Old 03-12-2003, 06:34 PM   #5686
alfa's Avatar
is your droop more that 5mm?, are those the purple springs the front ones? if so there shorter than the silver rears it think.
alfa is offline   Reply With Quote
Old 03-12-2003, 07:21 PM   #5687
dstrout, Try taking your rear droop screws completely out, then set your ride height. With RH set, put the droop screws back in, and set your droop. Note: The spring should never be preloaded. With the car off the ground, the spring should move freely (it can be close, or touch a little, but shouldn't be compressed)
Also, it's hard to tell in the picture, but it looks like you have the MF low roll center blocks. If you do, make sure your rear pivot support is in the lower hole. If it's in the upper holes (if that'll even work???) it would probably make it impossible to get ride height.
alfa, I don't think the spring length should matter. I run the 1" springs (shorter ones, long are 1.15" I beleive) front and rear, and get ride height easily. As long as you've got the same spring length left and right, it shouldn't matter.
JeffC is offline   Reply With Quote
Old 03-12-2003, 08:55 PM   #5688
stumper1's Avatar
R/C Tech Charter Subscriber
I've had the same problem with certain set ups. The G+ springs are all 1" - I think the old kits were 1" up front 1.5" in the rear. If you have any Associated clip-on pre-load spacers it's a good temporary fix. I finally found some 1.15" springs for the rear end and it orks much better ( with the associated clips the spring rub on the shock bodies ).
stumper1 is offline   Reply With Quote
Old 03-12-2003, 08:59 PM   #5689
STLNLST's Avatar
Trader Rating: 19 (100%+)
is there a chance that you have the short FRONT shock shafts in the rear???
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-13-2003, 03:24 AM   #5690
Send a message via Yahoo to dstrout
Well, since I didn't realize there was a difference, there's at least a 50% chance
I'll check it out. I know my front shocks are 2.3", as I measured them to make sure they were the same when I pout them back, but I haven't measures the rear -- I'll check it out. I'll also check the spring length, as I have a whole box o' springs and may have grabbed the wrong ones.
thanks guys,
dave.
dstrout is offline   Reply With Quote
Old 03-13-2003, 03:58 AM   #5691
Default Doh!
Well, I guess this falls in the category of having "a keen grasp of the obvious". A droop gauge is not a ride height gauge
I was trying to get the car up to the "3" on the droop gauge, which is closer to 12.5 mm! It's no wonder I ran out of shock travel. I'll have to run out & buy a ride height gauge at lunch today.
Thanks for the spring-length tip, though -- I did have 1" springs on the back -- I put the longer ones on while I was at it.
thanks,
dave.
Old 03-13-2003, 06:50 AM   #5692
RandyB's Avatar
HAve you guys checked out the pictures from the carpet nats. Heres my question and I havent yet seen it addressed in the thread.
Has anyone noticed the ft guys cahnging the link from the servo to the steering rack take a look they are placing a ball in te middle of the rack lengthing the link. hhhmmm why would they do this?
any insight
later
RandyB is offline   Reply With Quote
Old 03-13-2003, 07:03 AM   #5693
i have the g+ and i run on a tight track (with my steering maxed) and i can't get the thing to turn (it pushes BAD!) ii run the orage springs in the front and whites in the back it also likes to lift the tires up in the end of the straightaway going into a 180 has anybody else had this problem i have tried lots of different stuff and it only makes it a little better! can anyone help?
zachtc3 is offline   Reply With Quote
Old 03-13-2003, 07:14 AM   #5694
Send a message via AIM to TeamRoy
any insight
later
I was told that this makes the steering less twitchy. Doesn't make sense to me, but that was what I've been told. It was originally done to the xxx4 and some of the guys did it to their sedans as well.
TeamRoy is offline   Reply With Quote
Old 03-13-2003, 07:23 AM   #5695
any insight
later
Old 03-13-2003, 06:38 PM   #5696
alfa's Avatar
try the kit springs (puple front and silver back)
Old 03-14-2003, 08:56 AM   #5697
rayhuang's Avatar
GUys,
I have my spare kit (G Plus) for sale in the Swap and Sells on RCtech. Just look for it under my name-of course. Its new in an un-opened box. PIcture and all!!! It will save you some money!!!
Ray
Old 03-14-2003, 08:40 PM   #5698
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Jeffc, LouisB...
Since I am running on a slick surface should i run high or low roll centers? Front or rear etc?
Blake
Blakesrc is online now   Reply With Quote
Old 03-14-2003, 09:14 PM   #5699
rayhuang's Avatar
Default High Roll for slick surface.
I am not either of the guys you mentioned, but I would run high roll center on a slick surface because it has been my hands on experience that the higher the roll-the more planted the tires become-hence the more mechoncal grip you produce. After running both front and rear high, you can slowly lower the end that feels too planted-no matter what springs, tires etc you use.
Its a subtle thing to feel. Roll centers arent the easiest thing to feel till youve actually changed it and nothing else and know what it does on your car.
Old 03-14-2003, 09:31 PM   #5700
Blakesrc's Avatar
Rayhuang, thanks for the info! I need all i can get at the moment, this track is driving me crazy.
Blake
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
