Old 05-22-2003, 07:20 PM   #6226
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally posted by ROBORAT
ttr: either add more caster or use a thinner sway bar up front (if you're using one at all). its a bit difficult to say not knowing what your set up is but generally the stuff i mentioned are what help the car rotate better around the middle of a corner.
as mentioned earlier to ttr, you may want to consider what i mentioned to him. with regards to my set up at your track, i was much softer in terms of spring settings. i was using silver all around, 40wt oil, 56 pistons. i would have gone up to blues all around if only i dint forget to bring them with me (yet another blooper). if you aren't using a sway bar, you may want to try moving one hole in on the front shock tower. this will make the front of the car roll more in the middle of the corner. it may compromise transitioning a bit but it might help solve your problem. you may also want to go up one spring rate in the rear - if you're using the stock silvers, go up to blue.... but change only one thing at a time. hope this helps.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 05-23-2003, 04:14 PM   #6227
chef088's Avatar
Does anyone no how many teeth
the blue spur gear is in the XXXS?
chef088 is offline   Reply With Quote
Old 05-23-2003, 04:30 PM   #6228
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
The 64p is 128 teeth.
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 05-23-2003, 04:38 PM   #6229
STLNLST's Avatar
Trader Rating: 19 (100%+)
ASM- Lomg time no talk. How's life treating you? Are you still working for HPI or is that old news? Goood to see that you're still around. I'm off to the Reedy race now.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-23-2003, 05:00 PM   #6230
chef088's Avatar
Thanks ASM I called losi & they
told me to count the teeth
They didn't know. My eyes are good
but not that good!
Old 05-23-2003, 08:51 PM   #6231
glide 1's Avatar
Default Robo
Thanks, i'll be trying out new things this weekend, mainly suspension and shock angles etc. keep you posted..
glide 1 is offline   Reply With Quote
Old 05-24-2003, 04:36 AM   #6232
Default XXX-4 chassis for XXX-S
Hi,
Can I use XXX-4 chassis for XXX-S ?
I like the graphite chassis without much milling.
ongbenghui is offline   Reply With Quote
Old 05-24-2003, 05:12 AM   #6233
LouisB's Avatar
The XXX-4 chassis is about 1/2" longer, so only if you want a really long touring car.
LouisB is offline   Reply With Quote
Old 05-24-2003, 05:47 AM   #6234
XXX-S LIMO!!!!!! Yeeee Haaaaa!!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 05-24-2003, 06:11 AM   #6235
LouisB's Avatar
Other than the probelm of belt tension (too much) i s'pose it could be a sneaky tuning trick for really big tracks
Old 05-24-2003, 07:37 AM   #6236
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
The XXX-4 Belt would fix that.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-24-2003, 09:13 AM   #6237
LouisB's Avatar
Would it? I thought that the spur gear (slipper) pulley was a different size on the XXX-4 but it might be within the range of belt tension adjustment, and you've got to use a stiff green belt.
Old 05-25-2003, 07:13 AM   #6238
ROBORAT's Avatar
glide1: let me know how what you end up with and if the suggestions i had worked. another thing you may wan to try is using the low roll center blocks (which are actually mid roll). i am assuming you may have followed the instructions to use the hi roll one's instead. but if your on the low roll already, moving one hole in in the front tower could work. oh, just to clear things, are you using a sway bar up front? ... oh, i finally i ran my new g+ over at the carpet track here in rockwell. the car was hooked. my new set up seemed to give a bit more corner speed without my rear coming loose. the car felt more consistent too. will be trying out the otional ackerman setting as well to see how they affect handling. will let you know how that works out. will have to get a set of extra pivot blocks for the front to do some milling with the dremel.
Old 05-25-2003, 08:20 AM   #6239
Oasis's Avatar
Trader Rating: 36 (100%+)
With the xxx4 chassis it makes the car handle bad in the tight stuff even on the big tracks,plus their is that weight thing..as in way to much,Glide 1 have you tried a one way yet ? For me it really made the xxxs work alot better in the corners even on a small track,but my first car was a Yokomo so I'm use to driving a TC with a one way.
Oasis is offline   Reply With Quote
Old 05-25-2003, 11:50 AM   #6240
ttr
ttr's Avatar
Default Swaybar sets
My LHS has no front swaybar set on stock, but they have a lot of rear sets. By the pictures they look very similar. Can I build a rear set (with some tricks?) on the front of the car???
ttr is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
