Like Tree2Likes
Losi XXX-S
Old 03-16-2003, 09:06 AM
  #5716
KevanB's Avatar
Ohhh I get it now! Will any other strong plastic piece work for this? I have lots of strong plastic crap that I dont use. So I will have to drill a hole into my precious Graphite?
KevanB is offline
Old 03-16-2003, 09:41 AM
  #5717
Oasis's Avatar
Trader Rating: 38 (100%+)
That's the only way I know of ,Of course you could allways try Ca. glue.
Oasis is offline
Old 03-16-2003, 10:04 AM
  #5718
LouisB's Avatar
I used to use a piece of foam glued on to the chassis.
Here's one I did earlier, but TSR6 did it first.
LouisB is offline
Old 03-16-2003, 10:09 AM
  #5719
RCTech Member #2
TSR6's Avatar
The servo mount is just to hold the battery tight against the chassis right???
On my old chassis ( Non GP+ ) I used a piece of AE Battery foam ( used in the buggies to keep the batteries tight ) I glued it with ShoeGoo between the chassis tub, and the battery, with just enough foam to push on the battery.
Edit - Louis - Great minds think alike. Same post within minutes of eachother.
TSR6 is offline
Old 03-16-2003, 10:21 AM
  #5720
KevanB's Avatar
Where can I find a giant, hard, chunk-o foam? I have some foam pieces like that, but they are too small. I need something that will REALLY hold down the pack, because I do not want to ever use strapping tape again!!
KevanB is offline
Old 03-16-2003, 10:43 AM
  #5721
LouisB's Avatar
I used an old pro-10 rear tire, any firm foam will work.
TSR6 I find with the G+ chassis that my packs stay in fine now, same with you?
LouisB is offline
Old 03-16-2003, 12:33 PM
  #5722
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally posted by xxxkat
STLNLST have you tried the contac paper yet?The new Losi Lexus IS300 looks good and it looks like it will work real good.
I haven't painted any other bodies yet. I still had two new one's that I didn't bring to the state race with me to use.
STLNLST is offline
Old 03-16-2003, 01:05 PM
  #5723
Rookie01's Avatar
Default question
Someone know if there any aluminum outdrive available or I have to stick with the molded one?
Rookie01 is offline
Old 03-16-2003, 01:32 PM
  #5724
Rookie01, I dont know of any aluminum outdrives available. Is there any reason why you would want to change the composite ones? They hold up great even under low turn mod motor conditions and are the lightest available for better punch. I have only seen one get broke but you should have seen the rest of the car!!
Doug Gaut is offline
Old 03-16-2003, 01:58 PM
  #5725
Kevin-- any piece of plastic that will stick up far enough to disallow the batts from sliding out will be fine.
TSR6--- No, it is a stop sort of just to prevent the battery from sliding out...
IMPACTPLAYR is offline
Old 03-16-2003, 02:14 PM
  #5726
Rookie01's Avatar
Doug Gaut: Just broke one outdrive, the other thing that broke is only a front table. no other dammage. Thats why I was looking for a aluminum outdrive.
Rookie01 is offline
Old 03-16-2003, 02:28 PM
  #5727
racecar850's Avatar
Post BLAKESRC
HEY CHECK YOUR PM
racecar850 is offline
Old 03-16-2003, 03:18 PM
  #5728
Rookie01, if durability is a problem you can always install some Trinity aluminum outdrive savers.
Old 03-16-2003, 03:35 PM
  #5729
Rookie01's Avatar
Doug Gaut: Thanks a lot! I will give it a try.
Rookie01 is offline
Old 03-16-2003, 03:49 PM
  #5730
RCTech Member #2
TSR6's Avatar
No problems at all since i switched to the GP+, although the only time I ever had problems after I put the foam block in there was with borrowed batteries, and the solder joint came un-done in a pretty good wreck.
I'm pretty sure I used the AE Foam block that does into the RC10T and RC10B3. The block acts like a 7'th cell (..lack of better way to describe it ), keeping the batteries in tight to the chassis. I know my LHS has them, I just dont know the #.
TSR6 is offline
