Old 06-08-2003, 03:36 PM   #6346
GKC
GKC's Avatar
Send a message via ICQ to GKC
Is there any other screw sets that is out there for the XXX-S other than Trinity? Even the stock screws that comes with the kit will do, need them as spares. Thanks!
GKC is offline   Reply With Quote
Old 06-08-2003, 04:00 PM   #6347
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
If you want cooler looking, stronger screws, contact TheBarber, or send an email to [email protected]. Barber Racing makes Stainless steel screw kits for TC3, and XXX-S. They look great
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-08-2003, 10:24 PM   #6348
ausracer's Avatar
does losi sell a graphite plus conversion kit. i want to stock up on parts but i think it would be cheaper to buy a kit and sell the main chassis.
i know they have a graphite converson kit with the old parts, i want to know if they bought out a new one for the gp.
ausracer is offline   Reply With Quote
Old 06-08-2003, 10:37 PM   #6349
yes they do, I think it might be a running change. Might want to look at Losi's website for more help. www.teamlosi.com
teamAE is offline   Reply With Quote
Old 06-08-2003, 10:51 PM   #6350
ausracer's Avatar
so are you saying that if i order this https://www.ssl-stormerhobbies.com/c....pl?pn=LOS9650 it will actually come with the gp chassis, gp arms and gp shock tower not the parts pictured.
Old 06-08-2003, 10:53 PM   #6351
I would check with losi first. Look on the web site and send them a email
Old 06-08-2003, 11:01 PM   #6352
ausracer's Avatar
i looked on the site and couldnt find much, ill send them an email.
thanks for your help.
Old 06-08-2003, 11:19 PM   #6353
rcdougie's Avatar
I just finished bulding my xxx-s g+ and am kinda stumped on the final diff setting. The manual stated to look in the back under tech tips but there is no mention of a final diff (in the car) setting. Is it something simple like turn the diff screw all the way in and back off half a turn? Can anyone offer any advice?? Thanks!
rcdougie is offline   Reply With Quote
Old 06-08-2003, 11:32 PM   #6354
Pembalap's Avatar
I think Stailess Steel would be heavier than the stock steel screw. So, what's the point of changing them other that looks cool.
I am trying so hard to reduce the weight of My XXX-S G+ to the 1500grams....
A.W
Pembalap is offline   Reply With Quote
Old 06-09-2003, 12:19 AM   #6355
highwayman's Avatar
losi diffs are very different from TC3, the process you mentioned doesn't apply to the losi, the most important thing here is that your diffs do not slip.
now that the diffs are installed, the way i check is this... hold the rear tires with your elbows, your hands should be within the front tires, now hold the rear tires with your elbow, and turn the front tires at the same time, if the front tires rotate easily, tighten your diff... do the same for the rear.
highwayman is offline   Reply With Quote
Old 06-09-2003, 06:00 AM   #6356
Oasis's Avatar
Trader Rating: 36 (100%+)
The stainless is about the same as stock weight wise,If you want lighter go with the Ti. screw kit and ball studs.I have my car down to 51.4 oz,I think thats under 1500 grams.. but its not cheap.
Oasis is offline   Reply With Quote
Old 06-09-2003, 10:13 AM   #6357
Send a message via AIM to M Ignacio
www.speedtechrc.com www.kthobbies.com
They both have titanium screw sets from Titanium Racing for the XXX-S.
M Ignacio is offline   Reply With Quote
Old 06-09-2003, 11:02 AM   #6358
Titanium is cool too, but if you have alum. parts they're a no no, i hear they fuse together. As said before, stainless steel will be a bit stronger than the stock ones too, as well as looking great. KT hobbies stocks them too.
USVTA Member #211
Old 06-09-2003, 12:30 PM   #6359
guru rc products has some awesome stainless steel screws and they are pretty much dirt cheap. 12 bucks for the xxxs set. email him at [email protected] no missing screws or anything and you even get motor screws
ernieball is offline   Reply With Quote
Old 06-09-2003, 01:36 PM   #6360
I don't think this is much of an issue with a xxx-s, but you can use a film of grease to prevent it. It's a bigger issue with titanium mountain bike parts (which I have a few of) because you tend to put them on, ride in bad conditions and never move the parts.
dicey is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
