Old 06-02-2003, 11:25 PM   #6301
Thanks a lot to everybody! I see that the "air gap" is matter of discussion for all...Anyway I will try both the solutions (with no air gap and with a lot of) on the track, I believe vent holes can help, and possibly careful driving!
EddiRossi is offline   Reply With Quote
Old 06-02-2003, 11:39 PM   #6302
Oasis's Avatar
Trader Rating: 36 (100%+)
Good Job! I'm going to race the next big one at speedworld (sept).See you guys then.
Oasis is offline   Reply With Quote
Old 06-02-2003, 11:46 PM   #6303
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
wats the advantage of this car over the yokomo sd n tb evo3 n trfm2?
cHckbOY5 is offline   Reply With Quote
Old 06-03-2003, 03:33 AM   #6304
LouisB's Avatar
it's very strong and doesn't get tweaked.
LouisB is offline   Reply With Quote
Old 06-03-2003, 04:44 AM   #6305
STLNLST's Avatar
Trader Rating: 19 (100%+)
it also finishes races. Just like every other car when it first came out it had a few bugs but they were addressed and the car a better because of it. The SD is an improvement over the SP (I'm being told) but IMO the car still isn't as consistent as the Losi. If your car is dialed one weekend and you race that same track with the same layout the following weekend the car should work right????? I'm not seeing that with the Yok. That has always been the case with Yok. When the car works it's hard to catch with a good driver behind the wheel. I'd lay off of the SD for about another two months so that some of the bugs are worked out.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 06-03-2003, 05:39 AM   #6306
ned911's Avatar
Send a message via ICQ to ned911
Got the right shock bodies and shafts on the rear. I'll double check the droop screws when I get home from work. Which I should do because I just rebuilt the shocks.
Another question. We used to run the Street Weapon and Yoks with 60-80 wt shock oil. 35/30 seems awefully light in the XXX-S.
Can someone explain why the lighter oil.
Ned
ned911 is offline   Reply With Quote
Old 06-03-2003, 04:43 PM   #6307
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I agree with STLNST that the Yok is more inconsistant. From experiance I run at an indoor asphalt track and my XXX-S G+ works the same everyweek no matter what the temp of layout is. My Yok was fast but every week I would have to mess with it a little to keep it fast and consistant. If I had to change foams to another set it was worse even if they were the same compound tires. I really like the new SD but I think I would wait a little to see if they make some minor changes to make it more of a consistant car.
We had two guys show up last week with the new SD and it is a nice looking car and worked fairly well. The guys liked them but said the same thing that they were inconsistant but when working were pretty fast.
Old 06-03-2003, 05:56 PM   #6308
cHckbOY5's Avatar
wats bad about the xxx-s g+?
Old 06-03-2003, 05:57 PM   #6309
ned911's Avatar
Double checked the shocks to make sure the long shafts were in the long bodies, OK.
Lengthened the shocks to no effect. I'm starting to thing the oil is just to thin to hold the car up. I'm running an old Teking 411-G2 which is pretty big and heavy for today's standards.
Ned
Old 06-03-2003, 06:22 PM   #6310
Send a message via AIM to Smartazz07
NO if he did mix them up his ride hieght problem would be in the front. Ive never heard of people having problems with rea ride height!?
Smartazz07 is offline   Reply With Quote
Old 06-03-2003, 06:28 PM   #6311
sorry i didnt read ahead
Old 06-03-2003, 07:02 PM   #6312
Oasis's Avatar
It's ugly..
Old 06-03-2003, 08:38 PM   #6313
STLNLST's Avatar
Ned
THe thinner oil really helps the car. To thick of an oil will make the car less responsive and may push really bad when you need it to respond quicker. This past weekend at the Speedworld Cup we were running 40wt oil with 56 pistons. Try the car your way and then try coming down in oil some and see how you like it. What works for me may not work for you and vice versa. What spring do you plan on running with the thicker oil? Please keep us updated on what you find out.
Old 06-03-2003, 11:14 PM   #6314
stumper1's Avatar
R/C Tech Charter Subscriber
Default Rear ride height....
I had a similar rear ride height problem. I had a hard time getting 5mm on my setup board so I switched to 1.15" rear springs. That fixed the problem but I also noticed that it only appeared on a freshly built car and seemed to get better after I ran it a few times.
Good luck.
stumper1 is offline   Reply With Quote
Old 06-04-2003, 09:56 AM   #6315
ned911's Avatar
Since I always start with the box setup I haven't actually tried the heavier oil yet. There are no racing oriented LHS's in the Austin area so I will have to start with the kit springs.
Shock setup is such - front: 35 wt, purple springs
rear: 30 wt, silver springs
I chose the oil based on the Ready setup. Also, our track is not located near a LHS so this first weekend will be based on what I got.
Ned
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
