Old 06-22-2003, 06:26 PM   #6481
lazyboy's Avatar
Send a message via AIM to lazyboy
Originally posted by dan-o
Has anyone had any luck with carpet (ozite) set-ups yet? Our indoor season is around the corner and a set up or suggestions would be helpful. Any word on the one-way yet?
Thanks and in one day this thread has more action than any....... Must be alot of TC3's for sale... he he he .
yea i run carpet year round with a xxxs and im running a monster pro with the blue 118 spur ggear and a 29 pinion i think and for the shocks and springs im running a 40 front and 30 back with purple front and sivler back (stock springs and oils for xxxs G+) and fron sway bar i think its the second smallest and the smallest for the rear. if the car does work for u just send me a message and ill try to help u out with any questions.
lazyboy is offline   Reply With Quote
Old 06-22-2003, 06:33 PM   #6482
lazyboy's Avatar
Originally posted by Axiom5B
Get 25 lb blacks, 30 lb whites, and 35 lb orange
for oils get from 50-70
so whites front and blacks rear with 70 in the front and 50 in the rear??
Old 06-22-2003, 06:34 PM   #6483
STLNLST's Avatar
Trader Rating: 19 (100%+)
lazyboy- The blue spur gear is the 128 tooth.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-22-2003, 06:46 PM   #6484
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
That would work, be kinda pushy, but would work. What i meant was to get shock oils between 50 and 70 (i.e. 50, 60, 70). Check your email .
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-22-2003, 07:14 PM   #6485
lazyboy's Avatar
oh ok so just try those springs and oils till i get a setup that works?
Old 06-22-2003, 08:43 PM   #6486
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally posted by Kevin K
Or you could just use one long screw with a mini lock nut on the other side....it seems to hold everything better then the two screws. I always had one of the screws loosen up on me after I did this I never had that happen again. Just be carefull not to tighten the nut or the screw too much and pinch the gear between the chassis sides.
KevinK: great tip. might actually try that. when i find a long enough screw. but so far no more stripped spur since i changed the top shat. must have been miss aligned. thanks!
glide1: dynamite has some and so does trinity under the Matt Francis line (dunno the part numbers though). however, if your objective is to make the losi wider, i think you'll have to go with the AE hex's - not sure if the two mentioned above will do the trick. as mentioned by STLNST, yoke make some in clamp style and they should make you come close if not right at 190mm. hope this helps.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 06-22-2003, 08:54 PM   #6487
glide 1's Avatar
Default Robo,
Thanks, have the tc3 hexes to try. It should be close to 190mm.
glide 1 is offline   Reply With Quote
Old 06-23-2003, 01:04 PM   #6488
UR
Default flipped steering
any ideas how "flipped" mounted steering affects handling?
UR is offline   Reply With Quote
Old 06-23-2003, 05:10 PM   #6489
Default Re: flipped steering
You really only need to flip and move the bellcranks foward if you lengthen the wheelbase by moving the front arms foward.When you move the arms foward this changes the ackerman,by flipping + moving the bellcranks foward helps maintain the same ackerman you had before in the stock position with the arms spaced in the middle.
BrianJ is offline   Reply With Quote
Old 06-24-2003, 04:48 PM   #6490
tufferwilde's Avatar
BrianJ -
How are the setups on the Losi site for normal running at Trackside?? I am going to move up there in a couple of weeks... and I doubt that my setup from SRS is a good place to start!
Thanks in advance -
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 06-24-2003, 05:00 PM   #6491
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Tuffer.....Im not Brian but any of the Foam tire setups should work on his carpet track or be a good place to start. If there is a setup from the Novak race this year that would be the place to start if you are going to be racing rubber tires on carpet. Just to let you know there is not too much racing at Trackside during the summer most people race outside. If you need more info check out the Wisconsin and Illinois fourms thats where most of the goings on in the area are talked about. And if your moving to Wisconsin....Im sorry.....J/k. Trackside is a hot place to race at in the fall and winter with 50 or more guys on any given sunday. There are some other tracks that are in Northern IL. that are not more then at most 2 hours from Trackside to check out as well.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-24-2003, 06:15 PM   #6492
Tufferwilde-this is the set-up I use @ Trackside and the 2003 carpet nat's
Front end:
toe:0
ride height:4mm
camber:1 degree
carrier:6 degree
sway bar:.080
front shocks:50wt
piston:60 standard
spring:Trinity congo purple
limiters:inside-0/outside:.120
shock length:62.4mm
droop height:4(measured off arm w/losi gauge)
pivot support:OF(in lower holes)
arm spacing:foward
ackerman:back(standard)
camber ball stud:chrome
pulleys:42/42
shock position:#2
camber link position:#2
roll center:losi low
Front diff TIGHT!
AE hex's
REAR:
toe:1.5
ride height:4mm
camber:1 degree
no sway bar
shock oil:60wt
piston:#56(standard)
spring:Trinity congo blue
limiters:inside:0/outside:.120
shock length:66.3mm
droop height:3.5(measured off arm w/losi gauge)
pivot support:2R
arm spacing:back
camber link position:1-B
shock position:#3 on tower/outside on arm
off-set hubs(1/2 degree's backwards)
roll center:low
AE Hex
KT Hobbies steel bottom cover(adds about 1.5 oz.)
Tires:TRC Cyan front/magenta rear(old mesh wheel)use losi hex in back if you are using the new GRP or Jaco wheel
Tire size:57.5mm
battery foward
used TL Alfa body/type A wing/body height:112mm
Good luck,looking foward to meeting you @ Scotty's
Brian Jucha
Old 06-24-2003, 10:55 PM   #6493
Send a message via AIM to Smartazz07
What does a oneway do? How does it affect your car? When should I switch to a oneway from a diff(like when I start winning)?
Smartazz07 is offline   Reply With Quote
Old 06-24-2003, 11:00 PM   #6494
Kevin K - Thanks for the info!! What are the hot tracks to race at in the summer?? Most of my experience comes from asphalt racing and off-road (buggy and truck) at SRS in Scottsdale AZ... funny thing is that out here, the attendance numbers are a little bit like Trackside... 120-130 on a Sat in the cooler months and 70-80 in the summer (those of us who are hard-core... or nuts since the temp is well over 100...) - Any information that you can provide for some summer racing would be great! I will most likely set up shop on the north side of Milwaukee...
As for the foam setups - I thought that Trackside only allowed rubber for most of the year...
Brian J - Thanks!!! The last couple of times I have visited over the holidays I was hurting since I never had much time to wrench on the car while visiting the family... not to mention the fact that it's a little colder there and I didn't want to spend any more time in the garage than needed. As for the springs - Do you know which poundage the Trinity congos are?? I haven't been able to get my hands on them, but I have the full compliment of Losi springs. And regarding the LRC up front - are you talking about the piece that comes with the G+, or the true Losi LRC.
Thanks again!! See you guys soon - should be there some time mid July or early August
Chris Wilde
Old 06-24-2003, 11:04 PM   #6495
Send a message via AIM to ZER01
A oneway makes the front tires freespin "off-power" FASTER than a diff or even a spool with no diff action or spool action what-so-ever. This creates HUGE amounts of "off-power" steering and more amounts of "on-power" steering than a diff as it will act as a spool "on-power".
ZER01 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
