Old 04-17-2003, 12:12 PM   #5881
Wilde-
Thanks for the input. How do you like the spool?
timc is offline   Reply With Quote
Old 04-17-2003, 01:23 PM   #5882
Oasis's Avatar
Trader Rating: 36 (100%+)
Here's my 2 cents on the spool,I do like using one on a large track with wide lanes,On a smaller track with smaller lanes it pushed real bad exiting the corners(maybe I had the wrong set up)It does work real good on a bigger track.
Oasis is offline   Reply With Quote
Old 04-17-2003, 01:58 PM   #5883
Madcap Magician's Avatar
I guess the only difference between a spool and a one-way is that you have more off-power steering with the spool, but more on-power steering with the one-way? Or am I screwed up some where?
Madcap Magician is offline   Reply With Quote
Old 04-17-2003, 02:20 PM   #5884
I think you have it backwards, but otherwise correct.
dicey is offline   Reply With Quote
Old 04-17-2003, 02:28 PM   #5885
tufferwilde's Avatar
As for the Spool - Dicey hits it on the head (sorry madcap magician... have another brew!!)
The spool is going to push like a raped ape off power... and on power, you have a ton of steering.. While our track at SRS is by no means open.. the spool certainly did make on power turns fast... sweepers and chicanes were incredibly fast, but only if you are on power - the moment you get off the power, the steering goes away!
Another huge advantage of the spool is the incredible amount of braking.. this way - you can drive far deeper into a corner and still have the brakes to make a corner if the driver ahead of you leaves it open.
OUT - wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 04-17-2003, 02:31 PM   #5886
TimC - I would say that the jury is still out on the spool - I loved it in my stock car on carpet... in mod it was too unpredictable at speed (it was difficult to keep it going in a straight line on power) Was the car fast through the corner? oh yeah... but it wasn't as easy to drive as the losi normally is
Wilde
Old 04-17-2003, 07:04 PM   #5887
Send a message via AIM to M Ignacio
What's up you guys. What are the best bearings for the XXX-S? Where can I buy them? Thanks
M Ignacio is offline   Reply With Quote
Old 04-17-2003, 07:20 PM   #5888
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
HAHAHA...funny similes
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-17-2003, 07:22 PM   #5889
the ones that come in the car are pretty good u just have to let them sit in some motor spray in a pill bottle for a few hours then use trinity royal oil or some type of synthetic oil and let them sit for a few min in them. if u need new bearings i would get boca bearing www.bocabearings.com there ceramic bearings are the best
hope i was of some help
jiggamacdaddy is offline   Reply With Quote
Old 04-17-2003, 07:50 PM   #5890
Does Boca Bearings sell XXX-S Bearings in a package? Is there a place where they sell Boca Bearings in a package for the XXX-S? Thanks
Old 04-17-2003, 08:07 PM   #5891
im sorry not shure about that but u can email them to find out if they do sell a full set if not u can look in the manual and it will have all the sizes of the bearings in the kit so u can make a set
Old 04-18-2003, 11:28 AM   #5892
Thanks for the info, bro.
Old 04-18-2003, 01:19 PM   #5893
highwayman's Avatar
Cool
my two cents worth on the spool of the XXX-S... it takes a huge toll on my drive train... better to have a one way... seems faster in the straights also...
highwayman is offline   Reply With Quote
Old 04-18-2003, 01:50 PM   #5894
what pistons and oil should i use on asphalt with a one way?
Old 04-18-2003, 02:05 PM   #5895
highwayman's Avatar
30 weight oil front and rear
#56 red shock piston
Red Springs front and back
* you've got to consider also the roll center, shock position and camber link position, start with the stock set-up and improve from there...
- hope this works for you...
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
