Losi XXX-S
#6216
Originally posted by ROBORAT
glide1: aha! thoght id catch you sneeking around here too pare! daming tips dito. lots of guys to help you get the losi hooked.
team losi rules!
#6217
highwayman/glide1: yup. im still assembling my new ride and prepping it up for the big race at Capitol next saturday. Im trying a few different stuff on this new kit especially on my front end settings. will let you know how it works out. im expecting a not so good outing in the next few races though coz this little changess i plan to do. but of cors i still have my old set up memorized so i can always default to that if things go really bad! HA!
#6219
Originally posted by Painy
simon... were you at the Australian Nationals in canberra?
i know some NZ guys were there... how did you go at your nats?
Last big meet was in March, back racing Modified from a year and a bit racing 27t stock as a cheaper alternative to Mod(nice idea at the time but didn't quite work out that way).
There's an indoor asphalt series starting up again early next month where a couple of the guys(and me) who've posted in the last page or so will be racing...
#6220
Registered User
The XXX-S uses 8-32 threaded nuts to hold the wheels on.
A 11-32 nutdriver is typically used for 8-32 nuts. I have been using a standard Craftsman 11-32 nut driver for the Trinity low profile nuts on my XXX-S Plus.
#6222
Good luck with the changes. How was your setup last weekend? I had a slight mid corner push...any quick remedies? I usually run a softer setup at our track but for last weekends race i went up 1 to green fronts and red rear with 40wt oil. not sure what to do first to get rid of the push.
Highwayman, seen you here before and yes losi rulzzz!
#6223
Originally posted by glide 1
Robo, now i see what you mean about a new kit.... another losi!!
Hope this helps.
#6224
Maddod TL
Thanks for the tip. Ill try to go harder i think. I tried softer up front before but the car felt like it was slow to transition...a lot of steering though. thanks again
