Old 04-30-2003, 12:18 AM   #5986
THeGame's Avatar
Send a message via AIM to THeGame
Default dicey
i had this problem to.
what car is it xxxs or the xxxs G+ your rear hubs might drilled wrong if there the new hubs. also check to see if you have the same amount and size shims on the arms. also check that you didnt crank down on the rear toe in block to much.
Hope this helps
THeGame is offline   Reply With Quote
Old 04-30-2003, 01:48 AM   #5987
Thanks TheGame for the infos... I am running G+ and i will try it tomorrow in the track... But i didnt like the way the shocks are sitting... they were too incline thats why i am asking.
thanks again
harris is offline   Reply With Quote
Old 04-30-2003, 06:35 AM   #5988
Thanks for the reply. It's the original kit. I remember hearing something about this once that's why I suspect there is an issue with the parts. I have tried to correct the problem by backing out all of the relevant bolts and realigning the parts but this has not worked.
dicey is offline   Reply With Quote
Old 04-30-2003, 06:47 AM   #5989
STLNLST's Avatar
Trader Rating: 21 (100%+)
Some cars can have the problem corrected while other's can't. The only way to get the same toe on both side's is by putting a different hub on the right side of the car. I had to run a 1 degree block on the right side to get my toe to 2 degree's per side. It sucks but this is the only way that it can be done.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-30-2003, 07:02 AM   #5990
Matt Howard's Avatar
stlnlst- don't worry, you won't have to do that with your new SD
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-30-2003, 07:21 AM   #5991
highwayman's Avatar
Can you guys give me some tips for this... im running the graphite plus now, with front one ways, red springs all around, 2 degree anti-dive... my over all steering is okay but the car seems to spin out on exit, im looking for some rear traction on the exit of the turn...
highwayman is offline   Reply With Quote
Old 04-30-2003, 07:34 AM   #5992
Send a message via AIM to munrath
Default Re: harris
Originally posted by THeGame
i wouldnt make this mod inless you are going to be run on High Bit carpet. I know Todd hodge and Andrew Gray were doing this. I did it and didnt like cause it takes steering away going in to the turn. If you want to do it shave down the front knobs on the blocks that hold the hing pins in like the 2 block or the 0/4 block. as for the shock tower you might need to shim it fwrd behind the shock collar. What car do you have the xxxs or the xxxs g+ ? cause your going to need to move the streeing rack in the fwrd holes.
Harris,
I also tried it and felt the steering to be to agressive for my driving style.
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 04-30-2003, 07:56 AM   #5993
STLNLST's Avatar
where are your rear camber links and shocks set at? Also, what wt oil are you running front and rear?
Old 04-30-2003, 07:57 AM   #5994
STLNLST's Avatar
I'm not buying that car.
Old 04-30-2003, 11:00 AM   #5995
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Default Re: Re: harris
Originally posted by munrath
Harris,
Mark
Mark, you? Agressive? Have nice trip, see you next wall - oops I mean FALL.
hehehehe, my XXX-S G+ is Gray's copied.. Because he build the darn thing
Now, I just have to learn how to wheel the thing like him...
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 04-30-2003, 01:54 PM   #5996
THeGame's Avatar
Default Re: Re: Re: harris
Good luck Trying
Old 04-30-2003, 03:23 PM   #5997
Ortiz's Avatar
Man, has anybody noticed how much the drivetrain freed up once you ran a couple of times.... I didnt have to work on anything. Super smooth and freerolling... I love it.
I got a pretty good setup on asphalt if anyone gets a wild hair and wants to try something different. Let me know...
Ortiz is offline   Reply With Quote
Old 04-30-2003, 03:31 PM   #5998
Ortiz- please post the set-up and how the car feels to you!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 04-30-2003, 04:22 PM   #5999
Ortiz's Avatar
Impact... sent you a PM with the setup...
Oh.. some more things i forgot to mention in the PM... I have been using a Stratus 2.0.. but it should also work great with the Alpha...
Red shock pistons all around...
Old 04-30-2003, 08:19 PM   #6000
Oasis's Avatar
Trader Rating: 36 (100%+)
I was starting to lose faith in you STLNLST..if I get beat by one I'll buy one..Not,everyone has a bad day,any one can win 75% driver,25% car..SW cup..oh yea.
Oasis is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
