm ...... steel outdrives just in the front may be the ticket ...... more pull out of the turns it may be ahappy medium between a regular diff and a one-way w/out the off power understeer of a spool?!?!?!?
What do you guys think?? CraigX???
Let's do a little theorizing before the actual test!!!!
Old 07-04-2003, 08:03 AM   #6540
Oasis's Avatar
Trader Rating: 36 (100%+)
Is the XXXS dead..At the track i race at i'm about the only xxxs racer left,when the losi first came out alot of people had them and selling a used xxxs is not an easy task,Question is are you guys still winning with them ?In the area i race at stock is the biggest class and the shaft drive cars seem to be a little better in stock than belt cars..I think it might be time to break out the R2,but I really like my losi's and I dont really want to get rid of them,any tricks on freeing up the drivetrain.
Oasis is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
