Old 06-19-2003, 12:58 AM   #6466
Pembalap's Avatar
Originally posted by losi jon
Hey guys, I race with Mimno and his problem seems to be drivetrain related, so any idea's on what may be causing it would be most helpful.
His motor's and electronics are going fine in his MR4TC and he knows how to gear properly, when on the track it just seems like he's running a stock motor when everyone else is running a mod.
The car doesn't pull to one side so it doesn't seem related to one particular side or corner of the drive train, he's tried various belt tensions, at the moment it's just slack enough to make the usual XXX-S belt slipping sound under hard braking. His diffs seemed slightly tight when I fealt them but not hugely so, not enough to slow him down so much anyway.
There isn't any excess noise from his car on the track, so gear mesh seems fine, could a badly moulded spur gear still cause problems?
He's rebuilt the car atleast once so I would of thought he would notice any obvious problem, he's an engineer so knows how to build stuff too I hope
check to see if the spur is rubbing up against the tensioner,i had this problem and talked to todd hodge,he found it and had me put a shim in between the two.
I think you might want to try to remove the motor first, and then try to push the car on a flat surface. It should be very free. If it's not free...there might be somethin wrong in the drivetrain.
I suspect it might be a faulty bearing. Another thing is that you might also want to check the spur gear assembly.....the shaft holding the spur gear might be too short. So that when it is installed in the chassis, the spur gear does not rotate freely.
A.W
Pembalap is offline   Reply With Quote
Old 06-19-2003, 01:29 AM   #6467
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally posted by ongbenghui
Great! you might want to use some thread lock on the screws such that the screws that secure the top shaft wouldn't come lost.
Or you could just use one long screw with a mini lock nut on the other side....it seems to hold everything better then the two screws. I always had one of the screws loosen up on me after I did this I never had that happen again. Just be carefull not to tighten the nut or the screw too much and pinch the gear between the chassis sides.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-21-2003, 07:50 AM   #6468
Default gear alinment
Kenin K.--That sounds like a very good idea.
Simple fix for a simple problem,I have not had the gear
problem-but have seen the screws back off.
I might try it on my xxx4 @ this week end s off road race,
Thanks for the idea!
SrRC is offline   Reply With Quote
Old 06-21-2003, 08:26 AM   #6469
glide 1's Avatar
Default Track Width with TC3 hexes...
Originally posted by GKC
For those using the TC3 wheel hexs, what is the part number of the part to use for tamiya type of wheels?
What is the trackwidth when using tc3 hexes? We run rubbers and following the setup on the manual (inner holes on the rear arms), i get a width of 186mm. Hope it is closer to 190mm and not over. Thanks in advance.
glide 1 is offline   Reply With Quote
Old 06-21-2003, 08:49 AM   #6470
STLNLST's Avatar
Trader Rating: 17 (100%+)
Default Re: Track Width with TC3 hexes...
It should be pretty close to 190. I haven't measured it but my car has never failed tech inspection with the AE hex's on.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-21-2003, 08:51 AM   #6471
LouisB's Avatar
I think they are exactly 2mm wider than the stock Losi ones, bringing it up to 190mm.
LouisB is offline   Reply With Quote
Old 06-21-2003, 11:21 PM   #6472
glide 1's Avatar
Default STLNLST, LouisB
Thanks, i'l give them a try. Also, are there aluminum hexes like the yoke (pin and o-ring type) that would fit the losi?
Old 06-21-2003, 11:35 PM   #6473
STLNLST's Avatar
Yokomo has those types....I think that they are called E-Z hubs. It's up to you which one's you want. I like the clamping (non O-ring) stlye hubs myself.
Old 06-21-2003, 11:39 PM   #6474
Koya Dale.com's Avatar
Send a message via ICQ to Koya Dale.com
glide 1: i used to have one of those in my losi. their made by dynamite
Koya Dale.com is offline   Reply With Quote
Old 06-21-2003, 11:43 PM   #6475
glide 1's Avatar
Default Clamp type hexes
Thanks STLNLST, Koya
Old 06-22-2003, 08:24 AM   #6476
highwayman's Avatar
i have those now, the red ones made by dynamite, will those make my car wider, like using the TC3 hex?
highwayman is offline   Reply With Quote
Old 06-22-2003, 09:59 AM   #6477
Send a message via AIM to jrnitrocars
Default Matt Francis xxxs
Anyone interested in buying a xxxs Matt Francis Edtion in very good condition! I got a few extras I could throw in! DJ
jrnitrocars is offline   Reply With Quote
Old 06-22-2003, 10:51 AM   #6478
lazyboy's Avatar
Send a message via AIM to lazyboy
xxxs
yea i bought a xxxs G-plus about mid march and have been running stock rubber ever since, and was woundering what kind of springs i could use to run foam with.? i had my tc3 running foam but got tired of all the problems of have a 2 owner car. so im open for suggestions on sorings a or oils for the shocks.
lazyboy is offline   Reply With Quote
Old 06-22-2003, 10:55 AM   #6479
lazyboy's Avatar
Post foam set up for xxxs G-plus
Old 06-22-2003, 10:55 AM   #6480
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Get 25 lb blacks, 30 lb whites, and 35 lb orange
for oils get from 50-70
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
