Losi XXX-S
#5806
hey big t bone i have a extra mip tweek station make me a offer i dont need 2.. thanks teamatlas
[email protected]
[email protected]
#5807
Hey guys what is the stock spur gear on the XXXS??? Thanks!!
#5808
the standard losi is 88 teeth
the graphite plus is 90 teeth
all 48 pitch
all 48 pitch
#5809
I'm still a little new to the T.C. world, quick question. When I got the 4 degree caster block kit, it has C blocks and steering blocks. Does the combination of the two parts give the car 4 degree of caster or does the C block set the caster and the steering block is 0 degrees? thanks for the info.
#5813
Go to www.teamlosi.com try Ron Rosetti,s parking lot set-up.should wrk good for you if track is not so good.
#5815
Originally posted by xxxkat
I tried that set up..for me it really sucked,I hope you have better luck with it than I did.
They should still be a good starting point for most tracks, but at the same time, you can't expect it to be perfect.
#5816
i thought it was pretty good.... and brian j is a team racer......so you already got a reply.....
#5817
Jucha,
You on Losi now? If so, awesome job. I saw the Nats results. Very nice finish my brutha.
Take care,
RB
Take care,
RB
#5819
Thanks Rob,you getting back into racing?
#5820
STLNLST:looks like you have a pretty good set-up for Billy,s track.Have you ever tried running a mid roll center in the back?All you have to do is either cut the high roll blocks .060 or shim up the low blocks.060.Then use the 4R block in the upper holes will give you about 1-2 degrees of anti-squat.This is how Paul Lemieux and I ran are cars at the Novak Race.This adjustment works really good when the traction comes up.I have been to Speedworld before and the traction seems to get very high.Good Luck to you ,Brian
