Old 06-28-2003, 07:27 AM   #6511
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
ned911
That is an awesome site. Does anyone know how you make pdf files editable (if that's a word ) I have other files in pdf format that I'd love to be able to just edit like that and print.
Jon Kerr is offline   Reply With Quote
Old 06-28-2003, 07:40 AM   #6512
ned911's Avatar
Send a message via ICQ to ned911
Thanks for the feedback.
To make the PDF's editable you need the full version of Acrobat.
Please fill out the sheet and submit as I need someone else to test other than me Just to make sure the site will scale.
I'm working on the XXX-T now and should have that working by Sunday evening. Then I'll do the XXX-4. If there are other setup sheets setup a poll in the forum and if enough people want them added I will do it.
Ned
ned911 is offline   Reply With Quote
Old 06-28-2003, 10:08 AM   #6513
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by ned911
I just setup a database to keep track of my setups. The input form is the Losi XXX-S G+ setup sheet in PDF.
Can also retrieve setups from the db and print the setup sheet.
If you could please help me test this at http://www.losiboard.com
XXX-S sheet is on the OnRoad page.
Tuff - say hi to Scotty and Thielke for me and if you see Richard Lake smack him. It's been about 6 years since I ran at SRS.
Ned
great job on the set up sheet. When I have more time later on tonite I'll check out the rest of the website. Looks good so far.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-28-2003, 11:35 AM   #6514
ned911's Avatar
Thanks STLNLST.
I just got tired of loosing setup sheets or having them get abused at the track. With this system I'll never loose another sheet again.
Ned
Old 06-28-2003, 01:50 PM   #6515
Ned,I tried to set up a sheet,wouldnt take it.I emailed it to you
Thanks,Brian Jucha
BrianJ is offline   Reply With Quote
Old 06-28-2003, 09:13 PM   #6516
ned911's Avatar
Brian,
Thanks for trying to enter your setup. Learned something - can't use single quotes anywhere on the form. This is why I wanted someone else besides me trying this out - to find potential problems.
I'll put a note on the page about using quotes.
Ned
Old 06-29-2003, 05:53 PM   #6517
STLNLST's Avatar
Brian,
Ned
I played with the set up sheet today and these are the things that I noticed. On the ride height and droop height areas you can't list your settings as 3mm. It will make 3 come out to 3.00 which really isn't a huge problem. In the notes section for the front of the car the cursor clicks on in the middle of the lines. It won't allow you to type any info on the provided lines. Thanks again for giving XXXS users an editable printable set up sheet.
Old 06-29-2003, 07:01 PM   #6518
ned911's Avatar
Awesome feedback.
I'll fix the ride height and droop fields ASAP. Not sure how to handle the notes area - it's a DB limitation - but I'll look into that as well.
I added the XXX-T setup sheet today.
Ned
All of your points have been implemented!!!! Took a minute to figure out the multi-line text area but it is now available on the XXX-S form. And I am about to change the XXX and XXX-T forms.
Ned
Old 06-29-2003, 08:33 PM   #6519
STLNLST's Avatar
Awesome feedback.
Ned
Ned
Ride height and droop problems are solved. Man you're quick.
Old 06-29-2003, 09:39 PM   #6520
tufferwilde's Avatar
Ned
Ned - Will do! We were actually down in Tucson this weekend racing the last leg of their points series (I got to fight phantom tweak issues all weekend... but it was fast as ___ in a straight line!) I will probably see Brent on Tues (he's on here as 51) and I Rich is going to try to make a run to SRS this weekend too - What is your last name? I will say hi to em for ya
btw - site looks good!
Chris Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 06-30-2003, 01:02 AM   #6521
highwayman's Avatar
Ned
great site dude...
highwayman is offline   Reply With Quote
Old 06-30-2003, 05:39 AM   #6522
ned911's Avatar
I am glad everyone is enjoying the site (it was a lot of hard work). If there is something missing please feel free to pass your request along. Best place is on the forum (http://www.losiboard.com/forum) so we don't clog up this discussion.
Chris,
Last name is Cullen. Richard will remember me (tell him to make Troy get a 12th scale) as we are still pretty close friends. Depending on my race schedule (1:1 scale car - check the avatar) and vacation I may try and make it out to AZ in the fall. Does SRS still run the Peak race in early December?
Ned
Old 07-02-2003, 02:59 PM   #6523
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
TTT
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-02-2003, 05:04 PM   #6524
TRL
Default steel outdrives
I was just looking at the set-ups from the nats and it says the guys were using steel outdrives! Is this a losi part or is it aftermarket any one got any ideas?
And why do you think they were using them just all that horsepower??
Thanks!
TRL is offline   Reply With Quote
Old 07-02-2003, 05:22 PM   #6525
Kevin K's Avatar
I think that you can get the steel outdrives from the gas truck. I have a set of them but they are from the XX days.
The only reason I can think of them using the steel outdrives is to change the way the CVD slides in and out of the outdrive. I know that with off road cars the Losi guys play with this alot sometimes they use sliders or plastic or steel outdrives. I think it effects the way the suspension moves, with steel outdrives the CVD is easier to move...plus they are stronger. This would be a question to ask Todd Hodge on TT or if he reads this maybe he can tell us why. I know with the street weapon they ran sliders in the back alot of times to increase traction I would think the Steel outdrives are doing something like that but what Im not 100% sure.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
