Old 06-09-2003, 03:57 PM   #6361
A little anti-seize will do the trick!
BrianJ is offline   Reply With Quote
Old 06-09-2003, 04:35 PM   #6362
GKC
GKC's Avatar
Send a message via ICQ to GKC
Thanks for the suggestions on the screw kits, will check them out. Thanks a lot!
GKC is offline   Reply With Quote
Old 06-10-2003, 02:59 PM   #6363
Default hpo up parts
I was wondering if anyone of you know a onlineshop that sells hop up parts for the xxx-s. Trinity and fastrax
sturla is offline   Reply With Quote
Old 06-10-2003, 04:33 PM   #6364
Oasis's Avatar
Trader Rating: 36 (100%+)
Dynamite makes better parts for the xxxs than trinity,I have bought both and found that not only are the Dynamite less money but hold up alot better,The trinity rear alum. hubs break and the front end parts bend.Speed tech also makes some really nice stuff for the xxxs their web site is www.speedtechrc.com
Oasis is offline   Reply With Quote
Old 06-12-2003, 02:45 PM   #6365
ever since i put my graphite chassie on my car has been gitching i have tryed every thing to get it to stop gitching but nothing worked i am about to take off my grapite chassie is there any reason it might be the chassie
pro3user is offline   Reply With Quote
Old 06-12-2003, 02:47 PM   #6366
Trader Rating: 19 (100%+)
did you use the chassis tape between the battery pack and chassis tunnel side?
MDawson is offline   Reply With Quote
Old 06-12-2003, 02:49 PM   #6367
no where do u get battery tape
Old 06-12-2003, 02:54 PM   #6368
You can use Associated Chassis Film. Cut a strip of it, adhere it to the chassis wall next to the battery. This will prevent any effect that contact of the battery may have that may cause glitching.
Glitching can be a hard thing to trace. This is one of the things that has been done to prevent any chance of it.
Old 06-12-2003, 03:48 PM   #6369
Pro3- you can use electrical tape, cover anywhere any non- shrink wrapped parts of the cell are close to the chassis.....
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-12-2003, 03:59 PM   #6370
Be careful when you tape a cell like that- the cells should allowed to let heat escape. If the factory cell wrap is ripped and exposing bare cell, consider using new cell shrink wrap.
Old 06-12-2003, 04:23 PM   #6371
Oasis's Avatar
Did you lay your reciver flat? If so put it on it's side,Thats all i did and the glitching stoped.
Old 06-12-2003, 04:59 PM   #6372
I was teling him to use tape on the chassis instead of buying the Associated stuff as suggested in this post........
I would nver use tape on my cells... it just looks hack.....
Old 06-12-2003, 05:00 PM   #6373
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Also, try to keep your receiver wire from touching the chassis. This includes the antenna tube holder.
When I had glitching problems last summer at the outdoor track, I put a hole in the tube about 1/2 an inch above the holder, and fed it through there instead of the tube holder. It kept it away from the chassis.
I used a XXX-main graphite decal sheet on my x-s, before the GP+ came out. It will insulate your chassis, and look trick at the same time.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-12-2003, 08:02 PM   #6374
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
I used fuel tubing to feed my antenna through. This also kept it from getting in contact with my chassis.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-12-2003, 09:35 PM   #6375
Pembalap's Avatar
Or, you can move the receiver on top mof the steering servo, so that the distance to the motor is greater. It eliminates the glitch on my XXX-S GP.
Andreas
Pembalap is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
