Losi XXX-S
#6122
Tech Legend
Trader Rating: 51 (100%+)
Today I used a locking spool for the first time. A very interesting experiance. It pushed off power but when I hit the throttle that thing had killer steering and I would not have to leave off the hug the corner after that. I just need to work on gettting more steering off power and learn the drive it a little harder so I can use as much of the on power steering as I can. The IRS spool worked flawlessly along with then Big Dawg Bones with the pin cushions in. A little more practice and setup work and the spool will be a great addition to my car.
#6123
Originally posted by highwayman
also the white ball cups he has? does anybody know who made them?
As said before, RPM does have white ball-cups availible though..
#6124
What's a locking spool?
#6125
I just ran my new Losi for the first time. Not bad for the first time running anything but a TC3. My race results look like hell, (4th in the C-main 19 turn class ) But I learned alot. I have to say, I'm amzed at the cornering capabilities of this car, even with a standard diff. I was loose going in and a slight push coming out. I was running the stock setup other than a few shock position adjustments and 50 wt oil. I'm thinking the spool and a front swaybar will help. (New tires woulden't hurt either Any other suggestions?
#6126
Originally posted by M Ignacio
Do you guys know where Todd Hodge got his titanium screws that were on his car in the R/C Car issue? Where do you get a titanium turnbuckle that attaches from the servo horn to the steering rack ( Like the one on Todd Hodge's car in r/c car)?
#6127
That was the May 2003 R/C Car issue.
#6128
xxxkat, Do you have a part number for the yokomo turnbuckle? Was it titanium?
#6130
what is a good starting set up for the xxxs g+. i am running on an asphalt parking lot. any help would be appreciated.
#6131
Ernie: A couple of things we need to know before we can help:
1. Is it an oval or is it a road course? If it's a road course is it tight and slower or is it more open and faster?
2. What is the temp of the the air and track?
3. Are you running during the day or night?
4. What type of batteries and motor are you running, and describe what your driving style is like.
Let us know, thanks.
#6132
Rear Toe
I have notice since day one that *visually* it looks like the Left Rear has more toe in than the Right Rear on my XXX-S (old model). I figured it was just an illusion because the chassis wasn't a perfect square. I measured the rear toe, then checked the parallility (seeing if both sides have equal amount of toe) and the LR had twice(!) as much as the RR. My method of measuring probably wasn't the R/C industry standard, but I feel pretty confident in it. WTF is up with this? Or am I sniffing to many paint fumes?
#6133
hey guys, does anyone know where i can download a softcopy of MARs Ko Propo Ex-1 manual? thanks in advance
#6134
Phoenix,
The toe should be the same on both sides... sometimes the arm mounts and the roll center mounts are a little tricky to work with. take it apart and put it back together again. Just check and make sure that everything on both sides is the same.
#6135
Re: Rear Toe
