Old 05-28-2003, 03:12 PM   #6256
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Default XXX-S G+ Very Nice *Cheap*
No selling is allowed outside of the For Sale forum -- that includes links to the Sale forum.
ChristopherKee is offline   Reply With Quote
Old 05-28-2003, 03:23 PM   #6257
highwayman's Avatar
How does the IRS dawg bones compare with the steel and or aluminum ones? are they more resistant to bending, wear and tear, etc...?
highwayman is offline   Reply With Quote
Old 05-29-2003, 04:52 AM   #6258
OK I'm a dummie head. What are pin cushions?
chefo88 is offline   Reply With Quote
Old 05-29-2003, 05:47 AM   #6259
Ortiz's Avatar
Chefo,
Most dogbones have a pin going trough it to keep in place when put in an outdrive. Most of them are made of some type of metal. When we mean pin cushion, it just means that instead of just metal, they put a rubber sleeve over the metal to help prevent dents or divets to the outdrive. IRS is one company that makes dogbones with a pin cushion, and I beleive they sell the pin cushion seperately also. Here is pic to sorda show you!!
Ortiz is offline   Reply With Quote
Old 05-29-2003, 05:51 AM   #6260
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
highwayman IRS Dawg Bones are red in color and are thicker than the stock MIP alum bones that come with the G Plus. They come with the pin cushins are already in for you and come with spares. They are aluminum si I would imagine they could bend just like any other alum bone but mine are wearing great but I don't normally take big hits to the walls so this will help keep them straight.
Pin cushins are rubber covered dog bone pins that replace the stock pin on your bone. They keep from digging into your outdrives. Check out the IRS website and go under XXX-S section and they have pictures of their stuff. You will get a great look at them and see what I mean. After using their bones with the cushions in I would not go back to stock setup again.
Old 05-29-2003, 10:54 AM   #6261
Send a message via Yahoo to hicheef
Default G+ Steering Slop
I know a while back this was discussed and probably discussed on several occasions but scanning this thread for this could be time consuming. What is the fix for steering slop in the XXX-S G+??
Just seems to be a lot of play in the front end. Any input is much appreciated!!!
KEVIN
hicheef is offline   Reply With Quote
Old 05-29-2003, 01:26 PM   #6262
Not to be smart, but if you have slop in your G+ steering you either need to build it right or replace some seriously worn ball cups and/or c-hub bushings......
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-29-2003, 01:54 PM   #6263
R/C Tech Founder
R/C Tech Charter Subscriber
Most XXX-S cars that I've seen, even brand new ones, seem to have a bit more play in the steering than other cars I've seen. I'm not sure how much it affects performance, but it's rather annoying to notice.
I would start with shimming everything to reduce play in the arms, carriers, and so on, and then replacing ball cups where necessary. You probably won't get it to be perfect, but there's always room for improvement.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 05-29-2003, 07:22 PM   #6264
wyd
Tech Legend
wyd's Avatar
The car needs a little slop so the car can track straight so leave a little slop in the car. I remember looking at Tossilini's car when he ran for Schumacher. The car he drove and won with at the Nats had a fair amount of slop. My Schumacher was alot nicer looking overall and had alot less slop. One problem is I'm not a national champ and he is. He didn't seem to worry about it so I don't worry about it as much as I use to.
My G+ has some steering slop but it don't affect my performance in any way.
Old 05-30-2003, 05:21 AM   #6265
Originally posted by Ortiz
Chefo,
Ortiz, Thanks for the info!
Old 05-30-2003, 05:34 AM   #6266
Default Spool?
I would like to some feed back on some drivers that have
used the spool. what it did & did not for you?
& are you running it now? Thanks
Old 05-30-2003, 07:45 AM   #6267
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I ran one at the Reedy race and am still running it. They give awesome pull coming out of the corner and through the sweepers. You just need to tune some extra turn in into the car. I talked to Matt Francis at the Reedy race and he likes to run all four corners equal as far as the dampning and springs when running a spool.
Jon Kerr is offline   Reply With Quote
Old 05-30-2003, 02:27 PM   #6268
highwayman's Avatar
Would you know, if he ran different springs with a one way?
Old 05-30-2003, 04:02 PM   #6269
Jon Kerr's Avatar
I'm not sure but I did hear someone say he dosen't normally run with a oneway anyways. He was running purples all around with 50 wt oil and 56 pistons. I'm not sure if he was running a swaybar or not but he didn't say anything about mine having the swaybar on.
Old 05-31-2003, 12:01 AM   #6270
STLNLST's Avatar
Trader Rating: 19 (100%+)
Matt doesn't use a oneway. He still had his diff in the car practicing today for the Speedworld cup. Most of the Losi guys came down for this weekend's race.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
