Old 05-12-2003, 05:22 AM   #6136
Simon K's Avatar
I assume if we take the rear bumper off and stand the car vertically on it's rear end, using an RPM camber gauge should accurately measure the rear toe in on either side...used to do this with my Predator T1 to get it right...
Simon K is offline   Reply With Quote
Old 05-12-2003, 09:38 AM   #6137
tufferwilde's Avatar
Simon, You are correct, this car can have the rear toe checked in the same manner.
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 05-12-2003, 04:47 PM   #6138
Default xxxs setup
i am racing on a tight track i think. about a 100ft straightaway. the track temp will be about 100 degrees, maybe less. it is a sedan road course in a parking lot. asphalt. i like to drive smooth but if needed will be aggresive. i have the graphite plus xxxs, not the standard one if that helps
ernieball is offline   Reply With Quote
Old 05-12-2003, 08:59 PM   #6139
Ortiz's Avatar
Hey, does anyone know what kind of servo horn Todd Hodge was using in the Magazine... Got some big races coming up and im gonna move back to the servo horn again. I will risk it at a big race.
xxxkat.... thats what i meant.... ive been sniffing the traction compound again.
Ortiz is offline   Reply With Quote
Old 05-12-2003, 10:38 PM   #6140
Oasis's Avatar
Trader Rating: 36 (100%+)
I was pitting across from Todd at the Ca. state champs race and he was not using a servo saver,just a servo horn,but he can afford servos..
Oasis is offline   Reply With Quote
Old 05-13-2003, 05:36 AM   #6141
STLNLST's Avatar
Trader Rating: 19 (100%+)
I use run a KO servo and just recently switched to the a straight arm. Since it's a KO servo I went to the KO arm.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-13-2003, 07:13 AM   #6142
Oasis's Avatar
Yea but you dont crash..
Old 05-13-2003, 09:30 AM   #6143
I have always run just a arm on the servo and never broke ever in 3 years with the same servo
teamAE is offline   Reply With Quote
Old 05-13-2003, 11:33 AM   #6144
I personally run the stock servo saver with a extra spring on it.Even ran a servo saver at the ROAR Nat's running foam Modified..Not one problem with the steering.
BrianJ is offline   Reply With Quote
Old 05-13-2003, 12:01 PM   #6145
Default Outdoor Set-up
Hey guy's,here is a set up I think you might want to try if you race on a medieum traction track or parking lot.If you try it let me know what you think,and if you got something else in mind lets start posting set-ups and compare.
Thank's,
Brian Jucha
Front:
Oil:70wt
piston:54/ limiter's outside-.118 inside-.060
Spring:silver
droop:6(measured off the arm)
roll center block:high
pivot support:OF
sway bar:.063
shock location:hole#4(all the way stood up).060 spacer under bellcrank ball stud
caster block:4
camber link:drill hole above & between #2&3
Ride height:5mm/camber 1/2 degree
oneway front diff
Rear:
Oil:40wt
piston:54/limiter's outside-.080 inside .030
Spring:silver
droop:4(measured off arm)
roll center:Mid(cut .060 off high blocks or shim up a low roll block)
pivot support:4R in upper hole's(this will give 1-2 degree of anti-squat)
camber link:3-B-use standard silver ball end
arm spacing:middle F&R
ride height:5mm-camber:1/2 degree
Tires:Takeoff CS-27
Old 05-13-2003, 12:44 PM   #6146
Default Re: Outdoor Set-up
Thank's,
Brian Jucha
Front:
Oil:70wt
Spring:silver
pivot support:OF
sway bar:.063
caster block:4
oneway front diff
Rear:
Oil:40wt
Spring:silver
Tires:Takeoff CS-27
Hi Brian,
Was that track sprayed and did you happen to try a spool with that?
Mark
MDawson is offline   Reply With Quote
Old 05-13-2003, 02:04 PM   #6147
Make sure you don't use the AE ones!!! They have a nasty tendency to break on ya!!
Wilde
Old 05-13-2003, 02:19 PM   #6148
Mark D.,I ran that set-up one two seperate day's once with traction layed down and once without(on practice day's are track doesnt use sugar water) .I would say it worked better when the track was sprayed,but still was pretty good without the traction added.As far as trying a spool,no I have not tried this with this set-up,cant make it to the Reedy race so I am practicing for National's w/oneway.Maybe this weekend I will give the spool a try.I am spending alot of time at my local track(which is a large 100x160 permanent track similar to the track in NC)working on all kinds of different set-ups,I will keep you posted.
Thanks,
Brian Jucha
Old 05-13-2003, 02:50 PM   #6149
Thanks,
Brian Jucha
Im going to try to make it out to NC. If I get a chance I will try the setup on another car this weekend in Roseville. I have not seen the track in NC- is it mainly radius turns and open?
Old 05-13-2003, 03:00 PM   #6150
Ortiz's Avatar
Hey thats my local track in NC...
the website for the track is www.thercspeedway.com
here is a pic of the track..
Pic of track
The layout will probably be way more technical than it looks there.
Let me know if yall have any questions...
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
